Question about Pyle Audio Players & Recorders
Can not get power to my pyle amplifier
Tried to set up directly from amp to batteries in my razor s ( small dune buggy )with no luck on the power. Check fuse - Ok, Checked fit- OK. Tried the neg to chassy- no luck. Using 14 guage wire. Key on ,key off, engine running and just no luck - Any ideas ?
    Problem Solver:
  • 16 Answers
Usually On Car Amplifiers, there is a Connector/Wire called "Remote On".
This is where Headunit supplies 12V to trigger the Power on the Amplifier.
(Of course, head unit usually has Remote Wire also in order to turn the Amplifier on).
If this wire is properly connected and still does not turn on, then try to supply 12V directly from the battery. If it turns on then your head unit has problem, If it does not turn on then your Amplifier has problem.
Posted on Jan 31, 2009
Pyle pcau44 amp
A fuse is blown, check main supply fuse.
Dec 22, 2013 | Pyle Audio Players & Recorders
Razor Dune Buggy Problem
I have the same issue with mine. Batterys check out fine.. i'm starting to suspect the motor??
Jul 23, 2012 | Razor USA Razor Dune Buggy
My razor dune buggy won't drive
are you sure that the charger is putting out enough volts to charge the batteries? check the charger with a multimeter, then check the batteries with a multimeter, and viually inspect the batteries for bulging
Apr 28, 2012 | Razor Dune Runner 350 Go Cart
Buggy is removing charge from battery
try investing in a battery charger instead of replacing the battery the dune buggy probably doesn't have an altinater to recharge the battery
Apr 18, 2010 | Jeep 36 Volt Battery for Minimoto ATV, Go...
Pyle dryver amp light protection stays on not green light stays red i have tried to disconnect everything and plug it back up but light stays red
check your subs disconnect them the try to power the amp up if it powers up the the subs have died and it could be a problem with that amp i suggest you get a better amp
Jul 09, 2009 | Pyle Dryver PLAD213 Car Audio Amplifier
PyLE PT2000 Power Amplifier' { is it worth it??}
People talk alot of **** about Pyle amps, all I can say is that,
I have two PT-2000 & PT-1800 power amps that I have set in bridge mode, one for each speaker and they are powering two Altec-Lansing 18" inch subs, one amp per speaker, no hiss, line noise or anything and the system kicks. I tried the Pyles on a whim because I got tired the trouble I was having with the QSC and Crown power amps, could not go a year without having something go wrong always sending back to dealer for some kind of fix! So now I have 2, QSCs, 2 Crowns & 4 Pyles driving my system
Apr 27, 2009 | Pyle PT-2000 Amplifier
Replacement parts for Pyle power amp PT-2000
VU meters are generally illuminated by small bulbs at the back of them. It's unlikely to be a powerfull bulb perhaps 12 volts perhaps around 200ma at the most. Most electrical shops should sell something that should suffice. It could be an LED though!
Apr 15, 2009 | Pyle PT-2000 Amplifier
Amp only runs on 1 channel til it is bridged tried 2 sets of rcas and still the same problem
Either the source isn't moving signal through stereo/both plugs, or the amp is damaged and will need repaired by an amplifier technician.
Jan 14, 2009 | Pyle 1800-Watt 2-Channel Bridgeable MOSFET...
Pyle amp
Hi Steve
You can use the amp stand alone. The remote connection turns the power amp on and off. I would connect it to +ve12v via a switch on the control panel of the boat. Turn on the switch when you want to use the amp. Good luck and happy punting!
regards
Graeme
Mar 06, 2008 | Audio Players & Recorders
167 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
