Question about Frigidaire FTF530FS Front Load Washer
Broken electronic connector on washing machine
Frigidaire FTF530FSO front load washer. Relatively new. All the sudden stopped final spin. Just slowly rotates back and forth during final spin now. Looked under front bottom panel and found a broken electric connector associated with the door lock. Any parts list or name of connection???
  • 1 more comment
  • seawolf541 Jan 30, 2009
    replaced door latch. now it spins slow on final spin and door lock has a mind of its own and only opens randomly? WTF?
  • Anonymous Jan 30, 2009
    I bought a new doorlocking mechanism. 69 bucks. the final spin portion of the cycle now consists of one fast spin for 8 seconds then a slow rotate in opposite direction for 5 seconds and finally a fast spin for exactly 20 seconds. and by fast I mean fast enough to get a little water out but it definitely could grab another gear... also the door now won't open sometimes. even if unplugged from wall. the door lock remove/install was piece of cake. so if you wondering if I messed something up I completely understand but it was a breeze.
    the washer is just about 2 yrs old. outof warranty. and about to be replaced if I can't get it fixedpretty quick.
  • Anonymous Apr 19, 2009
    My final spin just doesnt. I tried both final spin spots and it just sloshes around. I happened Monday. But I found if I used the extra rinse it would spin. Last night it didn't spin. It has a couple of inches of water in the drum.
  • 640 Answers
Seawolrf your going to have to do a little the door now looking at the washer i want you to take a knife or screw driver and take that gasket off right next to the door switch,,the black gasket is glued ,,yes glued pull it up..only by door remove door switch screws (2) now replace that connection...onthejob
Posted on Jan 28, 2009
  • onthethejob1
    onthethejob1 Jan 30, 2009
    did you replace door latch,,or did you reconnect...
Frigidaire gltf1670a front load washer not agitating or spinning. Can my broken shocks have anything to do with that?
Your broken shocks could have disconnected some wires due to the vibration. Plug off the wall, open up the machine to examine. In the process you have to change the shocks. Disconnect and refit each terminal, especially the connector to the motor.
Click if helped.
Mar 21, 2013 | Frigidaire GLTF1670A Front Load Washer
Won't do final spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
May 14, 2010 | Frigidaire ATF6000ES Front Load Washer
Will not go into final spin
Just a Idea, belt is slipping this is why when it is empty it works on high speed when full its to heavy and belt slips
May 06, 2010 | Frigidaire HE 3.1 cu. ft. Extra Large...
My washer works until the final spin. I have tried every final spin cycle, balanced the load, removed things to make it lighter, let it rest over night, and it still stops at final spin.
The PCB (electronic board) could have failed, but there could be other problems which would have to be rectified by a technician.
Hope this helps you?
Oct 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire FTF530FS Front Load washer
Take off the lower panel. Inspect the shocks too see if they are damaged. If they are OK turn the wash basket by hand if the knock is heard then most likely you have a broken wash basket.
Jan 13, 2008 | Frigidaire FTF530FS Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire FTF530FS Front Load Washer Logo
255 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
