Question about Canon CLC 2400 Color Copier
ERROR E061-0122 When a job is sent, printer just shows E061-0122 Turn OFF and ON printer... and it does deliver a blank paper... can anyone help me?
  • paulalvarezm Jan 29, 2009
    i'm about to fix it... will let you know..
  • 168 Answers
E061 is a code for a drum charge error on the first drum in line from right to left i think yellow ? any way its either a worn drum broken charge wire if you have not changed drums in a while the other ones may be coding out next
Posted on Jan 28, 2009
My cannon D680 prints a blank page after every print or copy job. the pages print fine but at the end it always feeds 1 blank page. what can it be?
See if there is an option in your settings to print a "job owner" page after each job. That's not what it's actually called but I had a similar issue with a Canon printer and found that you can have the printer automatically print a page after the job that identifies who sent the job to the printer. It's the last page so it lands on top of a finished job and separates it from other jobs sent to the printer before you have a chance to get yours. If you don't have network identifications associated with users it may just print a blank page as a separator.
Jan 14, 2015 | Canon imageCLASS D680 Laser Printer
Printer shows jam when there is none, press the check and it prints OK
That type of problem is called a phantom paper jam and is caused by the printer not picking up the paper like it should. When the print job is sent to the printer the pickup rollers turn and should grab the top sheet of paper and feed it into the printer. When the rollers get worn down and slick they can not grab the paper right so you get the error message. When you retry the rollers may be able to grab the paper and the job goes through. To correct this intermittent problem you will need to replace the pickup rollers and separation pads. This is easy to do for the end user no need to send the printer in for service. Here is a link to the roller kit needed for the HP Lasejet 2420 printer:
http://www.ccl-la.com/catalog/product_info.php?products_id=304
Mar 05, 2013 | HP LaserJet 2420 Printer
Load tray plain, letter Error shows by printer
You need to go into the paper setup on the printer and make sure that it is set for plain letter. The error you are getting is your printer thinking it does not have the correct paper loaded for the print job you sent.
Apr 18, 2012 | HP LaserJet M1005 Printer
I have a konica 2400 w magic color. error message paper jam when no paper jam
Hi Camru, I wondering if the jam light is on at power up before data is sent to your machine or if it occurs after a print job is sent to it?
If it is on constant ie before a print is sent to it, then we have a sensor or paper detect switch activated. If this is the case then it can be a piece of paper or a remaining fragment of paper holding down the switch or the switch arm itself is broken or its corresponding light sencing photocell is covered in toner/dust.
In Printers there are a number of these sensors in the paper path, generally we have one that detects paper at cassette and bypass position, another at registration roller another at fuser exit, the machine monitiors these switchs for activation to tell if a jam is present. These switchs are tiny plastic arms that get pushed down when paper passes them which in turn blocks the photocell sencing light. One normally finds fragments of paper sticking the arm down, or the arm broken, most of the time the printer also tells us jam position so we know which switch it is seeing a jam condition at. Check the switch operation by looking for them, and ensuring the arm is moving freely.
The other possibility is the machine with no data present shows no error but a error occurs when a print job is sent to it. If this is the case it is caused usally by incorrect paper size settings in printer paper size menu or the printer drivers paper size settings on installed driver in printers under control panel of computer, It can also be caused if the paper is feeding multi sheets from cassete due to dirty rubber rollers in printer itself or not picking paper from tray at all as the feed roller is slipping on paper in tray due to losing its grippyness.
I clean feed rollers with water, just slightly damp rag and rub the rubber surface of the feed roller, sometimes they are so worn they need replacing, I will post a pic for you and also here is the service manual of a machine pretty much the same as yours.
This is another uses post on how he fixed his, please note this will be the same as yours only if jam only occurs after data is sent to your machine.
Cheers
Steve
Feb 03, 2012 | Office Equipment & Supplies
I have a Brothers MFC 7420 and it will not print, says Manually feed paper
that means the job you sent was larger than the paper size in the tray, to clear this put blank pages one by one in the front slot of the machine until it prints t out the job
Dec 13, 2009 | Canon S520 InkJet Printer
MP630 print ERROR - ''There is no paper. Load paper and press OK''
You have to set up NOT "cassette"(in this case "cassette" means the front side of the printer where you are supposed to place a cd or dvd) Choose "rear tray" ! You might have changed the settings by mistake. I had the same problem. I was wondering why is the printer not taking the paper but i figured it out. Try the settings on the mini display of your printer.
Jun 10, 2009 | Canon Office Equipment & Supplies
Print Jobs from our IBM Unix System Reports creates Ghost Jams
The answer to our problem ended up being a firmware upgrade to the Canon iR7095. I would look into that as your possible solution.
Oct 10, 2007 | Canon ImageRUNNER 3570 Copier/Printer
HP 5550 Print issue
When you removed the jammed paper , the jam paper sensor was not reset or positioned correctly. The reason the machine was sending two pieces of paper thru at once was probably due to the paper feed sensor. A lot of H'Ps do this. Try re-aligning the tray and if you pulled the paper out and heard a grinding noise, the whole feed unit is probably out of time.I would only re-install the software as a last resort, since your problem was caused by hardware, not software. Scrivitron
Jun 20, 2007 | HP DeskJet 5550 InkJet Printer
Canon CLC 2400 Color Copier Logo
381 people viewed this question
old marine
old marine
