Question about Vizio SV421XVT 42 in. LCD TV
Sv420xvt1a stand screws - Vizio SV421XVT 42 in. LCD TV
Vizio LCD SV420XVT1A-has a red screen when starting then red bleeding through dark
Got to go to settings to change the color of your tv screen and see if that helps
Jan 23, 2015 | Vizio Televison & Video
Red pixels on vizio tv model sv420xvt1a
A picture or video would be great
Jan 13, 2013 | Vizio 42 in. LCD TV
I have a: Vizio SV420XVT1A.... The TV dont turn on!!... The logo light is off and have a sound like a beep beep and a red light blink a number 5.1 in the bottom of the TV
The main digital board to your TV should be troubleshooted. If it found faulty, there is no other way than replace it as card basis. There is no repair to these boards. Very like computer motherboards.
Oct 27, 2012 | Vizio New Original SV420XVT1A Remote...
Model Vizio SV420XVT1A will not power up. The Vizio logo is amber, nothing happens when you press the power button.
You will need to have the set diagnosed as there a number of things could cause this. But I would say you're looking at a power supply or main board problem. It is also possible that your key controller (side buttons) is defective. I take it the TV doesn't turn on with a remote either?
Sep 09, 2012 | Televison & Video
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
The Swivel Mount TV Stand I just purcahsed didn't come with TV mount screws. My TV is a 50" Panasonic Viera TC- P50U2, what size screws do I need
There are different types of stands as well as the screws vary. It is by the exact type of stand we can provide a screw size.
Another solution is for you to try to reach the dealer that supplied the TV stand to you, so as to get the exact screws that came with the stand.
Take care and good luck
Dec 03, 2010 | Televison & Video
I have an opportunity to buy a Vizio Model SV420XVT1A television that has cracked screen for $100.00. How do I repair something like this or is it even worth the effort?
My suggestion would be not to buy it since the screen is the most expensive part of the TV and is not repairable unless is replaced. The price for a new screen it might exceed the price of a new TV.
Sep 29, 2010 | Televison & Video
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
May 26, 2009 | LG 42LG30 42 in. LCD HDTV
Vizio SV421XVT 42 in. LCD TV Logo
159 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
