Question about Acer PD523 Multimedia Projector
Acer aspire one won't connect to projector
Tried Fn+ F5 and that didn't work
  • 1 more comment
  • Anonymous Feb 03, 2009
    I have an Acer TravelMate 4720 that won't connect to a projector either. The laptop doesn't recognize that the projector and the projector says that 'no connection'.
  • Anonymous Feb 18, 2009
    I cannot get my computer screen to show up on my projector screen. Everything is connected correctly, I was able to get screen two up when I followed your directions above, but I want the same screen I am veiwing on my laptop to show up on the projector screen, how do I do that?
  • t_rr Nov 26, 2009
    My Acer Aspire One 150 A won't connect to the projector properly either - doesn't show me the desktop.
    I tried the listed solution to no result - just the desktop wallpaper shows, no icons, nor nothing.
    I read I shoud "go to advanced display properties and set the output to clone instead of extend desktop", but how do I do that?
  • Acer Master
  • 13,433 Answers
Hey,
On your desktop, right click, select properties.
now go to settings.
do you see screen number 2? select screen number 2 and check that the screen is enabled if not place a check on the checkbox and enable the monitor, now check the resolution and colors adjust them as you see fit, to move objects to the projector display drag them out from your laptop monitor.
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 16, 2009
  • Ekse Feb 16, 2009
    on my computer, I can drag objects from my main monitor to the one above it and the other one on the side, just draging them out from that side will move them to the other display.
    if you have any questions let me know.
  • 4 Answers
I think I have the same computer. It has Intel graphics so it is harder to find information. Here's what I do.
1. Right click on desktop
2. You should see two graphics options. Clock on either of them.
3a. Graphics Options > Output To > Choose Monitor, Clone, or Extended Desktop.
3b. Graphics Properties... gives you a menu driven procedure to do the same thing.
If these don't work, open the Control Panel and click on Intel GMA
Posted on Mar 23, 2012
  • georgena1949
    georgena1949 Nov 10, 2012
    Thank you so much everything else I tried didn't work your suggestion was instant.....
I have acer aspire 4720 laptop. when i am
Did you press FN key+F5?
Please rate my help++++Thanks for using FIXYA
Jul 01, 2010 | Acer Aspire 4720 Notebook
Cannot get screen to come up utilizing INFOCUS media projector
check whether the connections are proper that is any loose connection
Jun 19, 2008 | Acer Aspire 3000 Notebook
I need to show Powerpoint slides from my Acer Aspire One netbook. When I connect to the projector it does not work. Why?
Have you pressed Fn+F5? It commands using external monitor/ projector. Try this:
1. Connect to projector with projector in ON position
2. Restart your PC
If it won't work:
1. Restart your PC, press F8 frequently, choose "enable vga mode"
May 01, 2010 | Acer Aspire One PC Notebook
Cannot connect acer aspire one to projector. it's first detected when netbook is booting up but the connection dispappears (no input on projector) when the computer is fully on.
It should be a keyboard toggle to switch display to the projector, usually Fn + F5, sometimes you have to tap the F5 key a couple of times for the display to switch over.
Good luck
Jun 19, 2009 | Acer TravelMate 2300 Notebook
No LCD connectivity
Hello, I am using a Viewsonic lcd projector with my new Acer Aspire One. I did not have connectivity off the bat. Here's what I did: 1. Downloaded driver (unsigned, not the signed version worked - ie not os-specific) for the lcd projector to the Acer. Restart Acer. 2. With lcd projector connected to Acer, toggle function key & F5. But then, continue holding down the function key. A screen pops up with icons for laptop, laptop/monitor, dual monitor, and lcd projector. You continue to hold down the function key and then press the F5 key to move to the desired device. I had to repeat the same process to restore my Acer screen to the original proportion when not using lcd projector. I'm not sure if both steps 1 and 2 are necessary, but I did it simultaneously, so I'm not sure of the origin of success.
May 22, 2009 | Acer Aspire One PC Notebook
ACER Aspire One AOA150-1635 and Sharp XR32-X projector
you need to connect it with VGA. then enable the 2nd monitor
now you should have a wallpaper on the projector, you can drag objects to it by draging them out from the screen.
if you don't have the 2nd screen option. Then hold down the blue FN button and then tap F5 see if the picture comes, the FN + F5 will swap around with the outputs.
Feb 16, 2009 | Acer Aspire One Netbook 8.9" Notebook
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Connecting to projector
HI-
Try tapping the FN+F5 keys twice, or try FN+F3 keys for acer laptops. MAke sure that cables are connected tightly at both ends.
Hope this helps
Oct 09, 2008 | Computers & Internet
Acer Aspire 3680 + View Sonic Projector
does it work with external monitor ?
the key should be Fn+F5 or Fn+F6
I believe you need to hold fn and press f5 to choose the target (lcd, monitor, lcd and monitor).
Feb 26, 2008 | Computers & Internet
Open Questions:
Acer PD523 Multimedia Projector Logo
10,529 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
