Question about JAKKS Pacific Spider-man Spider Sense Plug And Play Tv Game /marvel Tv Games
Why to plug in on Sony tv - JAKKS Pacific Spider-man Spider Sense Plug And Play Tv Game /marvel Tv Games
Our Sony TV is connected to cable box when you turn it on the cable box and tv comes on then the tv goes off then you have to pick tv then power to get the tv to stay on why?
Sounds like you have the TV power connected to the switchable power connection on the cable box. Just plug the TV into a separate power wall plug.
Sep 02, 2017 | Sony Televison & Video
Sony KE-42TS2U. Nothing happens when the TV is
Seems some thing wrong with power input plug or may be with power board in side the tv. first confirm with different power socket.
Oct 07, 2013 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Emerson TV will not work with Sony Earphones
Found the problem -Emerson TV has only one circuit audio outlet and that
is being used with my HD Box - I have now spliced the red and white
connections from the Hd Box connection to TV - plugged
the spliced red and white connection into the red and white plugs and
its a done deal. Everything works just fine,
Feb 05, 2013 | Dynex DX-LCD37 TV
On the sony bravia what ports and what channel of the TV should I plug the cable into for WII? I have tried pliging the wii in but don't know which ports are the right ones and what channel the TV should...
it all depends on model of sony bravia tv, the wii comes with a scart adapter that the white red and yellow phono plugs, plug into so justr use the scart socket , if you have no scart sockets plug the three leads into the composite plugs on the tv
Apr 08, 2011 | Televison & Video
Want to see my laptop screen on my sony lcd tv
First I need to know what model laptop and if your Tv has rca a/v inputs.
You can buy a vga to rca converter online or if you have a video out,little yellow plug in on the laptop then you can plug it right into your yellow rca a/v input on your tv.
here is a link.
http://www.geekwithlaptop.com/how-to-connect-laptop-to-tv
Mar 20, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Got a 42 sony monitor yet need a TV conversion...
HI,
You can use it as TV through Monitor device (also known as cable device) and are very commen in market also in cheap prices, which specifically designs for monitors, just plug you monitor with the device and plug your antenna with the device and enjoy it.
Thanks for using fixya.
Jul 28, 2009 | Sony Televison & Video
110 sony flat tv was plugged in 220
change the regulator of your tv and check also the resistor value 2.2 5 watts or lower value.
May 09, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Connecting RCA plug to speaker wires
You can connect the RCA plugs to the speakers. But, as for using the red/white Audio outputs you may need an amplifier, those connections are used when going into a dvd or vcr that boosts the signal in their own environment. If you have a connection for headphones on the TV you might have better luck there for the speakers.
Jan 11, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Sony ps2
Try Plugging the Ps2 into another TV if it works then its probably the TV or you plugged in the 3 coloured plugs wrong you mite wanna try it in front or behind the TV.
Mar 11, 2008 | Sony PlayStation 2 (PS2) Compact System...
JAKKS Pacific Spider-man Spider Sense Plug And Play Tv Game /marvel Tv Games Logo
Top JAKKS Pacific Televison & Video Experts
Electro Med Services...
Are you a JAKKS Pacific Televison and Video Expert? Answer questions, earn points and help others
