How do I stream music using airport express to beosound1?
5 Suggested Answers
SOURCE: new wireless network - now my airport express and airtunes does not work
thanks so much - vey helpful!
Posted on Sep 04, 2007
  • 17 Answers
SOURCE: airport express streams audio for a short period then quits
Make sure that your setup for the Express is set to "join the network" and not extend.
Also remember that with wireless technology there can be interference from microwaves, phones, etc.
If you are running programs that use a lot of bandwidth, this will cause the drop outs as well.
If you have a newer Express, another cure can be to use the 5GHz band for the broadcast channel.
Posted on Feb 15, 2009
SOURCE: Airport utility cannot find airport express - ask for rescan
connect a ethernet cable to it. find it in the utility and reset it.
Posted on Apr 21, 2010
SOURCE: Hello, Bought a near new Airport
What you need to do is attach a network cable directly from your machine into the base station. Then launch the Airport manager utility and reset everything from there
Posted on Aug 23, 2010
I want to plug stereo cables with the red and white ends into my LG FB163 mini shelf stereo, so that I can use my Airport Express to stream music from iTunes, but I don't know where to plug the red and...
there should be an aux/analog in. if the analog/aux in does not use red and white rca jacks, then it must be a single 1/8th inch jack input, like a headphone jack, and you will have to get an rca to 1/8 inch "Y" adapter
Nov 06, 2010 | LG FB163 DVD/DivX USB Micro system Shelf...
I'm having trouble finding a reliable software to download that will enable me to play youtube/slacker/pandora (non- itunes music) on my Mac and listen through my stereo using my Airport Express,...
Welcome to Fixya community.
Please try download and Install MacTube Player to play Youtube video or music... Let me know the result please...
Also to play the music in stereo receiver please follow below steps.
  1. Plug in the Apple AirPort Express into a power outlet near the stereo. Connect an audio cable from the audio port on the AirPort Express to the audio in port on your stereo. If your stereo has a different sized audio port than the 3.5 mm one on the AirPort Express, you will need to use an adapter to connect it.
  2. Plug in an ethernet cable from the AirPort Express to your computer or wireless router for a wired connection. For a wireless connection, connect the AirPort Express to your existing home network, or use a computer with a wireless network adapter to connect directly to the AirPort Express.
  3. Connect to the AirPort Express with your computer as directed in the manual to run the setup with the AirPort utility. Follow the instructions on the screen.
  4. Open iTunes and play the music to your stereo. There should be a pop up in the lower right corner after you run the Airport utility.
Let me know how far you could able to reach in a result. Our expert friends are here anytime to solve your issue.
Thanks once again for joining us.
Have a good day.
Aug 02, 2010 | Computers & Internet
Attempting to connect new Acer netbook to existing Mac network
Had the same problem. What i did was in the Airport Configuration program goto "Airport" then to "Wireless" and then to "Wirelesee options" In this menu deselect "Use wide channels". Also i decreased the power of the 5.0 Ghz transmission, because i don't use it yet. But i think the "Wide channels" is the reason of the problem. It is a bit weird thoug, on my Airports Guest acount with no password and incryption, the Acer One loged on perfectly, but on my private network with WPA2 it did not. Aparantly the Guest network does not use "Wide Channels" Hope this helps, but take care, maybe the menu's are called differendly because i had to translate them from Dutch. Good luck.
Aug 11, 2009 | Apple AirPort Extreme Base Station
Airport express streams audio for a short period then quits
Feb 14, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
I can't connect apple airport expresses with a siemens 587 route
Login to your airport express using Apple's airport utilities (either in it's current configuration or after resetting it).
Using the airport utility do not choose manual setup, just select continue.
Adjust (as required) the airport express station name and password and select continue.
Select "I have a wireless network and I want to add AirPort Express or replace an existing device on my network and select continue.
Select I want Airport Express to wireless join my current network and select continue.
Choose if you want to extent the rance of your network or just join the network and select continue.
Choose the network you wish to join... etc etc etc....
You should be fine.
Jan 31, 2009 | Apple AirPort Extreme Base Station
Just installed Airport Express. I can select it from iTunes on my PC running vista. The music plays but songs intermittently stop...it like it can;s download fast enough...suspect the laptop can't send...
Make sure that between the laptop and airport express you don't have devices that can interfere, like microwaves, phones, etc.
Also, if its a newer express try using the 5GHz band and that the airport is set up to "Join the network" not "Extend".
Dec 25, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Which wireless router.
if your using a imac product i would suggest for this complex system a cisco router they will have all you need in properties and allow streaming sound and video threw there routers
its a preference i like to use
little bit more money but the quality is what your looking for right
May 19, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Yamaha RX V800 w/ iTunes Airport Express
thats cause your patch cable is mono get a stereo 3 ring connector.
Apr 01, 2008 | Yamaha RX-V800 Receiver
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
