Question about Ibico GBC HeatSeal HP924 Hot Laminator - 1703002
Ibico repair parts for model el12 laminator - Ibico GBC HeatSeal HP924 Hot Laminator - 1703002
User manual for ibico pl-330 ic
http://office.manualsonline.com/support/other/laminator/laminator-manual-required-2292677
Oct 12, 2014 | Office Equipment & Supplies
Paper **** inside
Probably rolled itself around the rollers. Got to be real careful to not have any exposed inside surface (of the laminating pocket) showing since that coating is heat-activated and sticky.
Unplug it, wait for it to cool, flip it over and remove the screws holding it together.
If the laminating pocket is just physically wrapped around one of the rollers, it will come right out. Re-assemble and go back to work being careful not to put anything through that is the least bit curly.
If the laminating pocket is stuck to one of the rollers, just chuck the thing out and buy another one. The cost of parts and repairs will exceed the cost of a new unit. To remove the adhesive, one would have to disassemble the entire motorized assembly and then heat the "offended" roller to more than 180?F to get the adhesive to soften enough to scrape it off. Then, while it\'s still hot, one has to use a solvent matched to the adhesive to remove all remaining traces (\'cause if there is any left, it will just suck the next laminating sheet right around the roller and you\'re back where you started).
Remember:
- Use only laminating pockets for that brand (different models may have different temperature ratings). If the clerk says their laminating pockets are universal, ask the Clerk to guarantee in writing on his company\'s letterhead that they\'ll be responsible for any damage / repairs / replacement. They won\'t.
- Don\'t put anything that\'s curling through.
- Don\'t put anything through where part of the inside of the laminating pocket is exposed (because as it heats up it will stick to anything and everything it touches)!
Mar 05, 2014 | Xerox Staples XRX LM1910 Laminator
Porter cable Laminate trimmer maual
The motor is part # 3092 and the base is model 3091. When you put the two together it becomes a model 309. A parts list is here. http://www.ereplacementparts.com/porter-cable-3092-type-laminate-trimmer-parts-c-129_1861_1865.html
May 01, 2010 | Porter Cable Porter-Cable 309 Factory...
Where do i buy spare parts for ibico 1232
where can i buy spare parts for the Ibico binder 8038
Dec 13, 2009 | Ibico Office Equipment & Supplies
I have a Ibico el12 ii laminator and need to know how to use it. I cant find the instruction manual for it at my new job i put the sheets in as it shows but it labinates the first 1/2 inch then goes no...
You need to put your document in a carrier to prevent the heat from buckling the pouch before it makes it into the rollers. I've had a similar problem in the past before I remembered to use the carrier.
Jul 02, 2009 | Office Equipment & Supplies
Hi, Our Ibico IL19VT Laminator (A2) has paper jammed inside of it. There are no reverse mechanisms on the laminator. The only feasible method is to open the laminator up at this point, whether or not...
You can open this yourself but i recommend sending it for repair. If you decide to do it yourself here is how: turn the unit over and on the end with only one screw (not the power setting side) take it out using a Philips screwdriver. Next you will need size 3 and 4 hex bits. Use size 4 to undo the 4 hex screws. Hold the non power end and it should slide off. You will see four rollers two on each side of the heater element. Using the size 3 hex bit undo the 4 hex screws at the exposed end and lift up and out the 2 housing bits. Careful as these are made of plastic and break easy. Remove the offending material and then put everything back together.
Simples!
Aug 21, 2008 | Office Equipment & Supplies
Ibico 2700 laminator
I need to replace the rollers on my IBICO 2700 laminator. I will need to order the new rollers can you help?
Apr 24, 2008 | Office Equipment & Supplies
Ibico 080s
ACCO Brands Corporation owns General Binding Corporation (GBC). GBC offers products under numerous brands, including Ibico. Ibico's owner's address appears to be in Switzerland
From GBC's sparse Ibico's homepage:
"Contact Us
Where can you buy Ibico Products, fill in your information and the products that you are interested in and we will send you information on the nearest Ibico dealer. "
I'd suggest just going to that page (link here) and filling out the contact info and including the specific information about the model found on this page (namely the product ID num)
.... i could be way off... but it is all i could find on google =)
Jan 04, 2008 | Office Equipment & Supplies
Ibico GBC HeatSeal HP924 Hot Laminator - 1703002 Logo
330 people viewed this question
Top Ibico Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Ibico Office Equipment and Supply Expert? Answer questions, earn points and help others
