Question about Car Audio & Video
NEED A WIRING DIAGRAM FOR PIONEER GM-42A - Car Audio & Video
  • 15 Answers
SOURCE: pioneer deh-p6800mp wiring
You can find the wiring diagram online in a PDF of the installation manual, which is at this location
Hope that helps!
Posted on Jan 14, 2008
happy_colors
SOURCE: Pioneer GM-232 Amp
amp%20specs%20001.jpg444bbca.jpgcc2af91.jpgthese are from the actual owners manuel-i used to have this amp also. hope these help
Posted on Dec 29, 2008
SOURCE: wiring diagram pioneer deh-3400
ce3d034.jpgh
ihave this for you
Posted on Feb 06, 2009
lostinfamily
  • 149 Answers
SOURCE: need wiring diagram for pioneer deh-p4000ub
http://akamaipix.crutchfield.com/Manuals/130/130DEHP4UB.PDF
Here is the PDF file for your radio. On page 63 is the start of the wiring diagram. I hope this helps. Please Rate this solution
Posted on May 20, 2009
etirbynnor
  • 655 Answers
SOURCE: wiring
Hello nootkabear,
Without the model number of your super tuner, it's not possible to point you to a specific location for the wiring diagram.
I'd start with Pioneer support to see if they have a download for the manual. If that fails, try the manualsonline site. Manualsonline is not a free site.
Hope this helps.
Posted on May 30, 2009
I need wiring for pioneer gm 3000 amp?
Here is the pinout. You need to solder your own connections.
Oct 15, 2014 | Pioneer Gm-3000t Car Amplifier
ON A PIONEER CAR UNIT MODEL AVHP49000DVD , I BOUGHT IT USED , THEN HAD TO BUY A POWER PLUG FROM PIONEER WITH A WIRING DIAGRAM , PUT IT IN MY 2006 GMC TRUCK WITH A FACTORY WIRING ADAPTER IT WILL NOT COME...
You will need to connect the pioneer unit to a switched ignition wire from the ignition switch. The 2006 GM factory radio only has a constant B+ (orange wire) and ground (black wire). The factory radio turns on when the Body Control Module (BCM) sends the radio a turn-on signal (on a data communication line) when the key is turned on. Your pioneer unit won't talk to the truck's BCM, and will need you to wire a switched B+ feed to it that turns on in the ignition accessory and run positions.
Aug 23, 2013 | Pioneer Avh-p4900dvd, Avhp4900dvd,...
Need a wiring diagram for a pioneer GM-840/UC amplifier
http://caraudio.manualsonline.com/ex/thread/view/idThread/2909343
Feb 10, 2010 | Car Audio & Video
Need the speaker wiring diagram for Pioneer KEH-1080
Yellow = +12V constant; Red = +12V switched; Black = ground; Blue-white = remote on; White/White-black = FL speaker; Grey/Grey-black = FR speaker; Green/Green-black = RL speaker; Violet/Violet-black = RR speaker.
--- hope that helps ya
May 20, 2009 | Pioneer Car Audio & Video
Amp dosnt work right
your amp cant handle the impedance of your subs i.e your running a 2ohm sub on a 4ohm amp!
Change the wiring on the sub so instead of running at 2ohm your run at 4
if you need to know how to wire up your sub to run at 4 then take a look at this wiring diagram
take a look at option 2
Click here
Hope this helps if so please dont forget to rate :)
Upfront Audio
Apr 13, 2009 | Pioneer GM-5100T Car Audio Amplifier
I need a wiring diagram for a Pioneer GM-A200 Amplifier
For a Pioneer GM-A200, pls use below wiring scheme:
  • Green & Green/Black - Left Speaker;
  • Gray & Gray/Black - Right Speaker;
  • Yellow - Illumination B+12;
  • Red - ACC B+12;
  • Orange - Always ON B+12;
  • Black - Ground/Chassis.
For the 8P INPUT DIN connector:
  • 1 - SWD +B;
  • 2 - Left Input
  • 3 - Audio Ground
  • 4 - Mute
  • 5 - Right Input
  • 6 - UN SWD +B
  • 7 - Illumination B+12
  • 8 - NC
  • Body - Ground
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 23, 2008 | Car Audio & Video
Wiring my tuner-DEH-1800 to Amp GM-5300-T into my 4 speaker system.
In most head units as in your case the Pioneer DEH-1800, there would be 2 RCA female jacks at the rear of the unit. These are your OUTPUTs.
While in most amps including your GM-5300-T, there would similar RCA jacks which would be your INPUTs.
You need to connect the output to the input using an audio cable terminated at both ends with RCA plugs. Further you need to connect the remote trigger on from the head unit to the remote/external amp to switch it on.
A more comprehensive connection diagram is available at page 6 of the GM-5300T Manual which may be downloaded from here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Nov 11, 2007 | Pioneer DEH-1800 CD Player
Instalation of a gm-x622
Trim God Hey Kell77. Go to this site if you have not already tried this. I found your amp but no manual. http://www.pioneerelectronics.com/pna/v3/pg/product/details/0,,2076_310069937_36965,00.html If that does not help, Google "Pioneer" and check out each site till you get what you need.I found the manual on this site,but it costs 9 bucks. Maybe you can get it for free if you search around a bit.http://www.tradebit.com/filedetail.php/824757. If you can't find a manual for your exact amp, download a manual for the same model type that is less or more powerful than yours. The wiring diagram for all the GM-X models might be the same. Just use your judgement and caution when wiring it up.
Oct 02, 2007 | Pioneer GM-X722 Car Audio Amplifier
Car Audio & Video Logo
301 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
