Question about Holmes Products HCH4166 Ceramic Compact Heater
Hch4166 shuts off - Holmes Products HCH4166 Ceramic Compact Heater
Which parts should be changed to solve the problem not to automatically shuts down
It depends on why it is shutting down. Is it overheating? Is it full of dust or pet hair? Does it shut down normally showing you a shut down screen or does it merely turn off. If it turns off, then I would check fans and heat pipes. IF it shuts down with a shut down screen you would want to check your windows install.
Oct 16, 2016 | Computers & Internet
Just replaced the circuit board after a technician told me that was the problem. White Rodgers 50A56-956. Getting the same result as the old board: clicks on, shuts off
White Rodgers relay clicks shuts off Surveillance Cameras ...
www.fixya.com > ... > Tags > relay clicks shuts off > Surveillance Cameras
White Rodgers surveillance cameras relay clicks shuts off related questions and answers. Ask your White Rodgers questions. Get free help from surveillance ...
White Rodgers car will start up but shuts off Surveillance ...
www.fixya.com > ... > car will start up but shuts off > Surveillance Cameras
White Rodgers surveillance cameras car will start up but shuts off related ...Thermostat works, clicks when turn on heat, shows Stage 1 on display (hooked up .
relay clicks shuts off Surveillance Cameras Questions ...
www.fixya.com > Forum > Tags > relay clicks shuts off
Surveillance Cameras relay clicks shuts off questions and answers. Ask your relayclicks shuts ... I have a white-Rodgers 1F86-244 thermostat. When I ... a new ...
Jan 16, 2016 | White Rodgers Home Security
Pull the keys radio never shuts off, I replace the fuse because it was burnt out.
radio will not shut off when car turned off - Car Forums and ...
www.automotiveforums.com > ... > Chevrolet > Cavalier
I have this anyoing problem..when i pull the key out of the ignition the radio ... They could not wire it so that when you opened the door, it would shut off. .... I NEVER had to do anything with the airbag wires or shut the airbag off or anything!
07 Silverado Will Not Shut Off With Key Removed - 1999-2006 & 2007 ...
www.gm-trucks.com/.../115642-07-silverado-will-not-shut-off-with-key...
Jun 27, 2010 - 14 posts - ‎8 authors
The only way I can shut it off is to pull the fue... ... It runs perfect as if I never shut itoff. It is not dieseling it runs like the key is on. The complete vehicle shuts down like it is off ie all dash lights, radio, go of and it will not allow the ...
VW Jetta MKIV/MK4: Stereo doesn't shut off with car 'Volksw
Dec 30, 2015 | Cars & Trucks
I am having a problem with shut down the computer.After shut down command it displays windows will shutting down and hangs but will not shut down i need to press the power button to shut down(My computer...
Something is not closing on exit. Try running in safe mode, then shut down. If it shuts down then something is loading and present in the taskbar which isnt closing down.
Dec 19, 2010 | Computers & Internet
Shut down computer but some lights stay on
Your are not "shutting down" the laptop. It is going into "Stand-by" mode.
#1:
When you want to shut down,
select [Start]
then select "Shut down" and not "Stand-by"
The power button will also work.
#2:
Press the power button and nothing else.
The laptop will log you OFF and "shut down"
Nov 08, 2009 | Toshiba Satellite A135-S2386 Notebook
I cannot shut down or restart my PC using the start menu prompts. The only way to shut her down is a hard shut down (manually turn her off).
There is a program that is failing to shut down in general, which is delaying the computers ability to shut down.
The next time you shut down, make sure you have no programs open. Then, while attempting to shut down, wait until Windows pops up window asking you to close a non-responsive program. When it does, take note of the program that it mentions, then close it and see if Windows shuts down. Note: sometimes this takes a really long time.
Try re-installing the non-responsive program and see if your computer can shut down normally again.
Aug 07, 2009 | Acer Computers & Internet
Television shuts itself off
i had the same problem with my set shutting off and was told it may be the ballast so i changed that but it still would start up and shut down after a few mins, then i was asked if the bulb had been changed and i had not, so i did change the bulb and have not had it shut down yet. :) (so try a new bulb)
Jun 01, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a 96 cadillac deville and my interor lights wont shut off
timer is bad that shuts them off after u open and shut a door
should go off when u get in and start up vehicle
Feb 06, 2009 | 1996 Cadillac DeVille
Holmes Products HCH4166 Ceramic Compact Heater Logo
Top Holmes Products Heating & Cooling Experts
Paul Carew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
