Question about Jandy Aqualink Rs4 One Touch Control System Control System
Pushing the reset button on my RS4 interface does not clear the old programs. How else can I get rid of the old programs?
I purchased a brand new interface and it reacts the same way. Pressing reset on the outside controller also doesn't reset the programs
    Top Expert:
  • Jandy Master
  • 5,096 Answers
Go to system setup go to clear push clear memory then push reset on front of aqualink top board
Posted on May 28, 2015
  • 22 Answers
SOURCE: Need to clear a program from my aqualink
Start with the cancel button. It will then prompt you to cancel the desired program. Go through the menu as you would with a program but follow the prompts to cancel. Remember, press cancel to start.
Posted on Dec 30, 2008
  • 22 Answers
SOURCE: I need to clear a
Start with the cancel button and follow the prompts
Posted on Jan 01, 2009
PartsCenter
  • 125 Answers
SOURCE: Jandy Aqualink RS4 controller won't turn lights on/off
AquaLink Trouble shooting guide
Posted on Feb 26, 2009
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
  • 368 Answers
SOURCE: Aqualink RS4 keeps turning on
This issue sounds tricky. I recommend you callthe Jandy technical support at 800-822-7933 and they should be able to help youfigure this issue out.
I hope this helps.
Posted on Sep 14, 2011
Aqualink rs4 manual pdf
hit cancel after that shows up for each program that will get rid of them or you can write down all the information then hit clear memory and reprogram all you auxs
Aug 27, 2014 | Jandy Aqualink RS4 Pool/Spa Combo -...
Need to reset handset
IP Reset
IP Reset returns the basic network settings to their factory defaults. You can perform this operation from the
base unit or one of the handsets.
The following settings will be reset to their factory defaults:
DHCP setting (restored to DHCP on
• Settings related to static IP addressing (the values for static IP address, subnet mask, default gateway,
DNS1, and DNS2 are cleared)
• DNS settings for DHCP connection cleared
1.2 Reset and Firmware Update
1.2.1 Reset
1.2.1.1 Resetting the Network Settings IP Reset
Performing IP Reset from the phone user interface see 2.1.4 IP Reset restores the basic network settings
made through phone user interface programming or Web user interface programming to their factory defaults.
If the unit is unable to connect to the network after changing network settings, you can restore the network
settings to their factory defaults by performing IP Reset, and then try configuring the settings again. Settings
such as the phonebook data, are not cleared by this feature.
• DHCP setting restored to DHCP on
• DNS settings for DHCP connection (cleared)
• PHY settings (speed and duplex mode of the either LAN or PC port are restored to "automatic")
• VLAN (Virtual Local Area Network) settings (disabled)
• Terminal number settings (restored to "automatic")
Notice
After performing IP Reset, the unit will restart automatically. To avoid problems, it is recommended that
you save your settings before performing IP Reset.
Note
If these settings (with the exception of PHY settings and terminal number settings) were made through
Web user interface programming, the set values made through Web user interface programming
remain effective, even if you perform IP Reset. To reset these settings to their factory defaults, perform
Reset Web Settings from the Web user interface again.
Document Version
2010-08
Administrator Guide
www.InternetVoipPhone.co.uk ' sales@internetvoipphone.co.uk ' 0800 088 4846
Firmware Update
configuration file programming, the set values made through configuration file programming remain
effective, even if you perform Reset Web Settings.
Resetting the Settings Made through the Web User Interface
(Reset Web Settings)
Performing Reset Web Settings from the Web user interface see Reset to Defaults) resets the
settings made through the Web user interface to their default values.
When you use this feature, the unit will return to the status just after performing the most recent provisioning
or pre-provisioning.
Notice
After performing Reset Web Settings, the base unit will restart automatically. To avoid problems, it is
recommended that you save your settings before performing Reset Web Settings.
Note
The settings configured through the phone user interface only will not be reset. However, settings that
can be configured through both the phone user interface and Web user interface will be reset.
1.2.2 Firmware Update
You can update the unit's firmware to improve the unit's operation. You can configure the unit so that it
automatically downloads the new firmware file from a specified location. The firmware update will be executed
when the unit is restarted.
For details, see Section 6 Firmware Update.
Provisioning server
Firmware server
Configuration
file
A
Firmware
C
B
A Download
B Check for update
C Firmware download and update
34
Administrator Guide
Docume
Jan 16, 2013 | Panasonic KXTPA50 Phone
How make factory reset on kyocera fs-2020d
Looking to get rid of 'Install MK' message - any way that i can reset so i dont have to purchase a main kit?
Jan 24, 2012 | Kyocera FS2020D ECOSYS Monochrome Laser ...
My KD12mm dishwasher's dial seems to get stuck half way through the cycle and keeps washing for hours, wasting water and electricity. I has the same problem with my old Indesit and got rid of it. Can...
This seems a clear case of the timer program controller ebing faulty. The stepper motor has struck on to a point or the gears are worn out which causes the motor not moving the position.
The only way is look carefully and maybe resetting the stepper motor so that the timer moves.
If not the cost of a new program controller must be cheked.\
Present day electronic processors for programs are highly reliable which must be thought of in your next purchase.
Jun 13, 2011 | Kelvinator Dishwashers
How do I delete an Aqualink RS4 program? The filter is on all the time. When I set a new program start and stop time the controller keeps adding programs versus replacing an/the existing programs.
to delete a program go to system set up go to programs add or delete or edit if doing on its own disconnect spa side remote if goes away replace spa side remote if no spa side reset board clear memory and re program write down all auxs and JVAs
Dec 26, 2010 | Jandy Aqualink Rs4 One Touch Control...
Just bought this home and have an 8 year old model of AquaLink rs4 - how do I cancel existing programs
On the face of your control you will find a small hole on the lower right side that you can put the end of a toothpick oe a paperclip in. That will clear all programs if you push something in it.
Oct 27, 2010 | Jandy Aqualink Rs4 One Touch Control...
I have a digital wall timer that allows for settings over multiple days. Trued to reset it (remove a few memorized settings) by pushing 'reset'; but this had no effect. Do I need to press it for a longer...
You posted the question under ST01C timer.
This timer will clear all programs if you hold reset in for a few seconds until the screen starts blinking 12:00. The reset button is a small round button that you push with a paper clip.
The ST01C memory for current day can be cleared by removing battery for a couple minutes, but the day-to-day programming remains forever until timer is reset.
Each timer tends to follow the same pattern as described above when there is a small round reset that is pushed with a paper clip >> push, hold for a few seconds, timer resets.
Other timers have a larger button for Reset ... the timers with larger reset button usually require you to hold the clock button and reset button at the same time ... or some other button besides clock has to be pushed at same time with reset. You can try different combinations of buttons and hold both down for a few seconds.
If you reply to this response with your exact model and brand timer, I can look up the specifics for most timers
Oct 18, 2010 | Intermatic Inc. ST01C Digital In-Wall...
How can I clear out the programs already in the system and start over
Their is a small reset button on the front of your controler. It is inside the cover and you will need the like of a paper clip to put in the small hole on the lower right side of the control. Just push that and it should clear all programs out of the memory, then you are ready to start over.
Apr 28, 2010 | Jandy Aqualink Rs4 One Touch Control...
Dec 26, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
136 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
