1967 Rowe Ami MM1 only selects A sides but not B sides?
In the process of buying this jukebox and was shown in a video that the a side works when selected but not the b sides of the records. Any idea's
2 Suggested Answers
SOURCE: Hi' I have just got a rowe ami r-83 disco jukebox.
you need to check the Home signal to make sure the opto is activated at position 99. When the unit powers up the mechanism scans one complete cycle so it re-indexes the computer and starts scanning from position 00. If you want a quick test, turn the power off and scan the carousel to position 99 by releasing the latch on the left side of the mech just under and behind the mechanism motor. then power up the unit and it should pick the right selection. You can also observe the optic indicators on the mechanism control board under the turntable. The Home signal only operates at 99, the Index pulses between each record as it scans. Good Luck
Posted on Dec 02, 2010
Selections already made on jukebox, how do I clear them
Hello stillwell42,
What model is your Rowe Ami jukebox, there will be an information label on the back or inside the jukebox with the serial number and the model type. We can suggest a solution once we know your model type.
Regards
Alan
Alan Hood
ami-man
UK
Mar 13, 2015 | Audio Players & Recorders
Rowe Ami Jukebox buttons do not unleash
Hello Pedro,
You need to unlock the top door of the jukebox so you can operate the catches to get to the keyboard. The open relays R1 & R5 which are normally under a plastic cover, the open contacts on these relays need cleaning. Do not use any form of switch cleaner, just make a paper taper and pull this through the contacts to clean the contact tips.
Regards
Alan
ami-man
UK
Feb 24, 2014 | Wurlitzer Jukebox 1015 One More Time...
We just bought a 1974 ami, plugged it in and it pl...
If your Rowe Ami is indeed a 1974 model it will be a TI-2 or CTI-1 (chest style jukebox) this era of jukebox uses a search unit to push out selected pins on the unit A side and B side for the mechanism to search for and play.
If the search unit is pushing out the correct pins but the mechanism is not scanning to select those selections, it could be that the mechanism is skipping over the pins or it could be that the search unit is not pushing out any pins at all with the search unit motor just spinning around.
If you are in the UK then I could help you.
If you are in the USA try posting a request for help on www.phonoland.com or on www.collectingbanter.com
Regards
Alan Hood
ami-man
UK
alan-hood@datex.co.uk
May 20, 2010 | Vintage Jukebox External Speakers Shelf...
I have a 1979 rowe ami jukebox model R65 when i switch it on it plays one record then just spins the record magazine and wont select another record what parts do i need .
Hello Gary,
If your jukebox is ineed a 1979 model it would be a R-83 Fiesta, Claremont or Disco. These jukeboxes curved top to bottom.
I think your jukebox may be the 1981 R-85 Starwood, Starburst or Starlight.
If your jukebox is from the 1979 era upwards then it will be electronically controlled.
You need to send in your boards to a Rowe Ami specialist in the USA you would contact :-
Bruce Wentworth A&B Jukebox Repair 56 Old County Rd. Plaistow NH 03865. A&B Jukebox Repair specializes in the repair of Rowe circuit boards in Rowe ...
www.abjukeboxrepair.com
In the UK contact me
Alan Hood
ami-man
Games Unlimited & Datex Systems
Units 4 & 5 Lion Park
New Street
Halfway
Sheffield
S20 3GH
0114 247 0242 phone
0114 251 0727 fax
Mar 01, 2010 | Vintage Jukebox External Speakers Shelf...
Looking for a spare plastic piece for a Wurtlizer 1015 One More
Hello Belinda,
Check out www.victoryglass.com for spare parts for your one more time jukebox. Make sure that yours is Wurlitzer and not a Rowe Ami, Rock Ola or Antique Apperatus (they were a subsidiary of Rock Ola but used Rowe Ami parts).
Also in the UK Sound Leisure made the one more time.
Regards
Alan Hood
ami-man
UK
Feb 11, 2010 | Wurlitzer Jukebox 1015 One More Time...
Rowe Ami R-80 imperial jukebox
Hello Andy,
Yes I know the 1976 Rowe Ami R-80 jukebox very well as well as most of the other Rowe Ami jukeboxes.
The turntable motor and the lighting work off of the 110 volt output from the power supply.
The other power voltages are connected to the power supply via the molex plug.
Pin 1 30VDC white/red
Pin 2 30VAC yellow/black
Pin 3 Common black
Pin 4 Ground gren/yellow
Pin 5 No connection
Pin 6 Common black
All the voltages are protected by circuit breakers.
I assume that you may be in the UK if this is the case here are my contact details.
Alan Hood (ami-man)
New Street
Halfway
Sheffield
S20 3GH
0114 247 0242 phone
0114 251 0727 fax
Jan 20, 2010 | Vintage Jukebox External Speakers Shelf...
I have rowe ami jukebox Eagle Laser Star and its amp seems to be dead sin have no sound justa a buzz. Need to find one or how to repair it.
CALL AB JUKEBOX SERVICE--ASK FOR BRUCE--TELL HIM LES FROM RMC VENDING SUGGESTED YOU CALL HIM.-
603-382-6272
Apr 27, 2009 | Wurlitzer Jukebox CD Player
Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
Jan 05, 2009 | Wurlitzer Jukebox CD Player
Rowe ami jukebox
Check the optical sensor, it may be blocked with dust.
Jun 09, 2008 | Audio Players & Recorders
Rowe jukebox
I take it that the jukebox accepts selections when you type them in. Also that you have tried selecting the A side and the B side records.
Is the switch on the CCC (Central Control Computer) set to Record it should not be set to Video.
Rowe Ami jukeboxes are very pone to dry (cold in the USA) joints.
If you can solder then the following items need to checked for dry joints.
Power Supply PCB (printed circuit board)
CCC
Mechanism Control Board
When taking out the plugs pull on the plugs (not the wires)
Look on the soldered side where the connectors pins are fitted for any cracking around the soldered joint ( this is the sign of a dry joint).
Resolder any suspect joints on all of the boards and refit into the jukebox and test.
If this does not cure the problem then the boards will be needed to be sent to a Rowe Ami specalist, I am one of these in the UK.
Regards
Alan Hood
ami-man
UK
May 30, 2008 | Wurlitzer Jukebox 1015 One More Time...
64 people viewed this question
 Grubhead
Grubhead
