Question about Kenwood KDC-X692 Car CD/ MP3 Player
Volume turned up, kenwood shuts off briefly...
My kenwood will work fine until I turn the volume up. Then it shuts off completely and then turns back on again..This continues on again and off again. I have checked ground wires, loose wires, connections, disconnected amp., checked fuses, still same thing happens with or without the amp connected or with or without the speakers connected. The CD player is installed in a boat with a 400 watt amp and blaupunkt speakers. I've noticed the stereo gets hot to the touch towards the top in the back. Any suggestion? I have a Kenwood KDC-X692 with new Kenwood speakers, no amp. When I turn the volume up to 25 the radio shuts off, turns back on and I don't understand why? My speakers aren't bolted completely down and they are saying that is why. I've never heard of such a thing. Could this be the reason? Or why would this happen? Thanks
  • montezmaria Jan 28, 2009
    When I took it in they said the wires were connected incorrectly and stated "they" said they reconnected them correctly, but I wonder since I didn't pay them to hook them up. I had gone in thinking it was the radio. I'll look into that. They say it's because I haven't bolted the speakers down real good yet and that could be causing it when I turn up the volume which makes no sense to me. I really appreciate your response. Thanks so much.
  • Anonymous Apr 14, 2009
    I went in because mine was doing the same thing. But my front wires were connected to the rear. & the rear to the front. Instead of them admitting the mistake. they said I had a bad radio & to send it back 2 Kenwood. IDK if the wirin had something to do with the radio working, though.
Does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
Posted on Jan 28, 2009
What's your problem?Kenwood kac-6295 shuts off then turns back on at high volumes
You got a (Problem) I have never heard of a amp doing that, In the 40 pus years, That i was a certified electronc technician, But like they stay you learn something new everry day,
Nov 06, 2012 | Car Audio & Video
I have a kenwood kac-9152d amplifer and it works just fine for about 10 minutes then just shuts off and subs dont work, about 30 seconds later my amp turns back on with the subs.
make sure it's well ventilated. If there's no air flow, then there is no way of cooling down and to protect itself it will shut off. Make sure the speakers are wired correctly as per amp specs. too many subs or subs connected improperly can draw too much current and shut the amp off, but you will notice this when you turn up the volume to a certain point and the amp shuts down.
Aug 30, 2011 | Kenwood KAC-9152D Car Audio Amplifier
My kenwood vr615 reciever had the volume turned up, unit shut down and now when it gets to a certain volume that is much lower than normal it will turn off and the stand-by light will flash, I have to turn...
hello ,i strongly suspect the units protect circuit is sensing a speaker problem.Listen to each speaker to see if all the drivers(woofer,midrange,tweeter) are working and if so are any of them sounding distorted.When an amp is damaged it wont play at all,sounds like a bad speaker to me.
Jan 09, 2011 | Kenwood VR615 Receiver
When adjusting the sound, we lose sound completely. The volume knob on the receiver does nothing. If we play with buttons on the receiver, sometimes it comes back. The second last time it happened, I shut...
I would try and clean your switches and controls before giving up on the receiver. use de-ox-id contact cleaner on the volume control and switches. Larry's Electronics
Apr 27, 2010 | Kenwood VR-7070 Receiver
Kenwood new sterio shuts off when turning up volume
You may have a short in a speaker. Check to see that the wire terminals on the speaker itself aren't touching any metal. Even 1 terminal touching metal will cause issues. Hope this helps.
Larry T
Winona Lake, IN
Jan 27, 2009 | Kenwood KDC-X692 Car CD/ MP3 Player
My kenwood amplifier suddenly off when i turn the volume high?
You need to make sure you ohms are correct if there too low this will happen to protect the amp.
Dec 03, 2008 | Kenwood KR-V7080 Receiver
Usb/ipod-no sound
Sounds stupid but did you turn up volume on ipod?
Aug 04, 2008 | Car Audio & Video
Kenwood KAC-9152D monoblock
The amp says it's 1 ohm stable, so assuming the DVCs are dual 4 ohm, you should be able to connect all "+"'s together and all "-"s together, like the picture below:
As for the amp shutting off for a few seconds, it sounds like it's either:
A) Not getting enough power at high volume.
B) Overheating.
The cap on the +12V to the amp should help, but putting a meter on the +12V might tell you whether it's dropping too low (<11V).
When you first turn the volume up, how long does it work fine before shutting off? Is it with the vehicle running or not?
Mar 25, 2008 | Kenwood KAC-9152D Car Audio Amplifier
I had this same exact problem when my last older Kenwood Marine stereo cooked itself while I had it up loud for a few weekends on the lake. (smelled like it had burned inside). I went out and bought a new Kenwood KMR-550u stereo deck. (I do not have an additional amp). I hooked it up to the exact connections where my older Kenwood stereo unit had been hooked up, as I never had a problem with this for the past three years until it failed after smelling of burning elelectrical. I had chalked the problem up to heavy rain we had one day. Every time I turned up the volume, sometimes up to 27 out of 35 possible, or 29, or 32, the stereo would suddenly shut off as if I had turned it off. After a few seconds the stereo would come back on, but unless I was quick enough to turn down the volume it would do it again right away. Of course on a boat, we were beached in a cove and the engine was not running when I encountered this. I searched the internet finding hundreds of similar complaints and several dozen theories of all types, but only a couple that pointed me towards the power (voltage) idea as the problem. I put a volt meter on the positive & negative wires powering the stereo. I watched as I gradually turned up the volume, the voltage on the power wire gradually decreased from 12.5 volts, down into the 11 range, and as it hit 10.9 or 10.8 volts it shut off typically around a volume of 32. The red power wire in my boat that never seemed to have an issue with my old stereo until it fried was determined to actually be inadequate for the power flow for the new Kenwood, and probably was the culprit of my failed older unit. I offer this sound advice: Run a new pair of positive & negative wires directly from the battery (with an appropriate fuse of course (the deck has a 10 amp fuse in it's back so I would use that at the battery) to the stereo. Check the voltage as you turn the volume up into the high 20's and low 30's to ensure you are still getting voltage in the mid to high 11-12 volt range. The stereo is designed to require a minimum of 10.8 volts to operate, and when it drops below that it protects itself and shuts down.
Mar 24, 2007 | Kenwood Sirius KDC-MP522 CD Player
Kenwood KDC-X692 Car CD/ MP3 Player Logo
1,652 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
