Question about HP Pavilion p6-2330 Desktop PC
How do I install a radion hd 7770 graphics card in the hp pavilion p6-2330 desktop pc
    New Friend:
How do I install a XFX Radeon 7850 I've put the card in disabled my on-board vieo but it's still not being recognized if you can help email me brandonkirby420@gmail.com
Posted on Jun 30, 2013
  • joecoolvette
    joecoolvette Jul 03, 2013
    We're not allowed to email back, and forth Brandon......or at least if 'we' are....we shouldn't be, (Going out of the realm of FixYa, you can't help determine who you will get....Or WHAT they may do.....such as as to Remote Support for your computer.....this = NO) The first thing to do Brandon, would be to put the XFX Radeon 7850's Installation disk in your optical; drive, and install ALL software, (NO toolbars though, if you catch my drift.....No Ask.com toolbar, no Google toolbar, no anti-virus program..) You want to install the drivers, AND the Nvidia Control Panel, that's IT........THEN following anti-static procedures, open the computer, and physically install the graphics card........Why? 1) Driver: Small piece of software that allows the Operating System to communicate with a device.....What version of Windows O/S wasn't stated.....the device is the graphics card.....2) When a device is installed on a computer that has Windows on it, Windows 'breaks it's neck' to find suitable, matching drivers..if THE drivers are not there, Windows will install one of it's Thousands of generic one size-fits-alll driver/s.....This = NO........Software installed FIRST, then physically install the graphics card..........What to do now? A) Unplug computer from power. B) FOLLOW Anti-Static Procedures, (Don't know? ASK....Otherwise you'll static shock out your computer, and have an expensive paperweight)..C) Remove the monitor cable from graphics card. D) Physically remove the graphics card. E) Press the Power On button in, and hold in for a count of 10 seconds. Let go...Do this 2 more times.....What you are doing is removing CMOS Error Codes, and resetting BIOS Setup back to the factory default settings...One of which is using the Integrated Video, (OnBoard Video) E) Plug back into power. F) WAIT 1 minute. G) Turn the computer on. H) Install ALL software as previously stated. Let the computer run for a few minutes. (Computer will NOT use the graphics card's software, UNTIL the graphics card is inserted. It will keep using the Integrated {OnBoard} software) Now turn the computer off normally, unplug from power, follow Anti-Static Procedures. Physically install the graphics card. Plug the monitor into the graphics card. Reinstall the computer case Side Panel. Plug computer into power...WAIT 1 minute, turn the computer on.......you may have to go into Nvidia Control Panel, and set the Screen Resolution of the monitor, to it's native resolution.....(Don't know? Look for the monitor's specifications online...see what the resolution is....Example: 900 x 1280 ) Awaiting questions, Regards, joecoolvette
  • HP Master
  • 5,660 Answers
1) FOLLOW Anti-Static Precautions
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve yourself of Static BEFORE reaching inside your computer.
Computer on a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface of the metal frame, of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
2) How to open the computer case:
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64180&taskId=101&prodSeriesId=5295969
Scroll down to the bold subheading -
Service and maintenance information
Click on - Upgrading and Servicing Guide / 27Sep2011 / PDF /2.23
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name above, it may take up to 30 seconds before the first page comes up.
Use the Down Arrow at top, and go to Page 14 - Add-in card
This is a look at the motherboard,
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c03499435&prodSeriesId=5295969
Scroll down a little to the photo of the motherboard.
That's how it looks in your computer case, with no hardware components attached, nor cables.
The long Blue, and long Black slots; are the Ram Memory slots.
To their left bottom corner is the long black PCI Express x16 slot.
Where the graphics card goes in.
On it will be a Lock. It is on the Right side.
Looks as though you push down to unlock, but it isn't. You GENTLY pull up a little, to unlock.
STOP
Computer turned on, Windows loaded, put the Installation CD disk that comes with the graphics card; into your optical drive. (CD/DVD drive)
Load all software.
That will be Drivers AND the Catalyst Control Panel.
If there is an option to install one, or the other -> NO.
Use the option to install BOTH.
[Driver: Small piece of software that allows the Operating System to communicate with a device
The device is the graphics card. It has it's OWN specific drivers on that disk. Windows does NOT have them.
What version of Windows operating system wasn't stated ]
Done?
Good. If you are asked to restart your computer -> NO.
Close all windows, go back to your desktop screen.
Now turn your computer off.
Unplug from power, remove all cables, open the computer case, and follow Anti-Static Precautions.
(IF you are not SURE where all the cables go, now is the time to makes notes, and a drawing; BEFORE you remove them)
Keep the graphics card horizontal to the PCI Express x16 slot.
Line the gold plated contact pins on the bottom of the graphics card, with the slot.
Gently pull up on the Lock, as you push the graphics card straight down into the slot. (PCI Express x16 slot)
At the same time you have to align the metal mounting bracket, on the graphics card; with the outer metal frame of the computer case.
The metal mounting bracket has a Tang on the bottom. This slides in-between the motherboard, and metal frame of the computer case.
The top of the metal bracket usually has a half-moon cutout, and/or a small hole.
The hole aligns on a small dowel pin, in the metal framework of the computer case; IF there is a dowel.
The cutout does the same.
(Usually one, or the other is used )
Metal bracket MUST be flush, and in place; before it can be locked in place.
The locking mechanism is a small rectangular metal plate, according to the Upgrade guide.
Has a Philips head screw which holds it in place.
Screw removed it is slid off.
Graphics card installed the metal plate is slid back into position, and screw remounted.
(Yes. Sometimes it's a 'juggling act'. You may have to keep the metal brackets of the other add-in cards in place, AND the graphics card metal bracket; while sliding that locking plate back into place )
Connect the monitor to the graphics card.
Reinstall all cables. Plug back into power. WAIT 30 seconds, turn the computer on.
Some monitors require using their drivers. If so the monitor will come with an Installation CD disk.
Even if you do not have the disk, and the monitor requires drivers; you can download AND install from the monitor manufacturer support website.
Screen messed up?
Maybe because your monitor needs those drivers.
You cannot run the native resolution for the monitor, without the drivers.
(NOT stating your monitor requires specific drivers. Stating it MAY require them.
If adjusting Screen resolution in Display Properties does no good, the monitor does)
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jan 24, 2013
  • 103 Answers
SOURCE: Power supply
The Hp PWRSPLY-250W power supply would be compatible when upgrading your graphics card.
please rate me. thank you.
Posted on May 28, 2008
sandro_monte
  • 72 Answers
SOURCE: HP Pavilion a705w PC Desktop\Ethernet Controller driver
obtain the driver from cd/dvd that was included as you purchased your desktop and try to check if the driver supports with the operating system you are using now. for example the driver available in your cd/dvd is only for windows xp and your operating system you are using now is windows vista of course driver not installed. try to download from internet the driver that are suite to your unit model and current operating system this can fixed your problem or else downgrade your os tha can support the driver that are available from your cd/dvd.
Posted on Oct 11, 2009
  • 73 Answers
SOURCE: HP Pavilion audio disappears with new graphics card.
Hi
The Pavillion systems normally have just enough power to support the comonents that came with it if you are putting a bigger graphics card in it could lack power on other componets thus causing the issue to solve your issue you will need more power check on what is recommended for the graphics card you are inserting I would say 400w should be ok depending on how power hungry the graphics card is
thanks
Posted on Nov 26, 2009
akgamit
  • 59 Answers
SOURCE: HP Pavilion a320n PC Desktop - won't turn on
Please visit the link given below and follow the steps to resolve the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&cc=us&lc=en&dlc=en&product=364171
Posted on May 29, 2010
Smith-alone
  • 360 Answers
SOURCE: Can you install a graphics card in the HP pavilion
Hi, yes you can but you have to follow the instruction on the HP website on how to do that. Visit the link below to learn how to do that..
https://h10025.www1.hp.com/ewfrf/wc/document?docname=buh06273&lc=en&dlc=en&cc=uk&product=445595&lang=en
Take care
Posted on Jul 18, 2010
Will Windows 7 install on my HP Pavilion?
You should run windows upgrade advisor as I don't think your specs meet the requirements
Mar 18, 2014 | HP Pavilion a600n PC Desktop
I have a HP Pavilion p6110f Desktop with the video signal that goes in and out..
Buy a Graphic Card PCI e x16 compatible. Install, Move the monitor cable to the new card connection and your good to go, with better graphics. If you haven't installed a Graphics Card before, do a little research. Take a look at this for example: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01684404&tmp_task=useCategory&cc=us&dlc=en&lc=en&product=3970026
Dec 29, 2012 | HP DT PAVILION P6110f DESKTOP PC
I tried playing some games (the witcher is a good example) on my moms pavilion a6720f and found that even though my system meets the min. reqirements, the graphics are really choppy and make the games...
You may need to install a graphics card, or download the latest drivers for your current graphics card on the Nvidia website.
Click here to download them, fill in the fields pertaining to your graphics card.
Happy Gaming!
damnor01
Jan 30, 2011 | HP Pavilion a6720f PC Desktop
I cannot get sound. installed new video graphics card ati hd 4350 512 ddr2. are there audio components on this graphics card?
NO sir audio component are not available on graphics card. Please install the audio drivers to get the sound.audio driver c.d is available on your distributor.
thank you.
Sep 13, 2010 | HP Pavilion M9040N Elite Desktop PC
What graphics card will fit in HP Pavilion Slimline s5510t?
Here's the link:
http://www.shopping.hp.com/webapp/series/category/desktops/s5510t_series/3/computer_store
Look in the Graphic card section for choices.
If you have integrated graphic in your PC, and you want to install another graphic card, you will need to disable the integrated one.
Hope that helps.
Aug 22, 2010 | Computers & Internet
Hi. I was buying HP Pavilion slimline 5310sc and want to put a new graphic card in it, to play games. What cards would fit best? Bjarki
Graphics cards are of many companies. For my opinion, Ge-force and N-vidia graphics cards are best. 512 mb graphics cards are well for playing games. As your need of gaming, buy high capacity graphics card as 1 gb or 2 gb.
Jul 30, 2010 | HP Pavilion Slimline s5310f PC Desktop
disable the VGA integrated mode from bios first then plug the graphic card.
Nov 25, 2009 | HP Pavilion Media Center a1330n - AMD...
Power supply
May 28, 2008 | HP Pavilion 763n PC Desktop
HP Pavilion p6-2330 Desktop PC Logo
470 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
