Question about Sewing Machines
Mezzo sewing machine esm008 Thread stuck under the sewing area
5 Suggested Answers
manski
  • 15 Answers
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
Posted on Dec 10, 2007
SOURCE: bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Posted on Jan 23, 2009
  • 97 Answers
SOURCE: my thread gets stuck down in the bobbin area.
Ensure that you are threaded correctly, set your tension for roughly 4.5 and "floss" your machine when threading by grabbing the thread by the needle immediately prior to threading the needle with your left hand, and the thread on the top by the spool with your right hand; then pull the thread back and forth briefly.
Ensure that your bobbin is in the bobbin case in the correct orientation.
Ensure that your feed dogs are in the "up" position. Many inexpensive machines do not have the option to drop the feed dogs, and I believe your kenmore to be one that lacks the option, but consult your manual just to be sure.
Also make sure you're using a good quality thread. Use a European thread, and definitely avoid anything from the dollar bin or any kind of "dual duty" type thread. Cheap thread causes nasty nasty things to happen to sewing machines.
If none of these fixes solves your problem, let me know; but going through the above will solve 99% of problems like you're describing.
Good luck,
-R
Posted on Mar 11, 2009
SOURCE: Sew Cute SC20 Mechanical Sewing Machine: how to thread sew cute machine ...
Place the origin bobbin thread so the thread is coming up (clockwise) extend to the thread tention, to the top thread holder, then down through the arm and then through the bottom thread holder, through the square thread guide above the needle, then through the needle, front to back. Check out a picture on ebay or amazon. That could help you visualize it.
If you are having trouble with the thread breaking, try changing the thread on the bobbins. The thread that comes with the machine is poor quality and jams & breaks. If you still have trouble, and might suspect the needle is dull or bent. Change it, it makes a difference. I had the thread problem with the machine right out of the box. Changed it and it works great!
Posted on May 22, 2010
Sewing machine hand wheel won't turn. Fabric is stuck under needle. How do I fix this?
Mine has only done this when the machine has jammed with thread form the bobbin and the top thread not being threaded properly in machine or the machine is dirty and needs to be brushed to remove all the fuzz from sewing. Pull the pressure foot off of the machine. Use a seam ripper and carefully cut the threads that are wrapped all around it. Once it is loose, take it off of the machine, then you will be able to pull your bobbin from the machine and trim all the thread that is wrapped around it. Then use a toothbrush or sewing machine brush and clean your bobbin area of your machine with the brush and try it again.
Feb 28, 2015 | Singer Sewing Machines
WHY IS MY THREAD WRAPPING AROUND THE BOBBING IN THE SHUTTLE WHEN I PRESS START
THE BOBBIN HAS ONE METAL PART ON TOP AND ANOTHER PART THAT KEEPS THE BOBBIN FROM MOVING FORWARD. TURN YOUR HAND WHEEL AND WATCH WHICH PLACE DOES THE THREAD GET STUCK. IF IT IS THE ONE ON TOP THEN IT WILL NEED TO BE RAISED SLIGHTLY BY MAKING A PULL WITH NEEDLE NOSE PLIERS. (VERY SLIGHT) IF IT GOES UNDER IT BUT STOPS AT THE AREA WHERE THE LITTLE INDENTATION IS THEN YOU WILL NEED TO LOOSEN ONE OF THE SCREWS AND SLIGHTLY TO ALLOW THE THREAD TO PASS BY. THE THREAD HAS GOT TO PASS THESE AREAS OR YOU WILL NOT SEW.
Nov 11, 2014 | Brother Disney PE-180D Computerized Sewing...
My sewing machine does not move at all
Is the bobbin winder on? If so, turn it off.
Otherwise, is there power to the machine?
And this happened while you were sewing? Cut the thread above the needle eye. Rock the handwheel back and forth firmly to try to cut the thread jam below the needle plate with the sewing hook. If that doesn't work, open the bobbin case area of the machine and try to pull the bobbin case out, cutting any threads you can see with a seam ripper. Still won't come? Take the needle out of the needle clamp and throw it away (it's bent!), and take the screws out of the needle plate (=throat plate) and take the needle plate off after cutting any threads you can reach under the fabric. Keep cutting and pulling out any thread you find, and eventually, you'll be able to turn the handwheel. Clean all the thread bits, lint, and junk out of the area under the needle plate, the bobbin and bobbin case, and the shuttle area... there will be directions in your manual on how to clean the machine, including the shuttle area. Reassemble. Put in a brand new needle, right way around and fully up in the needle clamp. Rethread from scratch.
Always hold the thread ends behind the presser foot for the first couple of stitches of each seam.
See also: http://www.picturetrail.com/sfx/album/view/22521551
Feb 05, 2014 | Brother LS-2125 Mechanical Sewing Machine
I have white D'Lite 1750C the bobbin thread is
try these suggestions
change the needle--use needle according fabric being sewed
rethread the machine top & bobbin
clean under needle plate & in bobbin area for lint or threads
make sure the bobbin is not warped or damaged
make sure the bobbin case is not damaged
if none of these suggestions help, then I suggest having the machine checked
to see if there is something wrong with the inside parts
May 31, 2012 | White Sewing Sewing Machines
LS-1520 Brother sewing machine hook pick thread up takes it around half way and gets stuck...any ideas. the timing seems to be right??!!
try changing needles
clean under the needle plate & in the bobbin area for loose thread or lint
make sure the bobbin is inserted into the bobbin case correctly--if the
machine won't pick the thread up from the bobbin correctly take the bobbin
out of the case & turn it around & try it that way.
Apr 13, 2012 | Brother LS-1520 Mechanical Sewing Machine
I am looking for a manual or anything that can tell me about my sewing machine it is a mezzo sewing machine model ESM-008
There is a general manual for Mezzo sewing machines available at http://ernie.awa.com.au/default.aspx?ArticleID=1568&UserSort=strFileDescription&UserSortDir=DESC&pg=2. There's also one available for the ESM-007 at the same page. I'd suggest downloading both of those, and they should be able to give you quite a bit of information that will help you with your machine.
May 10, 2011 | Sewing Machines
When I try to sew, the thread on the bottom of my fabric gets all bunched up. Sometimes the needle gets stuck. This happens all the time. I re- thread the whole machine, but it always eventually happens...
put a new needle in the machine
clean under the needle plate in the feed dog area for lint
also clean in the bobbin area for lint & loose threads
keep a check on the thread take up lever,, because when the thread comes off the thread take up lever it will build up thread under the fabric & can jam up the sewing machine
Nov 17, 2010 | Elna 1010
Thread keeps getting stuck in bobbin holder area
Unthread your machine, clean out the bobbin area and brush it, then totally rethread your machine. Make sure that there are no tangles in your thread. Try that, good luck
Sep 20, 2010 | Janome Memory Craft 4900QC Mechanical...
Thread jamming under fabric
bobbins in backwards
flip it over
Dec 18, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
144 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
