Dynex DX-40L260A12 Logo
A
Anonymous Posted on Jan 23, 2013
The color went off of tv while watching tv and now it is just black and white picture, how do I get the color back on the tv?
4answers
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Color went to black and white
You have it hooked up to Analog TV with your RCA jacks. I had the same problem.
Philips 60PP9200D went black and white.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixelation ,black and white picture,even vertical lines.You will need to replace the light engine. Have a blessed one!
RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Black and White picture when watching TV
Check color syestem of tv,select Auto
1helpful
TV Picture is tinted pink
depending on how much you paid for the tv , the cost of the repair may be more than the tv is worth. but if this is a large tv , then the repair would be most likely worth it
3helpful
2answers
Have a polaroid tv, model 3700 seriel F0600181940001053. WATCHING THE OTHER NITE AND A LOUD SQUEAL CAME ON AND THE PICTURE WENT OUT, TURN IT BACK ON TODAY AND THE SQUEAL IS STILL THERE WITH NO PICTURE..NO...
I have a flat screen polaroid lcd hdtv model 3700, first the sound started to get really loud with a beeeeeeeeep when we turned on and after a while was gone, now it doesnt! we had to put mute and connect the tv to a sorround system to hear it without that crazy noise, and now the colors of the tv are gone too its just black and white when we try to see the dish satelite but if we put a movie on the dvd player colors are perfect we try to conect the ps3 player too but its black and white too. Help what can it be!!!!????
2answers
Picture.....
I'd still pick plasma , because it has true black where LCD does not.
better for gamming by a long shot.
can you say WARRENTY :->
7helpful
4answers
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Top Dynex Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Jesse Walters
Jesse Walters
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
