Question about Sony Ericsson K550i Cellular Phone
My phone has just stopped vibrating
I am not sure what has happened i have it set to vibrate but it doesnt and this is realy starting to annoy me could you please help me out
    Sniper:
  • 58 Answers
Check again ! Did u set it to Vibrate On if Mobile is in Silent or Only 'ON'.
hope u'll get it.If not contact service center near in ur place.
Posted on Jan 31, 2009
I have a clunking noise ciming from transmition/ transfer case when accelerating.
This may be in the transfer case or transmission, the best thing is to have a transmission shop look at it before something lets go and shoots out of the case, from what you wrote it sounds internal, being at a stop and having this vibration tells me internal,
Nov 24, 2012 | 2003 Chevrolet Silverado 1500
Why my nokia C3 doesnt ring accordingly although i set the ring tone already?its only vibrate.i'm not using silent mode.
I can imagine it how annoying it would be to you to see your cell vibrating instead of playing your favorite ring tone. Most probably it could be because of incorrect Profile configuration. It is possible to make your phone vibrate in almost every profile so we will assume that it is the reason for your problem too. Do the following and check some parameters as described.
1. Go to Menu > Settings > Profiles
2. Select Profile and then Select General.
3. After selecting General you will be given 3 options (Activate, Personalize, Timed)
4. Select Personalize.
5. In the Incoming Call Alert field, select Ringing.
6. In the Ringing Tone field, select your favorite ring tone.
7. Scroll down, (push down button) the next field would be Ringing Volume. For now select the max.
8. Scroll down to the Vibrating Alert field and set it to Off.
9. Scroll further down thill the very last field where it says Alert For, select All Calls for this field.
10. Save your modifications.
11. Activate the profile and see if it works now.
Only and only If it doesn't work, it may be due to software corruption.
In that case reset your phone to the factory default settings by going to:
Menu > Settings > Press UP button.
Select Restore Factory Sett. give your Security Code (default = 12345) and viola.
(Make backup of your messages ad contacts before attempting this)
Jun 04, 2011 | Nokia C3 Cell Phone
Every time I would get a message, It would say "message recieved from" and who ever would send it. I turned my phone on silent and it would still do the same thing. This has never happened before and...
well to me it could be something in you msg settings... check and see if your phone is not set to wear it sounds off like that even when on vibrate or silent!....
Nov 23, 2009 | LG Xenon GR500 Cell Phone
Vibration rattle coming from the front behind and under dash
hi, the inner wheel arch linings should be made of plastic,( if my memory serves me correctly ), make sure that all of the plastic rivvets are in place, .....it doesnt sound like a very serious problem, it sounds more like cosmetic than mechanical
Aug 19, 2009 | 2001 BMW 330
HTC Touch Pro Won't Vibrate
So you having problem with vibrate capability?
Try this:
1. Make sure your phone not in charging (it won't vibrate for several phone like e.g. NOKIA)
2. Have you dropped it? If yes, immediately contact the customer service.
Hope this will help! PM me if there's any questions =]
Jul 07, 2009 | HTC Touch Pro Smartphone
2004 dodge ram hemi wont always start up
this is your camshaft pos. sensor
Mar 28, 2009 | 2004 Dodge Ram 1500
Samsung i616, Ringtone file corrupted
Best way I have found is to use explorer and browse into your mobile device and search for a folder called "volatile". I copied every wierd looking folder that started with XME or such. There were like 999 of them on my phone. Once they were removed, everything went back to normal!
Mar 13, 2009 | Samsung BlackJack Smartphone
What can I do to stop that annoying beep sound
Usually that "beep" alert is an indication that your phone is NOT on vibrate, but on "beep". Check your side volume keys and make sure that your setting is on vibrate, then click "ok" to confirm your changed preference.
Mar 13, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Plz help me with vibration problem
I had this problem with my Nokia although it was a bit older than your phone!
If you are sure that the settings are correct and it should be vibrating then get someone to call you and while it is ringing, knock the phone gently on a table.
If the vibrator is stuck then it may free itself and start working again.
It worked for me.. But my phone was 2 years old and used in a gritty environment.
Good luck.
Oct 16, 2007 | Motorola Mobility MOTOMING A1200...
Sony Ericsson K550i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
