My tv says no channels found please check antenna connection what can I do please
2 Suggested Answers
SOURCE: tv not working
Can you confirm that you didn't have any input signal? My wife once accidentally pressed the reset button on the remote and the TV was stuck in this state. I tried to hook up an antenna to the digital antenna input and let the TV search for a channel. It did find a station and got out of the channel search mode, which was all I needed. Then, I unhook the antenna and continued to enjoy my DVD movie. I didn't check the manual. So, it's possible that there is a better solution. My TV was working fine and I think it just has a terrible user interface. I'm not sure about your TV's condition, though.
Posted on Sep 19, 2007
Finds no channels on autoscan, even though it found channels a few days ago in another location & another tv finds them in current location connected to the same antenna. Has a part gone bad?
Has the input source been set back to Antenna or TV tuner? Click on the Menu button on the remote and select input and check that it the correct source is selected
Jul 04, 2016 | Televison & Video
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
I have an indoor digital aerial connected to a free view box but when I automatically tune the TV it comes up with no channels found check aerial connection
Possibly. Try rotating the antenna a little bit and retry tuning. Keep on doing this until you get your channels. If this doesn't work, raise the antenna as high as possible and try again.
Dec 20, 2014 | Goodmans GTVL19W17HDF 19 in. LCD TV
Why won't hd channels be found when I tune my 42
It depends where you are. Digital has replaced analog signals. If you don't receive channels, ask a friend or neighbours on the situation with their TV. If their hd TV are working properly, then you may have not tuned the TV properly. Have you chacked the Antenna cable? Yes? Then tune it with care and watch what happens. Normally, the TV will show if a signal has been detected. If you have no signal, you need a technician because there are more than one reason this is happening, probably you haven't connected the Antenna cable. Who knows. Again, check the antenna cable, is it lose or wrongly inserted? If you have a small digital TV, connect the antenna to that TV and see if the channels are working. If not, it's probably the cable from the wall socket to the TV (change the cable) or the Antenna cable had been a meal for a rodent on the roof. As I said, who knows?
Oct 17, 2014 | Televison & Video
Hi I bought a TD930B GPX today and I already listened music on cd, how I can set up to watch TV channels please give me a little tip? thanks
Since the TV has a digital and an analog tuner, you just need to connect to an antenna with the strength to receive your local channels and point the antenna at the station transmitter (or at least close to the correct direction). antennaweb.org and tvfool.com will both provide some information on the available channels in your area. Antennaweb is very conservative in the list it provides (even with the assumption of an external antenna). tvfool will provide information on the antenna that is most likely to work to get a given channel at your location.
Next set the source to TV and use the menu to search for channels. (Digital channels will only be found if the signal strength is sufficient for the tuner to resolve.)
I hope this helps.
Oct 11, 2010 | GPX Televison & Video
I have a Westinghouse 26 inch TV. Model # SK-26H590D. It will not scan channel 9. I have tried both the automatic scan and the find channel scan. It is hooked to a Phillips Mant 510 vhf/uhf indoor antenna...
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Feb 19, 2009 | Westinghouse SK-26H590D Television
No signals found when searching for channels at setup
you need to press the channel up button 3 times if yo get message as please connect av sources. then do the manual channel search for 2 times. it should solve the problem.
Oct 13, 2008 | Sanyo DP32746 32 in. LCD Television
Programming
can you enter channel 4 manually and get picture
Nov 19, 2007 | Zenith Z19A11S TV
Stuck on Channel searching!!!
the problem is we have no cable-none at all. The tv is used only for playing DVD's. solution check dvd to tv wire or socket if it is ok then play dvd in another tv if it works fine then problem in tv. for that check tv tuner & its circuit for loose. check tuner itself
Sep 11, 2007 | Sanyo DS20930 20" TV
Quasar VV-2001 TV/VCR combo - msg: Check Antenna Cable Connection
Check first the antenna using another TV. If there is no other TV available, check using an ohmeter. If you are 100% sure tha the antenna is ok then the antenna connector on your Tv is not making a good connection to the antenna plug.
May 24, 2007 | Quasar VV-2001 20 in. Combo
Televison & Video Logo
873 people viewed this question
Top Televison & Video Experts
