Question about Garden
Where can I get a muffler for stihl P835 gasoline water pump?
My stihl fs400 strimmer starts first time and runs on full throttle then dies a few moments later starts first time and does ame thing again
inside the muffler there is a screen that gets all gummed up, take muffler assy. apart and clean screen, if you have a propane torch, this works well as you burn crud off it becomes ash and wipes or blows off. first link shows how.
press the helpful button and follow me on fixya
Easy Repair on STIHL FS38 Grass Trimmer Clogged Spark Arrester
how to fix stihl trimmer
STIHL GAS TRIMMER REPAIR Stihl FS 40 Grass Trimmer RAN NO OIL IN GAS blown...
How to fix bogging out grass trimmer with clogged spark arrester
Feb 03, 2016 | Stihl Garden
Why would water be in muffler
Burning gasoline generates some water. When your truck is cold, that water condenses in the muffler. Normal.
Sep 01, 2014 | 2005 Ford F-150
I can't get my blower to accelerate. It will only idol on full choke. If you pull trigger it bogs down. I replaced the fuel line and sprayed carb out.
Check the following, and then clean or replace:
  • Fuel Filter - Located INSIDE the Fuel Tank
  • Spark Plug
  • Spark Arrestor - at muffler
  • Carburetor - May need a rebuild kit
Watch this as well...
and...
Oct 18, 2013 | Stihl Bg 55
Stihl saw runs but won't idle.
The paper pumps get stiff and do not pump fuel very well. It's the new Ethanol gas that is the Carb Killers. You need a rebuild kit not just disassemble and clean.
You have IDLE ADJUST Low Speed adjust and High speed adjust. Low and High speed adjust have nothing to do with Idle.
Oct 11, 2012 | Stihl 044 046 Ms440 Chainsaw Muffler
How do I gap ignition module on a TS350 Stihl concrete saw?
I thought the unit was under the flywheel, in this case there is no gap to set it just screws to the crankcase and you re fit the flywheel.
Sep 18, 2012 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
What gas to use for TS350
Gasoline cut-off saws are a simple and extremely robust tool that will easily last for many years if treated with respect and maintained regularly .
During normal operation it is absolutely imperative that the correct fuel/oil mix is always used. An incorrect mixture leading to a lack of lubrication is by far the easiest way to ensure an untimely death for your cut-off saw.
Here's a list of regular cut-off saw maintenance tips that will keep your machine running and running:
Jul 20, 2011 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
My stihl ts 760 , no gas going to carb. I have changed all filter , fuel, air, all gaskets , all gas hoses, new decompression valve, plug, cleaned carb. was working before this . Any ideas?
Clean it again you missed something or maybe a gasket is on wrong. If you went through all of that it should run fine. Stihl usually rebuilds and runs well. Slow down turbo maybe you got a little ahead of yourself. Good Luck...
Apr 02, 2011 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
Water is coming out from my tail exhaust pipe Ford Expedition 2003 4X4
When gasoline is burnt the products are carbon dioxide and water:- 2C8H18 (gasoline) + 25O2 (air) ----------> 18H2O (water) + 16CO2 (carbon dioxide) If you take short trips the water content will condense in the cold exhaust pipe and collect in the muffler boxes (silencers). At a certain point the water will fill the mufflers, overflow and begin to dribble out of the exhaust tail pipe. It is worthwhile to occasionally give your car a longer run to allow the exhaust to become sufficiently hot and to evaporate all the collected water. The water is acidic and hastens the corrosion of the exhaust pipes.
Dec 06, 2010 | Ford Expedition Cars & Trucks
Does carb work under crankcase pressure cause petrol coming out of carb when engine stopped,
If the unit is leaking fuel out of the carburetor when the unit is not in use then it is usually the needle sticking open. This can be from a piece of grass or other debris getting under the needle and keeping it open. Alternatively it could be a bad diaphragm that is leaning on the needle and keeping it open.
As always it is recommended that you take the unit to a Stihl dealer with a Gold Certified Technician for parts and repairs.
Nov 06, 2010 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
