Question about Sanyo DP26746 26 in. LCD Television
Screen is green there is no red color, red colors look gray
Bought the TV 3 years ago everything was fine until yesterday - there is no red color, it's all green
Sanyo DP26746 model
  • jackiwolf Mar 22, 2009
    TV was perfect until I hooked up to Dish HDTV. Only colors now are blue, sickly green, grey, black.
SOURCE: Sanyo DP26746 - 26" LCD TV
USER GUIDE
Posted on Nov 04, 2007
  • 1779 Answers
SOURCE: where can i get a screen for a sonyo dp26746 ?
Sanyo Manufacturing Corp. 1-870-633-5038
Posted on Oct 14, 2009
newrd1
  • 185 Answers
SOURCE: sanyo HDTV Model # HT27744
its the chip
try to open and clear contacts with clean dry sprey
if that wont work
ask a mechannich
Posted on Oct 20, 2009
  • 12 Answers
SOURCE: 3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Posted on Dec 16, 2009
Testimonial: "while we did not unplug the set, we let it sit for 2 days and we were able to turn it on by the remote & manually....does that still sound like P/S"
maatmartin7
  • 1213 Answers
SOURCE: I had my Emerson Tv
With the original remote. Press cursor button up followed by cursor down. Power off TV. This should return your TV back.
Posted on Mar 11, 2011
Picture red can not fix
Step 1:
The problem you have is the grayscale tracking needs to be reset.
First, This looks like a philips tv. In order to set the grayscale tracking remove the back of the set. There should be rectangular shaped box that is marked screen and focus on it with 6 knobs coming out of it.
Step 2:
NOTE: DO NOT TOUCH ANYTHING INSIDE THE SET-YOU WITH BE SHOCKED! WITH THE TV TURNED ON, WITH THE REMOTE, TURN DOWN THE COLOR TO ZERO. ON THE CONTROLS I PREVIOUSLY MMENTIONED, THERE ARE RED,GREEN AND BLUE ADJUSTMENT POTS.
Step 3:
TRY TURNING DOWN THE RED UNTIL YOU SEE A NORMAL GRAY PICTURE. YOU MAY HAVE TO ADD MORE GREEN OR BLUE AS NEEDED. IF THIS DOESNT LOOK RIGHT ,TURN ALL 3 R.G ANDB ALL THE WAY DOWN, THEN ADJUST THEM UNTIL THE COLOR IS JUST APPEARING ON THE SCREEN, MAKE THE PICTURE AS GRAY AS POSSIBLE. iF THIS DOESNT WORK,YOU WILL NEED A SERVICE PERSON TO REPAIR YOUR TV.
Jan 20, 2013 | Televison & Video
I have a 42" Hitachi HDTV Model Number 43UWX10B which I bought 12 years ago. I was having problems with the color about 2 years ago, and replaced the part, but now I am having similar problems where...
Over time a thin layer of fungi grows over the top of your BLUE CRT preventing light fronm shining through. This causes you to loose the blue color in your set. Check and clean. Also when the back is off your set check to see if your blue CRT is on. If not you may need to replace it.
Aug 14, 2010 | Hitachi 42V710 42" Rear Projection HDTV
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
Apr 12, 2010 | RCA P52926 52" Rear Projection Television
Hitachi Projection Color TV 43FWX20B - COLOR OFF
Check all cables,replaced all cables if more than couple years old.After that the same,ur tv have one dead color gun,require service.
Jan 01, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Convergence issue-60 inch RCA projetion TV
it is under set up options in the menu
Oct 16, 2009 | Televison & Video
No blue color on tv screen
Your welcome ! please comment. Thank you !
May 01, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Xbox 360 problem
If you can still HEAR sound, but can't see. Check your Audio Video Cable.
It's the colorful one (red, white, yellow) (red, blue green, white, red)
Make sure the connections are secure into the back of the TV as well as the connection to the back of the Xbox 360.
Jul 18, 2008 | Microsoft Xbox 360 Console
Picture color
I discovered that the red input from my DISH receiver had come loose. I plugged it in and all is well.
Certainly glad I didn't call a technician out!
Feb 11, 2008 | Panasonic PT-65WX51 65" Rear Projection...
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Toshiba 65hx81 65" Rear Projection tv. black & white color/green
Yep, your problem is a relatively easy one to repair if you know how to solder. You better repair it before it blows the fuse though. There are two capacitors in the main power supply that are coming loose and need to be re soldered. There is a Toshiba service bulletin about it. They are marked C809 and C810 on the main power supply board. Good Luck
Sep 05, 2007 | Toshiba 65HX81 65" Rear Projection...
Sanyo DP26746 26 in. LCD Television Logo
64 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
