Question about HP Compaq Evo Notebook N1020v PC Notebook
I can't boot from external usb dvd/cd drive
Internal cd rom faulty
bios setup to boot
1 removable devices
2 cd rom drive
3 HD
  • seamillar Jan 28, 2009
    thanks
    i thought you might say that.
    will try.
  • Anonymous Mar 21, 2014
    Bios dell 1137 How to Setup boot from usb
    New Friend:
ENTER BIOS SETTING .... CHOSE BOOT ORDER AND SET IT TO YOU FAVOURITE DRIVE eg .cd rom, usb super disk
Posted on May 30, 2013
  • Niraj Sharma Jul 27, 2013
    But How to enter to the bios in MSI A6400?
  • 1,800 Answers
Please try to remove the connection between motherboard and vd/dvd drive.
then perform the previous steps.
Posted on Jan 27, 2009
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
My ASUS Z99E laptop cannot access winXP
Try to access the BIOS "F2" Key, Go to the BOOT Section, set the 1st Boot device to DVD / CD Rom. Press "F10" Save and Exit. If it fails again, re-enter the BIOS. Then make sure the drive is set to IDE and not ACHI. press "F10" save and exit the BIOS. If that fails then select in the BIOS Load Setup Defaults, and re-select the boot device to DVD/ CD Rom.
If all fails, you have to open the side or bottom cover to remove the HDD - Hard Disk Drive, Connect it to a Stand alone pc via the SATA Cable or External Device (Works as USB) then you can either do an emergencey back-up, Format the drive through windows.
Hope it helps
Mar 23, 2014 | ASUS Z99E COMPATIBLE LAPTOP LCD SCREEN 141...
Hi, I'm installing widows xp in HP Compaq nc6220, but after setup loading files the mesaage (bottom of setup screen) "Setup is starting windows", then it did'nt contiue the installation,...
1 many times the the CD cant load as the files in the CD are corrupt or the CD is not read by the drive corectly...so get a new WinXP CD
2 try an external CD drive if your BIOS alows to boot from USB drive....(connect the external CD drive to the USB and make necessary changes to the BIOS boot seq in the BIOS screen...
BIOS screen can be enabled by pressing the F1, or F2 or the Del key as on as you start the PC
3 once in BIOS screen look for boot seq and change the boot drive to the foll
1st boot device - USB CD / DVD rom drive
2nd boot device - internal CD rom drive
and so on
if you can do the above then try the WinXP installation using the external CD rom drive....
else there is a little complicated method of using a pen drive thru USB (will discuss that later) provided your BIOS alows booting from USB
for more PC related issues visit my website
reg
kris
suresh_krishnan1961@yahoo.com
www.sureshayyar.110mb.com
May 18, 2011 | HP Compaq nc6220 Notebook
Usb dvd writer can install xp?
Yes you can use a usb external cd/dvd-rom to any operating system as long as the bios allows you to, most bios's have the capability.
When the external usb drive has been connected power up the mechine, in post it should tell what to press to enter your boot menu without entering your bios and choose usb drive to boot.
Jan 22, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Trying to boot from external dvd drive
u must either have one of the foll...to boot and install OS...also the seq in BIOS must be availabe and enabled
1 Floppy
2 CD Rom Drive - internal
3 CD Rim Drive - External connected thru USB
4 You can also try to connect a USB pen drive having the OS install program and try - I have not tried that so not sure if this option works...sorry
5 If u can open the machine then u can connect another internal HD(this can contain ur OS install files) to the cable (connector points in the flat cable) that connect your internal HD to the Motherboard.
if i can think of anything else i will post
all the best
Dec 31, 2009 | Dell PowerEdge 2600 Server
My laptop won't boot from cd
to reset the BIOS, there is a small battery somewhere in your computer. if you unplug it for 3 seconds, it will reset the BIOS. I RECOMMEND THAT YOU DO NOT TRY THIS! get a service professional. If this doesn't work you might need to get a new laptop.
Dec 29, 2009 | Toshiba Satellite A105-S2712 Laptop
When my Maxtor basic External Hard Drive is conected my PC won't boot up.
Verify in the BIOS setup (usually accessible by pressing F2, F12, or Del at boot), "Boot Device" submenu, that the system isn't programmed to also boot from an external device. If it is, it will try to boot off the Maxtor, but won't be able to since there's no OS there.
The system should be configured to start off the internal hard disk, and optionally the CD-ROM. Other options (ROM BIOS, PXE, USB, etc.) are usually best left deactivated or at lowest priority.
Nov 17, 2009 | Maxtor BASICS Personal Storage 3200...
How to configure theh bios to boot to cd
when u power up the computer press "del" or F2 to enter in bios
then go t o boot option set first boot device as dvd drive then presss F10 then save all settings then it boot with dvd or cd
May 22, 2009 | Computers & Internet
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
HP Compaq Evo Notebook N1020v PC Notebook Logo
1,185 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
