Question about Schumacher Electronics - Others
Why does my Schumacher 750w inverter now read 8 8 8 when hooked to 12V battery but no 110 v output?
Model X175DU
Skinnerd1
  • 13 Answers
SOURCE: Need manuel
Here is a link to your manual.
http://manuals.batterychargers.com/manuals/00-99-000854.pdf
Posted on May 22, 2009
  • 332 Answers
SOURCE: howtowire 2 12v batteries to an rv?
wire one hot lead to one battery and one neg lead to the same battery
then wire second battery to the first one
your inverter lead goes to the positive post of the first battery
Posted on Mar 05, 2010
  • 608 Answers
SOURCE: Lost the wall charger of my Schumacher 400w power
Ah, I see, it seems what you have is a power pack. If so it would contain a gelcell battery, probably 12 volts. If this is true, then you may charge it with any 14-16 volt wall charger. You have to make sure you observe correct voltage and correct polarity when connecting up. Also you may have to obtain and change the plug on the charger wire.
I'm assuming the battery DC output is inverted to AC and you use it to power small AC appliances.
Posted on Mar 21, 2010
  • 20 Answers
SOURCE: 175 watt 350 peak inverter 12v dc to 110 ac need
Hi
15/16 amp would be recommended.
You could to try a 20 amp, but you will risk overheating and the possible failure of the vehicle circuit fuse.
Regards
Posted on Jan 30, 2011
SOURCE: I need a replacement charger for my Schumacher
will not charger the batterys
Posted on Apr 24, 2011
My Shumacher 750 air compressor want come on now. When I put the gauge on it only tells how much air is in it but will not cut on.
Make sure that the motor is receiving power. If there is a starting capacitor make sure it is good. If all else fails you could have a bad motor or a frozen pump, either of which will cause your dilemma.
Nov 18, 2015 | Schumacher/Charge Express SCHPID-750 12V...
Where can I buy a replacement 45 amp fuse that goes in the Schumacher 750 watt power inverter?
According to the Schumacher 750W power inverter manual it can take two 40 or 50 amp spade type fuses which can be found on ebay with the link below.
40 amp spade type fuses
Sep 03, 2014 | Electronics - Others
How should I hook up a 2000 watt schumacher inverter to a 12volt battery
i normally mount it under my seat run one lead straight to the positive (red) lead of battery with a 30 amp fuse using an inline fuse holder fully sealed.than the ground (black) using a ring connector to the chassis or seat mounting stud.must run positive under carpet and through fire wall using a grommet or other possible wire channels.
Aug 16, 2014 | Schumacher Electronics - Others
2500 superex hooked up to 12v ,has a squeal when I turn a hair dryer, and the volt meader drops from 12v down alot
Is the unit hooked up in a vehicle? If it is, try increasing the engine rpm a little bit to bring the voltage back up. Sounds like the hair dryer is overloading the inverter.
Jan 02, 2014 | Superex 50-373 2500 Watt 12 Volt to 110...
Have a PI-1500 Schumacher that I just got and trying to hook up to a litium Ion battery with charged voltage of 15.86 - lights on inverter light up(red and green) but no power output--- Is this battery...
you must be careful you can not interchange Lion and Nicad there voltages are not compatible and the intelliichargers will register a fault you must replace with same batterys recomended for your unit
Oct 24, 2013 | Schumacher PSI-1500 1500W Pwr Inverter
Schumacher Mity-Mite model PS-70A. I want to
http://www.alibaba.com/product-gs/206111785/dry_type_deep_cycle_battery_12V.html
Does the above fit the description of having solid tabs with holes?
Or is this the quick connector type?
Jul 13, 2010 | Schumacher & Fast Charge Starter Charger
Lost the wall charger of my Schumacher 400w power inverter (model PP-2200), where can I get another one?
Mar 21, 2010 | Schumacher 400w Power Inverter
Power hook up
This type of inverter has large alligator clips on it because the amperage that comes through a cigarette lighter is insufficient and can result in blown fuses and overheating of the socket. Hook this one up directly to the battery without splicing a longer wire to it.
Apr 22, 2009 | Black & Decker Husky 750w Power Inverter
Electronics - Others Logo
37 people viewed this question
Top Schumacher Electronics - Others Experts
Are you a Schumacher Electronics - Other Expert? Answer questions, earn points and help others
