Question about Sony BP-U60 Lithium-Ion Battery BP-U60
My sony bp-u60 battery is blinking & not charging
I just leave my battery for 25 days not work in use & don't charge in present that battery is blinking & not charging plz suggest
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
Bat collapsed change it.
Posted on Jan 24, 2013
Why wont my nookhd wont charge
If it\'s only two months old it may have a defective charging cable or adapter. If it\'s a new purchase and you can return it. To check to see if it might be the adapter and not the charging cable you have a few cheap ways to test this out.
General charging recommendations.
If you get power leave it on charge at least 3+ hours. This is the minimum time required if the battery is totally drained. If the Nook turns itself on during this process manually turn it off. The battery charges faster and more deeply if it\'s truely powered down. Charging more than 3 hours won\'t hurt it. In fact some manufacturers claim leaving thier products on charge for an additional hour after the charging light glows green is good as it leaves a slightly deeper charge on the battery. Also I believe leaving it alone for that hour allows it to cool the battery. Most manufacturers also recommend tottaly draining the battery at least once a month and then fully recharging it 1+ hours after charging light is green. They claim this helps the battery maintain a healthy charge and extends the battery life. Simply disconnect any charging cables, turn the unit on and just let it set. Don\'t touch it peroid just leave it alone until it turns off because the battery is totally drained. Then just plug it in and leave it. Only if the unit automatically turns itself on do you manually turn it back off.
Well that\'s about in in keeping the battery life and charge at its maximum.
If your AC power adapter has gone south there are only three ways to get around this. 1. Purchase a generic AC to USB adapter. 2. Purchase a genetic DC to USB adapter. Most of these can be cheaply purchased at most drug stores ect.. these days. You can even get DC to USB ones at dollar stores such as Dollar Tree. Good way to maintain your battery if your AC one goes south or you lose house current.
One other way to charge your battery is to plug the USB cable into your computer. Some manufacturers don\'t recommend this as this more often than not doesn\'t fully tank up your battery.
You can also get replacement charging cables at the same place you got the adapters. Places such as Walgreens, or CVS often have these at around five dollars a pop.
Apr 26, 2014 | NOOK HD 7 Tablet
Sony Ericsson K550 Cyber-shot battery error then wont read sim card
Hello, Tammy, according to your explanation it looks like your device started problem after one week of charging error, if charging pin is same of your device and your brother there is no problem charging with it, for the charging error it must be happened when you didn't connect charger properly. try your device with another battery if possible, for the switching on and off it sounds me software issue, try to connect your device to pc suite and update firmware your problem will be solved. for further help post comments.
Jul 05, 2012 | Cell Phones
I'm using a "ACER aspire
There should not be a problem provided the notebook is used with the battery on occasions and charged up again when the battery level drops to approx. 25% level.
Jun 15, 2011 | Acer Aspire 5742Z-4200 Notebook
My dsi is not charging the battery light is blinking and it will not turn on
this is either a battery, DS, or charger issue. it is recommended to try charging with a different cable, one that you know for sure works. if it successfully charges then it is a problem with your charger, i recomend you buy a new one. if it still will not charge, the problem will either be your DS or battery. your DS's wiring may have been cut loose internally, or the battery can no longer hold a charge or is malfunctioning. if you have used the battery for an extensive amount of time it will slowly lose its ability to hold an electric charge. this loss of charge can also be caused by leaving the battery drained for a large amount of time. if you have concluded that the problem is your battery, you may order a new battery from nintendo. dsi here http://store.nintendo.com/webapp/wcs/stores/servlet/ProductDisplay?productId=150208&currency=USD&catalogId=10001&tranId=0&lastAction=setCurr&storeId=10001&languageId=-1&categoryId=66209&ddkey=http:SetCurrencyPreference and dsi xl herehttp://store.nintendo.com/webapp/wcs/stores/servlet/ProductDisplay?productId=167217&currency=USD&catalogId=10001&tranId=0&lastAction=setCurr&storeId=10001&languageId=-1&categoryId=66716&ddkey=http:SetCurrencyPreference
May 10, 2011 | Video Game Consoles & Games
It appears that my battery for these headphones doesn't hold it's charge....It's hardly been used Battery type.....BP HP550-11 for headphones Serial No MDR RF 840RK
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make the charging cradle work with the new batteries installed in the Sony headset you MUST use the bottom part of the plastic battery holder piece on the BP-HP550-11 battery pack (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism inside the headset to enable the cradle charger to charge the batteries.
NOTE: I am not an electronics expert so I do not know if there would be any problem using other rechargeable AAA batteries (with higher mAh ratings). So I decided to be safe than sorry and ordered the 550 mAh batteries through Ebay.
Dec 03, 2010 | Sony MDR-RF960RK Consumer Headset
I'm nokia E63 user. Battary of this phone ( BP-4L) does not give back up for a day after full charging. Today when i got up in morning i touched my phone and found it overheated. I brought this phone in...
you should replace your battery
or
take the battery out and leave it out for an hour atleast, give your phone and battery little rest then use again.
remember never ever over recharge your battery. two hours are more than enough. and always swtich your phone off when you are charging it.
Nov 10, 2010 | Nokia BP-4L Battery
I need a new battery (BP-HP550-1 1/2.4V 550mAh) for my sony headset. Regular batteries will work (non-rechargeables and rechargeables) but I found that the cradle will not recharge the rechargables only...
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make them work in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
Nov 01, 2010 | Sony MDR-RF960RK Consumer Headset
Sony batteries BP-HP550
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make the charging cradle work with the new batteries in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
Jul 27, 2010 | Sony MDR-RF960RK Consumer Headset
Where can i buy a sony battery bp-hp550 1 1/2 4v
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make the charging cradle work with the new batteries installed in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
Jul 11, 2010 | Sony MDR-RF960RK Consumer Headset
Sony BP-U60 Lithium-Ion Battery BP-U60 Logo
771 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
