Question about Lexmark T644dtn Printer
I have a lexmark t644 error 843.00 - Lexmark T644dtn Printer
SOURCE: Reset Lexmark T644
1. Turn off the printer. 2. Press and hold (check) and .(right arrow). 3. Turn on the printer. 4. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. 5. Select Reset Maintenance Count from the Configuration menu. 6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
Posted on Jan 26, 2009
SOURCE: setting print count on Lexmark T644
I'm assuming you mean the maintaince counters... Turn off the printer. Press and hold the check and right arrow buttons on the front of the printer
Turn on the printer. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. Select Reset Maintenance Count from the Configuration menu. The message Reset Maint Cnt=Reset displays momentarily. Press Check to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
  • 13 Answers
SOURCE: i have a lexmark t644
  1. If the printer is currently displaying a 900 RIP Software error, power off the printer and leave it powered off for 20 seconds or more. Doing this will clear the printer's memory.
  2. While the printer is off, clear any pending print jobs from the computer or the network queue. This will prevent any corrupted print jobs from being sent to the printer again when it is powered back on.
  3. Power the printer back on.
  4. If the printer goes to the Ready status, try printing again.
  5. If the 900 RIP Software error returns when the printer is powered up or when you try to print, there is a problem with either the printer, the communication cable connecting the printer to the computer, or with the print job itself. Follow the directions below to check each of these components.
    • If the error appears every time you power on the printer, regardless of whether you send a print job or not, the likely source of the problem is the printer or an option installed on the printer.
    • If the error appears only when you send print jobs to the printer, the likely source of the problem is the computer, a setting on the printer, or one of the communication cables.
Posted on Feb 06, 2009
  • 3 Answers
SOURCE: nvram mismatch
You have to install a brand new front display, the display board has a backup of the nvram, on boot the system board check the nvram and if it don't match it will return an NVram mismatch error
Posted on May 29, 2009
SOURCE: lexmark t644 error code 917.00
This error indicates that there is a charging problem with the transfer roller. You could start by cleaning the contacts for the transfer roller (power off printer first). The transfer roller is the black foam-like roller under the toner cartridge. Handle it with paper because the oils on your hand could damage it. To remove it, just pry under the far left side with a screwdriver. Lift and pull to the left to remove. If this does not fix it, then you have a more serious problem. It could be one of the arms or the HVPS.
Posted on Jun 03, 2009
How to install a lexmark t644 250 sheet pick arm ***'y in 3rd tray
We do not advice that you remove the pick arm for the Lexmark T644. I would suggest that you contact Lexmark Technical Support or contact a local Lexmark Service Provider (please click on the link below to locate a Lexmark Service Provider nearest to you).
Link: http://bit.ly/UeQhSB
Jul 04, 2012 | Lexmark T644 Laser Printer
What's your problem?: Lexmark T644 238.02 ERROR
Lexmark t640 Fehlermeldung 238.02 alles nach gesehen kein Papierstau was kann es sein?
Feb 08, 2012 | Lexmark T644 Laser Printer
Lexmark t644 is showing "920.06
920 error is cold lamp on fuser replace fuser will clear problem
Sep 25, 2011 | Lexmark T644 Laser Printer
I got message (900.00 service rip software) on my lexmark T644 printer. What does this mean
900 rip is a inrecoverable software error POR printer take data cable out and POR should clear if not then system bord needs replacing more likley corupt dat sent to printer
Sep 16, 2011 | Lexmark T644 Laser Printer
Hi where do i find a toner sensor in a lexmark T644
The toner sensor is located in a hole on the right frame (is an optical sensor)
Sep 05, 2011 | Lexmark T644 Laser Printer
How to fix,if every time somebody send to printer Lexmark T644 shows error message:"change tray 1 to color letter? thank you Bella Touro College lab tech
Have a look in the preference settings of the printer driver and check the paper type. If this is set to color letter you'll have to set the traysettings to the same type of paper. Best is to set both setting to normal paper.
Jul 27, 2010 | Lexmark T644 Laser Printer
77 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
