Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Toner cartridge how do you change a toner cartridge?
  • 1 more comment
  • Anonymous Feb 03, 2009
    how to open the toner
  • bshelby1 May 05, 2009
    How do you change the toner cartridge on a Canon IR 3300
  • benhayescons May 20, 2009
    How Do I get the toner cartirdge out? I need to shake it back & forth for more uses.
    Genius:
  • 2,120 Answers
RTFM
Posted on Jan 28, 2009
Some confusion about compatible toner cartridges
If you have used the brand of V4INK's toner cartridge, you won't want to change any other brand. It's the best compatible toner cartridge I've ever used. It's cheap and good quality. Printer Toner Cartridge Supplies Buy Toner Cartridges Online V4ink
Jul 17, 2017 | The Office Equipment & Supplies
Out of toner
Make sure that the toner ink cartridge is a genuine Lexmark toner cartridge. Try removing the toner cartridge and then shake the toner sideways. Re-seat the toner cartridges and check if the error persists. If it does, please contact our Technical Support Hotline.
Dec 03, 2012 | Lexmark T520/522 BLACK PREBATE TONER
HL215ON changing toner How do I change the toner?
Its not very hard to replace toner cartridge on your brother laser printer. please click the link below and follow the instructions with diagram, to replace toner cartridge:---- http://technoanswers.blogspot.com/2011/06/how-to-replace-toner-cartridge-on.html ----------- this should help.thanks.helpmech,
Jun 01, 2011 | Brother HL 1240 Printer
I change my toner, and i have msg. "ORDER
Must be an aftermarket or refilled toner cartridge. These toner cartridges have a chip on them that must be changed when refilling or remanufacturing the cartridge. It looks like you got a cartridge where the chip has not been changed. I would return it for another cartridge.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 13, 2011 | HP LaserJet P3005 Printer
When any color cartridge finish , you must change the whole unit Why?????
No, you must change only the toner cartridge that has finished. It would be quite a waste to replace a toner cartridge that's not empty. Here are the codes for each cartridge, to know which one you need:
-CB540A Black Toner
-CB541A Cyan Toner
-CB542A Yellow Toner
-CB543A Magenta Toner
Remember to always use genuine cartridges.
Dec 12, 2010 | HP LaserJet CM1312 All-In-One Printer
Have a c1900 but no disk for utility management to change toner cartridges, how do I get around this and change toner cartridges? Drivers are installed and printer in operation hence need to change...
You go through the menus :
Press Right arrow once,
Then down arrow 5 times (to Reset Menu)
The Down arrow 5 times to Change toner C (Cyan)
Then down arrow again to Change toner M (Magenta)
Then down arrow again to Change toner Y (Yellow)
Then down arrow again to Change toner k (Black)
Select your colour to change and press the right arrow. The engine durns, open the door and remove the cartridge
Jul 01, 2010 | Epson AcuLaser C1900 Printer
Inatallation of a printer
Hello , I believe I can help you out.
First here is a bit about your machines toner maintenance.
Second will be how to change the cartridge.
Remember if I was of assistance please be kind and leave a kind quick testimonial and good rating.
Maintaining the toner cartridge
Toner cartridge storage
Toner cartridges contain components that are sensitive to
light, temperature, and humidity. Samsung suggests users
follow the recommendations to ensure the optimum
performance, highest quality, and longest life from your
new Samsung toner cartridge.
Store this cartridge in the same environment as the printer
it will be used in; this should be in controlled office
temperature and humidity conditions. The toner cartridge
should remain in its original, unopened package until
installation – If original packaging is not available, cover
the top opening of the cartridge with paper and store in a
dark cabinet.
Opening the cartridge package prior to use dramatically
shortens its useful shelf and operating life. Do not store on
the floor. If the toner cartridge is removed from the printer,
always store the cartridge:
• Inside the protective bag from the original package
• Correct side up in a horizontal position (not standing on
end)
• Do not store consumables in;
- Temperature greater than 40°C (104°F).
- Humidity range less than 20% and not greater than
80%.
- An environment with extreme changes in humidity or
temperature.
- Direct sunlight or room light.
- Dusty places.
- A car for a long period of time.
- An environment where corrosive gases are present.
• An environment with salty air.
Handling instructions
• Do not touch the surface of the photosensitive drum in
the cartridge.
• Do not expose the cartridge to unnecessary vibrations
or shock.
• Never manually rotate the drum, especially in the
reverse direction; this can cause internal damage and
toner spillage.
Use of non-Samsung and refilled toner
cartridge
Samsung Electronics does not recommend or approve the
use of non-Samsung brand toner cartridges in your printer
including generic, store brand, refilled, or remanufactured
toner cartridges.
CAUTION: Samsung’s printer warranty does not cover damage to
the machine caused by the use of a refilled, remanufactured, or
non-Samsung brand toner cartridge.
Estimated cartridge life
Estimated cartridge life (the life of the toner cartridge yield)
depends on the amount of toner that print jobs require. The
actual print-out number may vary depending on the print
density of the pages you print on, operating environment,
printing interval, media type, and/or media size. For
example, if you print a lot of graphics, the consumption of
the toner is high and you may need to change the cartridge
more often.
Redistributing the toner cartridge
When the toner cartridge is near the end of its life:
• White streaks or light printing occurs.
• The warning message, Toner Low displays on the control
panel.
• The Smart Panel program window appears on the computer
telling you that the toner cartridge is low on toner.
• The Status LED blinks red.
If this happens, you can temporarily reestablish print quality by
redistributing the remaining toner in the toner cartridge. In
some cases, white streaks or light printing will still occur even
after you have redistributed the toner.
1 Open the front cover.
2 Pull the toner cartridge out.
3 Thoroughly roll the toner cartridge 5 or 6 times to
distribute the toner evenly inside the toner cartridge.
NOTE: If toner gets on your clothing, wipe it off with a dry
cloth and wash clothing in cold water. Hot water sets toner into
fabric
Changing cartridge:
_______________________________________________________
CAUTION: Do not touch the green underside of the toner
cartridge. Use the handle on the toner cartridge to avoid
touching this area.
4 Hold the toner cartridge by the handle and slowly insert
the toner cartridge into the opening in the machine.
5 Tabs on the sides of the toner cartridge and corresponding
grooves within the machine will guide the toner cartridge
into the correct position until it locks into place completely.
6 Close the front cover. Make sure that the cover is securely
closed.
Replacing the toner cartridge
When the toner cartridge is completely empty:
• The printer stops printing.
telling you that the toner cartridge is empty.
• The Status LED lights red.
At this stage, the toner cartridge needs to be replaced. For
order information for toner cartridges, see page 7.1.
1 Pull the toner cartridge out.
2 Remove the new toner cartridge from its bag.
3 Roll the toner cartridge 5 or 6 items to distribute the toner
Thoroughly rolling the toner cartridge will assure
maximum copies per toner cartridge.
4 Remove the paper protecting the toner cartridge.
fabric.
touching this area.
5 Hold the toner cartridge by the handle and slowly insert
6 Tabs on the sides of the toner cartridge and corresponding
7 Close the front cover. Make sure that the cover is securely
closed.
Good Luck!
Mar 30, 2010 | Samsung SCX-4300 Monochrome Laser...
I need black ink for my lexmarkc540n printer
This is the worst printer! i advise everyone not to buy!! changing ink every week!!!!! total garbage!!!!!!
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
Tonner exhasted and cartriges does not supportes
yes you change your printer cartridge . Your printer toner chip is disable. You buy a new toner
Jul 20, 2009 | Samsung ML-2240 Laser Printer
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
353 people viewed this question
old marine
old marine
