Question about Acer Aspire 3610 Notebook
Doesn't boot up and start
I can't start the computer in Windows XP anymore because there is the "If your computer stoppt.... " and then goes to "Safe Mode - Safe Mode with Networking ect.". I left it with "Start Windows Normally" but after it counted down to start, it repeat it again and again. If I go to F2 Set up, it will not do anything and any command is ignoured. What can I do to start the notebook (model Acer Aspire3610) Thanks! I wrote that email from another computer!
  • varn Jan 28, 2009
    Thanks Geekman, did everything you proposed but have to re-install at the end of day. Still some problems because may be the BIOS damaged and can't get from Acer no download. But thanks for your comment again! Varn
  • Acer Master
  • 32,281 Answers
When you computer starts select Last Known good configuration,
if this deosn't work then select Safe Mode.
Then goto Control Panel - System - Hardware -Device manager to see if there are any problem devices ie item with the yellow ? against it.
The problem devices may need the drivers installed again.
If Safe Mode does not work then you need to bootup with the Windows CD and do a System repair.
If this does not work then use the ACER restore CD
If you have lost the ACER CD then you need to reinstall Windows with a Windows XP CD and then install SP2 and SP3 plus all your other programs.
Posted on Jan 28, 2009
Safe mode on a computer
When you start the PC, as soon as it hums up start hitting F8 button. The black window with a bunch of safe mode options will show up, select the one you need.
Aug 27, 2014 | Microsoft Windows XP Home Edition
Tip
How to boot up in safe mode from Windows XP
Showing the steps to boot up in safe mode from Windows XP.
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
1.If the computer is running, shut down Windows, and then turn off the power.
2.Wait 30 seconds, and then turn the computer on.
3.Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. 4.To resolve this, restart the computer and try again.
5.Ensure that the Safe mode option is selected.
6.Press Enter. The computer then begins to start in Safe mode.
7.When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
1.Close all open programs.
2.Click Start, Run and type MSCONFIG in the box and click OK
3.The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
4.The computer restarts in Safe mode.
5.Perform the troubleshooting steps for which you are using Safe Mode.
6.When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer.
Select your steps to boot up into safe mode to your Windows XP System.
Other relative articles: Crack windows password from system SAM files
How to reset Windows administrator password if forgot Windows Xp/2000/2003/2008/Vista/7
on Apr 16, 2010 | Computers & Internet
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Laptop turns on, goes to first screen which reads IBM TRHINKPAD. THEN FLASHES OFF TO NEXT SCREEN WHICH READS THE WINDOWS XP LOGO then it goes black and doesnt come back on
Your installation of Windows is most probably corrupted. Try pressing and holding the F8 button on your keyboard when the 'IBM THINKPAD" screen disappears. That should bring you to a Windows menu where you can select various modes. Select Safe Mode and press enter. If it boots, then you know that something's wrong with Windows and not the notebook itself. What have you installed prior to this problem? Maybe you should try uninstalling it while in safe mode, and then try starting up Windows normally again.
If your windows doesn't start anyway, you should get some live OS (OS that can boot from CD) like Ubuntu or Puppy Linux, so you can save the data from C: partition (burn it or copy it elsewhere) and then reinstall your copy of Windows XP.
Sep 01, 2011 | IBM ThinkPad R32 2658 Notebook
It's a dell monitor e2010h and it starts up then runs post op then it goes into a black screen and a cursor
That is the computer problem, try booting in safe mode to see it works OK, if it does, you can try uisng system restore to take it back the known working date before the problem start.
Hit F8 key while booting up if you use XP.
XP: http://support.microsoft.com/kb/315222
WINDOWS 7: http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
Aug 23, 2011 | Dell E2010H Monitor
I cannot get passed the loading screen. Doesn't boot up. Just seems to go in a loop.
Hi, try go to safe mode ( before loading screen, press F8 and select safe mode, ) if it goes on to safe mode, goto; Start ->Run..->type msconfig ->goto stratup startup.
uncheck all the entrys, and boot the machine normally, if it boots normally, start adding the entrys one by one, until it failes to start. report back.
Apr 06, 2011 | Computers & Internet
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
My computer suddenly shut down and doesn`t start anymore
When you start it, before the Windows logo, try to tap to F8 key ... if you get the advanced boot options, try to go to Safe mode.
Do let me know if you are able to boot to safe mode.
Nov 18, 2009 | Acer ASPIRE 5720-4649 Notebook
Computer wont start in safe mode
Click On Start---> Run---> MSCONFIG---> click on BOOT.INI --> Then Click On Safe Boot --> Click Apply And Click Ok---> Restart Your system u'll get what u want.......... Temme If u need any help in virus removal...
Plz Rate This Solllution If It Works For u
May 21, 2009 | Microsoft Windows XP Home Edition
After booting process done. Screen goes blank and Keyboard not working only Mouse cursor is dispaly and working on the blank screen in My acer Laptop.
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, F8 key on your keyboard. When Windows Options menu appears, scroll to select the Safe mode menu item, and then press Enter.
Select "Last known good configuration" then press Enter.
If that doesn't work reboot again and keep tapping on F8 to Safe Mode and instead of selecting "last known good configuration" select "Repair Your Computer"
Or you can try this:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  1. Place your Windows XP set up disk in your CD drive.
  2. Turn off your computer and change your BOOT order to boot from CDs first.
  3. Turn your computer back on.
  4. Press any key on your keyboard when it asks you to.
  5. Press enter when you see a blue screen, one of the options should say, "To setup Windows XP now, press ENTER.".
  6. Press enter to start the windows set up.
  7. Accept the Licence and Agreement and confirm that the setup is searching for current versions on XP.
  8. Press "R" when the set up has found your current version of XP.
  9. Notice that the Set up is deleting all your windows xp files and replacing them. (This will not cause loss of data)
Jan 11, 2009 | Acer Aspire 5610 Notebook
Acer Aspire 3610 Notebook Logo
73 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
