Question about Pool & Spa
HOW DO I SET THE TIMER ON A HURLCON VX7T POOL FILTER?
3 Suggested Answers
  • 22 Answers
SOURCE: 2010 Easy Set 2500 Gph Swimming Pool Filter Pump (): ok we have the 24 by 52 in intex metal frame pool ...
88 It is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process. On the filter set it to run atleast 1 hour longer than you SWS. set the timer on both at the same time.
Posted on Jun 17, 2010
maxcarson
  • 7627 Answers
SOURCE: hurlcon pool pump reset switch where is it??
If there is a reset it will be locater near the power inputs, could be beneath a cover. Try looking here:http://www.hayward-pool.com/pdf/manuals/NorthStar.pdf
Posted on Nov 04, 2012
My hurlcon CX 240 pool pump has good return pressure but very low suction from the pool and wont opperate the kreepy krawly, Do I need a new pump? Thanks. Richard
no
what you may have is a blocked outlet--filter --tap incorrectly set
good pressure but no suction indicates that the pump is pumping but the pumped water has nowhere to go
Jan 05, 2017 | Pool & Spa
I have a HURLCON RX280 Sand Filter, if I replace the sand how much new sand do I add & to reinstall do I then fill up with water?
fill to the correct level as in the user manual
no need to fill with water as that will happen when you turn on the pump
Sep 29, 2016 | Pool & Spa
How do I service valve selector on hurlcon sand filter
they have a big spring in them, so with 2 big C clamps you can compress the spring to get it apart to service, warning use safety glasses for every one involved !!! if you break a tooth, oh well, but if you lose a eye that's a problem.
you might want to see if your local pool pump motor repair guy or pool supply can service it for you, just take them the valve from the filter and ask.
jay the pool pump motor repair guy in longwood florida .. give me a review if'n I was of help.
Oct 05, 2014 | Pool & Spa
Hurlcon ctx 2hp pump troubleshoot
maqke sure the intake union is tight also check to see if seal slipped use filter lube
Jul 02, 2014 | Pool & Spa
How to set Timer
need to set timer on hurlcon
Jan 14, 2014 | Hardware & Accessories
Hurlcon pool pump reset switch where is it??
Nov 04, 2012 | Hayward 2HP Pool Pump Motor A O Smith...
My low salt light on my Hurlcon vx7t salt chlorinator keeps comming on.How do i adjust it?
A low salt level warning is indicated on your VX Chlorinator if the salt level drops. If Low Salt is indicated, check again in 24 hours and then if it is still indicated, add two 25kg bags of salt to the shallow end of your pool. Run the filtration system for approx. 6 hours to help mix the salt in the pool. It can take up to a day for the salt to fully dissolve.
If the low salt light is still on, then you should get your pool water tested. If the Salinity is above 4000ppm then you may need to have your Chlorinator checked.
Warning: Some people recommend that you put salt directly in the skimmer box. This is a very bad practice as it allows very high concentrations of salt to be passed through your filtration and other pool equipment.
Hope this helps.
Jul 06, 2011 | Grilling
May 18, 2010 | Intex 2010 Easy Set 2500 Gph Swimming Pool...
Pool & Spa Logo
347 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
