Question about GE DBVH512GFWW Dryer
Power button broke gfdn240el1ww - GE DBVH512GFWW Dryer
There are two main pieces to the front panel for the GFDN240EL1WW dryer-- the plastic panel and the circuit board. The actual replacement part is: Control Panel WE19M1687. The panel can be purchased for from places like partselect.com or repairclinic.com or Amazon or even EBay, etc. for $100-$200+.
The power button is just a piece of plastic mounted to another piece of plastic; it is not electronic. When pushed, it presses against the circuit board, which then turns the unit on/off. When the power button breaks, it typically means the little plastic button has broken off from the plastic panel. Most likely, the problem is the mount point for the button and the button is actually re-usable.
A cheaper quick-fix is to:
  • Remove top screw from back of the front panel
  • Remove main front knob from the panel
  • Remove screw from behind the front knob
  • Grab both sides of the front panel and push/pull up to remove the panel
  • Disconnect the block connector (power) from the circuit board after removing the panel
  • Locate the power button and mounting position
  • Inspect to see if it looks like you can glue the button back into place
  • Buy a small tube of loctite Stik'n Seal Ultra Universal Adhesive
  • Put some Stik'n Seal on the button mounting point for the power button (be generous)
  • Press the button onto the mounting point and hold for a few minutes
  • Add more Stik'n Seal around the edges of the mounting point and the button mount after you have held the button in place long enough so that it sticks
  • Let the whole thing dry for several hours (instructions on the adhesive say 24hrs
  • If you are worried about the button staying seated while the adhesive sets, you can always try tape it into place
  • When dry, replace the front panel by reversing the steps above used to remove the panel: connect the power block, slide the panel back into place, replace the front screw and knob, replace the top screw in the back of the panel
Posted on May 29, 2014
  • Louis Guardino
    Louis Guardino Dec 26, 2015
    Of course I saw this post after removing screws all over the place. But we did finally figure how to get the panel off.
    I used 2 part epoxy putty to glue the button back. It set like a rock in minutes. Let's see how long it holds. Hate to spend $230+ for just a crappie button.
This worked great! Couldn't fine that glue and instead used epoxy for plastics which worked as well! Thank you.
Posted on May 22, 2016
Did this work? I have the same problem as I just disassembled the front panel. Thanks
Posted on Jan 09, 2016
Dragon Touch Android tablet. How can I replace a broken power button?
I bearly got my dragon touch and then my power button broke?
Jan 26, 2014 | Tablets & eReaders
Firmware update broke WGR614v7
Best way is do a factory reset.Press and hold reset button during this procedure ,do not release the button until you are finished and you will be back to factory default.
1)Hold button 30 sec.
2)remove power cord hold 30 sec.
3)plug in power cord 30 sec.
You should now be in default factory mode,good to go.
Nov 06, 2013 | NetGear WGR614 54Mbps Wireless Router...
I broke the female end (****) off motherboard for power button
YOu can buy and replace it with new one. contact your supplier for that accessory.
Dec 29, 2012 | Dell Inspiron Mini 1012 Netbook
Power button completely broke off,alternate power on suggestions
hi there is no alternate solution. you can fix it by contacting the your mobile servicer. they will change te power button.you can solve it by changing the power button
thank you
Dec 16, 2010 | Nokia 5310 Cellular Phone
My power button broke to my mitsubishi hd 1080 and I lost the remote control is there any other way to turn it on?
is the button pysically broke... the unit does have a keyboard lockout feature press and hold menu for 10 seconds... maybe if not then the power button will need repair or a universal remote may be used
Oct 14, 2010 | Mitsubishi WS-65315 65" Rear Projection...
POWER BUTTON BROKE
The power button is broken and jammed. change it , everything will work fine.
Jul 24, 2009 | HTC PPC-6800 Smartphone
Can you help me? pleasE!
what kind of help do you want? if the button is broke, its broke.
Jun 15, 2008 | Coby MP-C7085 MP3 Player
POWER BUTTON BROKE, CAN'T START MY NOTEBOOK COMPUTER GATEWAY 7326GZ.
Did the power button come off or did it stop working. Broke has a lot of meanings.
May 29, 2008 | Gateway Computers & Internet
Turn on
what you have to do is to replace the power buttton you broke with a new one the power button you broke doesnt make contact with the phone.advice by dogy
Dec 21, 2007 | Nokia 6233 Cellular Phone
Dryers Logo
1,769 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
