Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
I need assistance changng the black ink cartridge on my MFC 24OC brother
  • 124 Answers
  1. I have this printer myself.
  2. Facing the printer, look on the far right corner.
  3. You will see a little door below the scanner. This is where the single black and three color cartridges reside.
  4. Open the door and see the cartridges.
  5. The black will be the one that is to the far left in this compartment.
  6. Each cartridge is secured by a blue vertical "lever"
  7. Push on the blue lever and it should click and pop out slightly.
  8. With your index finger, pull down on the lever and the cartridge should pop out even further.
  9. Let the blue lever drop down and grasp the cartridge and pull toward you. The cartridge should come out.
  10. Remove the cover and tape from the new cartridge and put in the black cartridge slot until seated in the slot.
  11. Gently lift the blue lever until it clicks
  12. Close the door and the printer will begin to clean itself automatically.
If my assistance has helped you, please complete the rating. Thanks for using Fixya.com
Posted on Jan 28, 2009
  • Bernie Thames
    Bernie Thames Jan 30, 2009
    Did you get your cartridge changed? If you able to use my information, I'd appreciate your feedback? Thanks!
New black ink cartridge
I suggest You Go to Official Brother Printer Page For You Brother Printer Problem On Below Brother forum URL Link: Replace the toner cartridge Brother
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :Brother Printer Support
Feb 13, 2014 | Brother MFC-290C Printer
Brother multifunction laser printer, model #8220 : can you use color ink cartridges with this model or black /white only?
Welcome to FixYa!
The MFC 8220 is a Laser Printer. It uses Toner Cartridge. Product #TN540 or #TN570. It cannot use the regular ink cartridge.
See full details in this link: http://www.brother-usa.com/MFC/modeldetail.aspx?PRODUCTID=MFC8220&tab=supp
Thank you for using Fixya. Jas247
Apr 03, 2011 | Brother MFC 8220 All-In-One Laser Printer
Black ink on my Brother MFC-420CN is faint and streaky
You said you replaced the cartridges. Were they Genuine Brothers' Cartridges?
My Brother MFC-240C, does not like Generic Printer Cartridges. That sounds like your problem. Also I had with Brother's was problem with Color. Color that should be Yellow, will turn out Green, or Blue Green, etc. The Generic Cartridges, also printed lines thru the words. That's what the Companies do., so they can keep selling the ink cartridges.
Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY, or Take them to have them filled.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for the PRINTERS.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 03, 2010 | Brother MFC 420CN All-In-One InkJet...
Changed toner on brother mfc-7420 cleaned lots black dust printed black cleaned thouroully again and again now lots of black streaks but no words ,whats best to clean drum
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother Mfc-845cw and Mfc-465cn both stopped printing Black about the same time. Using Non brother Ink. Tried cleaning, replacing carts, unpluging maching. how can I fix this.
the black ink that was used in the refilled cartridges was probably to thick for the nozzels on the head, you can try buying the original cartridges and then cleaning again, or check with the store you got these cartridges from as some of them offer a warranty
Nov 20, 2009 | Brother MFC-465CN InkJet Printer
Black ink empty
hello, please see this e-book to assist you.
http://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_MFC_240C_EN_353.PDF
Sep 21, 2009 | Brother MFC 240C All-In-One InkJet Printer
Not detecting ink cartridge - or saying empty - Brother MFC 240c
Is it an ORIGINAL BROTHER cartridge ? ?
OR
A cheaper version ? ?
Aug 22, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Feb 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
New ink cartridge istallation: Brother MFC-240
I guess you d used generic ink carts?!
If yes, the cart holder needs replacement due to ink that has stained the led control. The ink has made a short circuit. The error can only be deleted by replacing the whole cart holder!
Jan 28, 2008 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
56 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
