Question about Amana PTH123E35AXXX Air Conditioner Heat Pump
Why does my amana pth123 keeps tripping breakers
3 Suggested Answers
james3751
  • 614 Answers
SOURCE: My Amana heat pump model PHD60C02F1 Keeps tripping
Is this kicking the ground fault on the cord or the breaker. If it trips breaker could be bad breaker. If it trips quickly it is a short in the unit. Russ
Posted on Aug 01, 2009
TheMobilian
  • 8220 Answers
SOURCE: My amana Ptac keeps tripping breaker.
Must be a swolen or shorted capacitor, that would be the first thing I would checkthemobilian_3036.jpg
Posted on Sep 30, 2011
Amana RCE24C2A trips circuit breaker
tripping the circuit means the unit is has a ground, "means some peeled wire inside is touching its metal case"
Jun 01, 2013 | Amana Heating & Cooling
Sep 30, 2011 | Amana PTH123B25AJ Heat Pump Air...
My amana gas range just tripped the breaker and now the oven light will not turn off and it keeps tripping the breaker every couple tries. It is running of a 20 amp breaker so it should be getting enough...
One possibility is that the circuit breaker has weakened and tripping intermentently for no real reason. To see if that is the case the oven could be plugged into a outlet on a different breaker using a extension cord.
Another potential cause is that any one of the wires in the range has became bare and lost its insulation and touching a peice of metal, shorting out
Good luck in figuring out what is wrong,
Gene
Aug 05, 2011 | Amana Kitchen Ranges
I have a Amana PTAC model PTC123A50AC never had any problems until this a.m. walked into office were installed no heat. Breaker tripped, reset breaker, nothing. Checked outlet, getting power. Any idea's?
To all friends! Whenever you find breaker tripped or fuse blown, it's an indication some device/s are in problem.
To get tripped breaker:
1. Condenser too dusty- clean it.2. Fan motor or compressor grounded-Replace. 3. Compressor high amps due to capacitor weak-replace capacitor. 4. Burnt wire-rectify. 5.Short circuit-rectify.
Jan 11, 2011 | Amana Heating & Cooling
Amana side by side SB 520S fridge trips ground
the unit has a higher heat load than normal after being off for a time. the compressor draws alot of amps and could easily trip a ground fault cb. The breaker should have a ground wire hooked into the back of the breaker that is connected to the nuetral or ground bar. this wire should be at least 12 guage wire if it is on a 15amp breaker
Dec 20, 2009 | Amana SXD524VW Side by Side Refrigerator
My microwave oven keeps tripping the circuit breaker.i replaced the outlet that it plugs into but it still trips it. is there an internal fuse in the oven that may be bad?
If a fuse inside had blown, that would definitely reduce the current flow rather than trip the breaker.
I have replaced several breakers over the years; they no longer last forever.
Try your Amana on a different circuit, not in the kitchen; if that other circuit likes the oven, the breaker is bad. If the alternate circuit breaker also trips, then you have not a blown fuse in the Amana but rather a shorted component inside and repairing the oven will likely cost about the same as replacing it.
Nov 22, 2009 | Amana Radarange Microwave Oven
Breaker keeps tripping when I use Amana NED5500TQ electric dryer.
Heating element or motor. Usually heating element. Replace limit switch (inside dryer) during repair. Limit switch should shut off before breaker if working correctly.
After repair clean or replace plug/wire. Inspect or replace receptacle in wall.
Sep 28, 2009 | Amana NED5500TQ Electric Dryer
I have a Amana Electric Dryer NED5500TQ. When I
It is possible that you could have a bad breaker in the panel. They will start to trip randomly when they are going bad. If not the dryer is drawing too many amps and the breaker is doing it's job. If the heating element is defective and drawing extra juice that could trip the breaker. Usually replacement breakers are not too expensive if you electrical panel is less then 20 years old and can be purchased at most home improvement stores. I would try replacing the breaker before you try repairing the dryer. If you install a new breaker and the problem continues to happen then you should check the dryer heating element. That component is what draws the most amps and would be the most common one for tripping the breaker.
Sep 25, 2009 | Amana NED5500TQ Electric Dryer
Trips breaker when plugged in
If it still does, you have a dead short in the electrical system of the dryer. Don't try to use it until you get it fixed. It could start a fire.
Sep 11, 2009 | Amana Dryers
My Amana heat pump model PHD60C02F1 Keeps tripping the circuit breaker
Aug 01, 2009 | Amana PTH123B25AJ Heat Pump Air...
Amana PTH123E35AXXX Air Conditioner Heat Pump Logo
15 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
