Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Reset ccu on Whirlpool 8540321
Cycles do not work properly
Ho do I reset the whirlpool error codes f6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Whirlpool Duet error f6 Google Search
Sep 06, 2014 | Whirlpool Duet WFW9151YW 27" Front-Load...
F1e1 error codes
Check the harness from the ccu .If all in tacked replaced the ccu.
Apr 29, 2014 | Whirlpool duet Washing Machines
Whirlpool aquasteam 6 sense model number 859297015700 error code f26
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa
Mar 04, 2011 | Whirlpool Washing Machines
Error message F22
HI. This error occurs if the touch pad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Possible Causes / Procedure
1. Check the touch pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the touch pad/LED assembly and Central Control Unit (CCU).
Replace failed component.(Which will be the actual CCU, if the wirineing harness is ok, and connected properly)
Feb 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport dryer getting an f26 error
DOOR SWITCH ERROR
Thanks for using FixYa*&^
Nov 27, 2010 | Whirlpool GEW9250 Electric Dryer
The door locks when the start button is pressed, but the cycle will not start. Diagnostics shows F26 door lock assembly. Whirlpool WFW8300SW. I have replaced the CCU and it still locks but nothing happens...
DOOR SWITCH ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Feb 18, 2010 | Whirlpool WFW8300SW
I am getting an F21 error code
This error occurs if the touchpad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding.
3. Check wire harness connections to the touchpad/LED assembly and Central Control Unit (CCU).
NOTE_ If the touch pad and CCU are connected properly, and the connections are not worn, or split, this will confirm that the CCU will be the culprit. Have it replaced, asap.
Jan 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Had f22 error - can't unlock door; tried CANCEL, tried RINSE/SPIN, tried UNLOCK, unplugged - door won't unlock
HI. This error occurs if the touchpad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Replace failed component.(Which will be the actual CCU, if the wiring harness is ok, and connected properly)
Oct 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I lost my manual and I am getting an F22 display. What does this mean?
CCU/Touchpad/LED assembly error(F-22)*
Hi.This error occurs if the touchpad/DED assembly is not able to transmit/receive data to/from the central control unit (CCU)
Check the following:::
A.Check the touch-pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch-pad/LED is responding. If the results are negative, move on to the next step.
B.Unplug washer or disconnect power.(Make sure you unplug the unit for 5 minutes, thsi will reset the panel, and restore proper functions if the damage inst severe)
C.Check Wire Harness connectors to the touch-pad/LED assembly and Central Control Unit (CCU)
***((Ok, if all fails to revive proper functions above, this will confirm a major issue that concerns the wiring harness that is used to link the touch pad to the CCU))
Sep 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet Control Locked button cycles on and off
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
If the troubleshoot below does not work, then the problem may be a defective CCU.
The front light lit on my Whirlpool.
Regards.
Jun 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
