Question about Hotpoint NBXR463EBWW Electric Dryer
Installing belt on a hotpoint eletric dyer
What do i have to take off to get the belt on? i have the top off already it looks like the dryer has the back and sides as 1 piece.
  • rickb736 Jan 27, 2009
    I See Them. Thank You Very Much! Have A Great Day!
    Problem Solver:
  • 5 Answers
Look inside at the front panel from the top down. On each side you will see a screw on each side holding the front panel in place. Remove the screws and pull the front panel foward. The front sits on two pins located on the bottom on the left and right. Lift the panel up and move to the side, be careful not to pull the wires off of the door switch. The belt will go over the drum , you will see a mark where the belt runs on the drum. You will not be able to see how the belt goes on but it makes a "S" shape around the motor and idler pulley.
Posted on Jan 27, 2009
  • 979 Answers
Envision the belt as putting a chain on a bicycle. Put the belt in place on the drum. There will probably be a groove to put it in and then start it on the pulley of the motor. Once you have it in place, simply turn the drum by hand a little bit and it should slip all the way onto the pulley. If there is a block or something in the way of you putting it on, you will have to loosen it first. Normally there is not.
Cant get top off dryer vtd00
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Picture of how the dryer belt for a hotpoint electric dyer goes in
Hi cherylannroo....
Here is a picture of how to route your belt.
Please take time to rate me
Sep 26, 2011 | Hotpoint Dryers
Install dyer belt MAYTAG
Hello there
Here is a detailed instruction for you ok
  1. Remove the two screws that hold the control console to the dryer; they are located on each end of the console. Turn the control console forward onto its face. Disconnect the wiring harness from the dryer to the console. Press in on the locking tab and pull the connectors apart. Set the control panel out of your work area. To remove the top, insert a putty knife between the front and top panels. Locate the retaining clip and push in on it to release the corner of the top panel. Lift up on the corner and release the opposite retaining clip. Set the top panel out of the way. Two screws that attach the front panel to the sides are located at the top corners. Remove the screws and swing the top of the front panel out so that you can access the door switch wiring harness. Disconnect the wiring harness from the door switch and lift the front panel away from the dryer.
  2. Replace the Belt
  3. Locate the idler pulley by reaching behind the drum and motor assembly. Using your hand, push the idler pulley to the left to release tension on the belt2.gif. Notice the routing of the belt around the motor and idler arm for reference when attaching the new belt. Remove the belt from the motor pulley. Lift up on the drum slightly and remove the belt from the drum.
    With the rib side pointed inward, lift the drum up and set the belt around the drum. Route the belt through the motor pulley and idler pulley. Pull the idler pulley to the right to reapply tension to the belt. ok?
  4. not too hard
  5. hope this is verry helpful for you
  6. Best regards MIke
Oct 15, 2009 | Maytag PYE4500AY Gas Dryer
Model DE 106, eletric dryer. Will not start. Turn
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
Jul 12, 2009 | Dryers
How to install a hotpoint electric dryer belt
Click the link to take you the belt diagrams page. Choose your brand and model number and the diagram will load. You will need the model number located on the product information tag, normally located inside the door or on top of the control panel.
http://www.repairclinic.com/0079.asp
Jun 30, 2009 | Hotpoint TDL15 Electric Dryer
How to install a belt for a frigidaire dyer how do i get the belt around the dyer
You must get the top up then you can easily remove the front then get that drum out clean everything oil everything and replace that belt. Very easy use my simple GUIDE
Apr 01, 2009 | Frigidaire GLER642A Electric Dryer
How to remove top on hotpoint 473e dryer , a need to change the drive belt
top should pop off use screw driver to pry apart there are 2 clips on the corner then lid should lift up
Feb 20, 2009 | Hotpoint NBXR463EBWW Electric Dryer
Hi there I am trying to replace a belt on my old dryer how hard is it
If you have a NVL333EY which you posted under, I'd rate the repair a 4 on a scale of 1 - 10 in difficulty. That Hotpoint model is actually manufactured by Frigidaire / Electrolux and sold through GE as a Hotpoint. (Hey, it's a global economy, right?)
Disconnect power to the dryer. Use a putty knife to push in the seem of the front panel with the dryer top to release the dryer top, allowing it to swing back. You may be able to use a phillips to remove the screws holding the front panel, but a #2 square drive works much better. Slip new
134503600 belt around drum from front. Put front panel back on. Remove 4 screws (again the #2 square drive works best) holding the back access panel at lower left back side to allow you to finish belt installation. Belt grooves touch the drum. The worst part is keeping the spring from falling off when you put the belt tensioning wheel on. After you have the belt installed, give the drum a turn by hand to make sure everything is OK before you close up the top and reconnect power.
Dec 07, 2008 | Hotpoint NVL333EY Electric Dryer
How to open the dryer and replace the belt
all dryers open from the top so open the dryer door and look inside the top edge you will see two screws . remove the screws and lift the top panel . the front panel has two screws on the top one on the left and one on the right remove them both and lift up the front panel to remove it. the only way you can install the new belt is removeing the front panel because the belt goes around the drum from the front. once you remove the old belt out put the new one in . the belt goes around the drum from the front and then to the motor and idle roller . you can reach the idle roller from the front left corner or from the back of the dyer? i like to install them from the back cause its more easy. in the back of the dyer where the hose goes connected to the blower is the top with four screws remove the hose from the blower tube and remove the four screws. after you remove everything you should be able to see the dryer motor and idle rooler put the belt over the motor first then over the idle rooler .always make sure when you do this the dyer is unpluged and after your done plug it back and turn it on to make sure it runs correctly . if it runs ok put everything back together again.
Dec 21, 2007 | Dryers
Hotpoint NBXR463EBWW Electric Dryer Logo
100 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
