Question about DeLonghi PAC C120 Portable Air Conditioner
PAC a130hpel Eco
How to heat he unit
I have a Pinguino PAC WE 110 ECO. I brought the unit just over 2 years ago and it has remained in the box until today when i finally unpacked it and tried to use it. Firstly, im a refrigeration appren
f1 fault could be either room sensor defective/open circuit or pipe sensor defective/open circuit. check the circuit board to see if any of the jacks have fallen off with movement of the unit over time.
Feb 07, 2015 | Heating & Cooling
Why is my portable air conditioner blowing out room temperature air?
Make sure the filter(s) have been cleaned (Washed) and that the thermostat is set to the correct temperature. If the room temp is the same as the setting on the air con, it wont cool or heat. Just the fan will be operating.
Sep 10, 2014 | Heating & Cooling
Atwood 10 gallon H2O heater- replaced thermal couple and electrode spark and sensor but heater comes on with switch, heats water for 10 to 15 mins then burner goes out. Can hear a couple of switching...
I'd check that ECO and thermostat discs are making contact properly with tank.Just peel back foam cover on outside of tank that has ECO and THERM marked on it. If they are installed correctly, replace them.
Aug 06, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I own a delonghi pinguino eco PAC T120 and when i switch it on it shows 'ft'on the screen. it doesnt turn the air on. what can i do?
Probably, the
"ft" means to check the filter. If your filter has not been cleaned in a while, it cannot breathe,and operate properly.
Dec 22, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Unknown 2007 Toyota Camry Hybrid Button
The ECO HEAT/COOL button of your hybrid functions to reduce the consumption of electricity thus, a reduction of fuel consumption. An indicator 'ECO' appears on the air conditioning display to indicate that the mode is on. Of course, with the ECO HEAT/COOL on it'll take longer than the usual amount of time for the temperature to reach its normal or standard set temperature.
Your ECO HEAT/COOL mode won't function if your temperature control is set at 'LO" or 'HI" or if the air flow is in the "floor/windshield mode" or "windshield mode".
Hope this helps.
-jay
Jul 03, 2009 | 2007 Toyota Camry
CVA-1004 head unit set-up
check the cables, it may be one color switched
Sep 28, 2006 | Alpine CVA-1004 Car DVD Player
DeLonghi PAC C120 Portable Air Conditioner Logo
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
