Blenders
Problem for Blenders
Generic problem for all Blenders
Leaking blender
By ljbrinkmann on Jan 27, 2009
My red, smoothie pro 600
leaks through the bottom of the blender no matter how tight the base is screwed on.
I wondered if it needs a new rubber gasket.
Same Problem
Mar 24, 2009
-   Mine also leaks, it has a crack in the collar also, seems to me it is a defect, because this happened after the very first time I used it......not sure if I want to get a new part or just throw the whole thing away.-   Guest
Mar 21, 2009
-   My red Smoothie Pro 600 base leaks also. I lost all my smoothie last time I used it. I was very upset about the mess that it caused. I have put it up and have not used it since. Looking for a solution. Thought I may need a new rubber gasket. I will see if it may be upside down. Did not know it had to be certain way. I am about ready to look for another one. Help, if you can.-   Charlais
Feb 09, 2009
-   I have same problem with leak from the bottom of my problend BL6000. I noticed a hairline crack in the collar. Does anyone know where I can get a replacement?-   pkraus2345
Solution #1
posted on Jan 29, 2009
Somewhat Helpful)
clyde2j2
Rank: Wiz
Rating: 83%, 103 votes
I know this may sound dumb but are you sure the rubber  gasket is not on upside down?
Was this helpful?
Yes
No
Solution #2
posted on Sep 21, 2009
Not Rated)
plumeriamj
Rank: Apprentice
Rating: 0%, 0 votes
Mine also leaked from day 1. I just read in the manual to first place the bottom and blade assembly on the counter, then seat the gasket around the blade assembly, making sure it is just under the lip of the blade piece (careful, you have to maneuver around the blades). Then place the jar on the assembly and screw in tightly. This worked and I have no more leaks.
This is different than other blenders where you place the gasket on the jar and then attach the bottom. It is a poor design, but after what I paid for it, I am glad to be able to use it and not just trash it.
Was this helpful?
Yes
No
Popular Solutions for Blenders
Questions and Unsolved Problems for Blenders
Answer
pour spout broken on back to basic sp smoothie 600
Answer
Nothing when power on.
Answer
The plastic stem adaptor is stuck on the blender base of my Cuisinart blender food processor combo.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Blenders:
Top Blender Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Blender Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
