I CANT FIND THE MANUAL FOR MY REMOTE ANY WERE
MY T.V IS A PHILIPS/MAGNAVOX SAME AS THE REMOTE BUT I DONT HAVE A MANUAL TO SET IT UP
SOURCE: Philips Magnanox Universal Remote CL034
I found this website and it has the codes for everything for your universal remote. Good Luck.
http://www.universal-remote.net/philipsmagnavox.html
SOURCE: remote codes for "ph301s" universal philips remote
www.remotecodelist.com .............................T.
SOURCE: philips universal remote control cl034
hey i tried this and it worked. hold code search till the light stays lit(it may take a couple of secs ) then after its lit press tv and then keep pressing channel up or down till the channel on your tv changes when does press mute to save the code. also the power button will work to during code search , but i use channel because if you accidentally skip your code you can go back the other way. you might need to take out the batteries then re-insert to reset any previous codes. hope this works for you guys as well.
I lost the remotes's manual.
