Uf 33 panasonic Ub-5835
Uf 33
Cannot change source or TV input. Stuck in HDMI2.
Sounds like you have a defetive main pcb. You might try a firmware update if there is one first.
Mar 19, 2013 | Samsung HL-S6188W 61" HDTV
Teac ct m685 shutting down
Removed and checked the power supply unit and confirmed the capacitors
C905 220uF 420V was measured at 200uF
C926 22uF 160V measured at 21.6 uF
C908 10 uF 100V measured at 10.35 uF
C910 47 uF 63V measured at 45.8 uF
Resoldered all of the joints on this PCB to ensure good connections.
On the Main PCB checked capacitors
C401 220uF 35V measured 214 uF
C417 100uF 160V measured 100 uF
C411 3300uF 35V measured 3090 uF
D204 was still a diode
C430 4.7nF 1600V measured 4.5 nF
C406 4700uF 25V measured 4460 uF
Reassembled and confirmed worked OK
These checks / repairs did fix this fault and the television is running well.
Dec 29, 2012 | Televison & Video
When I turn my tv on my speakers work for apprx 5 minutes than start crackling very loudly then go out.What could cause this ?
Hi, My samsung dlp 46 tv was making a loud crackling and popping sound from the speakers, I turned OFF all the volume
control on my tv from the menu the srs, the auto tune volume, the internal volume which, is the main one which silences the crackling sound immediately! But, you must have surround sound and play the tv volume through your surround sound and wa laaaa, it WORKS! The tv may eventually stilll go out before or if I decide to have it fixed. It is about 3 years old.
Nov 30, 2010 | Samsung HLT6187SAX 61" DLP HDTV
I have a floor fan with a bad capacitor. its a 1.5uF +-5% 450V. can i replace capacitor with a 33 uF 250 ~ 275 V capacitor ? or with some other one that i got ?
no, the capacity is way too high.... get a capacitor of at least 1,5 uF or up to max 4 uF if you happen to have one lying around
Oct 10, 2010 | Lakewood HV 18-c Floor / Box Fan
Samsung HL-S6168W DLP is making a popping (cackling) sound and beeping noise. Audio on television goes up and down, sometimes the voice audio is loud and background is low and then vice versa. Sometimes...
I would check the speakers see if the anything is getting hot, take back cover off make sure you dont look at lamp. Tape down switch to lamp door and see whats making noise.
Jun 02, 2010 | Samsung HL-S6168WX DLP TV
Driver compatible with vista
(Laungage : English)
OK : Available
�� : planned.
�� : Currently undergoing compatibility testing
N/P : Not planned. OK��Update on Mar 31, 2010
Model 32 bit
(English)
64 bit
(English) Others
DP-MB300/320/340/350 GDI
DP-MC210 GDI
DP-8060/8045/8035 GDI
DP-8032/8025 GDI
DP-8020/8016 GDI
DP-6030/4530/3530 GDI
DP-6020/4520/3520 GDI
DP-6010/4510/3510 GDI
DP-3030/2330 GDI
DP-3010/2310 GDI
DP-1820/1520/1515 GDI
DP-190/180 GDI
UF-9000 GDI OK N/P
UF-8100/8000/7100/7000 GDI
UF-7950/6950 GDI N/P N/P
UF-8200/8300/7200/7300 GDI
DX-800 GDI N/P N/P
DX-600 GDI N/P N/P
UF-6100/6000/4100/4000 GDI
UF-6200/6300 GDI
DP-3000/2500/2000 GDI N/P N/P
DP-1810/1510 GDI
DP-150/135/130 GDI N/P N/P
UF-990/890/790/590/490 GDI N/P N/P NOT PLANNED
UF-895/885 GDI N/P N/P
UF-595/585 GDI N/P N/P
UF-880/770/560/550,DF-1100 GDI N/P N/P
DX-2000/1000 GDI N/P N/P
FP-D605/455/355/305 GDI N/P N/P
DP-C406/
Apr 29, 2010 | Panasonic PanaFax UF-490 All-In-One Laser...
The audio on my Samsung HL-S6188W DLP TV is completely out--no sound from TV speakers in any input mode (ATSC built-in tuner, component-in, etc.). Furthermore, the optical-digital audio out does not...
Check your mute on /off status through your remote. If it is changing status & no sound,
It looks like sound circuit problem.Contact service center for assistance.
Apr 21, 2010 | Samsung HL-S6188W 61" HDTV
TV has low sound output through right speaker of stereo receiver
try the balence. if no joy. try the cable if you have a meter also see if the cable and see if the cable has been reversed???????
Mar 27, 2009 | Samsung HL-S5087W DLP TV
Bose Lifestyle 5 ~ dead display fix
Hi the fix for a dead display is a faulty capacitor. Depending upon which board version you have, you need to replace the 33 uF / 63 volt capaitor. On some units this is C19 on the display board, on other units this capacitor is mounted on the main board and re-numbered, there is only one 33 uF on the unit so you should be able to find it.
Dave
Sep 21, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
19 people viewed this question
k24674
jasbo
jasbo
