Question about Montgomery Ward Sewing Machines
Brother entrepreneur pro pr1000e thread not catching the bobbin thread
The needle thread is not catching the bobbin thread. Stitches one or two then stops
  • 192 Answers
SOURCE: Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
  • Thread the needle.
  • Turn the handwheel by hand.
  • Watch the hook as it approaches the needle from right to left.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
Posted on Nov 14, 2007
RickE1
  • 202 Answers
SOURCE: Timing for Bernina Virtuosa 153
Timing these machines gets pretty involved such as in just removing the covers. You need a grounding ******** your wrist as the cables all need to be unplugged and you don't want to send a static charge from yourself to the circuit boards. They are expensive. Then you need special sized metal pins to pin several pinning points so the needle, hook, stepping motors and feed dogs all co-ordinate with each other. Also several places need certain guages to set less than .1 millimeter size distances between different places to avoid other problems. You also need several sized torx screwdrivers and the knowledge to adjust the upper and lower tensions. The upper tension alone has at least 3 or four places that need to be in the correct position.
All of the above has to be done in a certain order also.
Its complicated enough. If someone is going to walk you through this over the phone expect it to be complicated. Even if you had a copy of the manual (which could be a copywrite infringment on newer machines) you can expect it to be difficult.
My advice is to leave it to the professionals to have it done right.
Posted on Jun 20, 2008
SOURCE: the bobbin thread on sewing machine will not catch
how do you retime
Posted on Aug 13, 2008
SOURCE: bobbin thread not catching
Whenever you see loops on the underside of the fabric something is snagging the thread. the biggest culprit is burrs on the hook. the hook is what goes round and around the bobbin. The reason for burrs on the tip of the hook areseveral
ONE ...is by helping the fabric through as the machine is doing the sewing which directs the needle too close to the hook thus scarring the smooth surface of the hook and potentially breaking it off and the needle too. You must allow the machine do it on its own and only guide the material.
TWO...Sometimes if you are sewing s-t-r-e-t-c-h-y double knit material the material calls for a ball point needle. I have gotten good results with the Singer brand YELLOW BAND needle.
Three ... The hook could have gotten out of timing. What this means is that the hook is not meeting the needle on the top edge of the eye of the needle. You yourself can check this out by removing the bobbin (or shuttle, cassette). Install the needle flat side to flat side of the mounting rod and all the way up. By slowly turning the handwheel on the right slowly and watching that the eye of the needle is just below the hook on the upward swing of the needle and that they both meet dead center. This when you need to take it in to a repairman. FrankIy I don't like to advise this because of unscruppulous practices. My boss used to call me a virgin Mary because I wouldn't ripp-off the customers. Anyway at this time you can also check the condition of the hook carefully looking for nicks and scratches on or around the tip of the hook. If there is damage present you can file this down with a very fine emory board or by using a strip of 400 to 600 grit sandpaper as if your were buffing a shoe. If the hook is removeable by unsnapping the snaps on either side its easier to buff. Anything courser may contibute to the problem. If the paper won't remove the damage you may need a whole new hook. If its not removeable you will have to take it in to have it installed.They have to time it properly.
Four...The two disk that you mentioned also has a spring. That sping is there to pull up those loops. If the disks are full of lint from the thread going through. the clups of lint won't allow the discs to apply tension on the thread and thereby having tightened the tension so much that that spring is not working properly.You can clean the discs by raising the foot which opens the discs. With a long narrow pick pull out all that lint without scatching the discs. Check closely that the the thread goes across the top of the machine down through the discs pull up snug so the spring engages,through the take up arm,in the two thead guides, then into the needle front to back or right to left, if it is a side loading bobbin. Now the tension will work properly!
TESTING : Move the TENSION dial to mid point of the dial usually 5. This is your starting point.
With two layers of fabric ( not stretchy) and with a regular needle, set stitch length at about 12 per inch on the dial. Now sew about six inches. Raise the fabric and look at the results. Do minor adjustments necessary on your tension dial up 6...7.. if loose on the bottom 4...3..2 if loose on top.
If you did all the steps above those are the steps a repairman performs and charges $75 except me I used to charge $10 .
Brother machines are good quality it is those hidden gremlins that make a fun hobby frustrating when you don't have someone to turn to without having to shell out cash! Its been a pleasure!
jravenus
Posted on Nov 07, 2008
SOURCE: Thread won't catch bobbin
I hope to God nobody else pays more for a repair than the machine is worth.
It's ridiculous to spend $300 for that repair since the machine is available almost everywhere for way under $200. You could have thrown that one in the trash and bought a new one cheaper than the repair!!
I paid $129 for mine, had the same problem with two, yes, two of them, and sent them back and was sent another which so far is working fine. There seems to be a flaw in the engineering of that machine since so many people are experiencing the same problem. The machines DO have a warranty so please, please, be careful of unscrupulous repair people. Oh, I'm sorry but I need to mention that I bought my machine from eBay and it was a refurbished machine sold by Ken Sewing and Vacumm in Muscle Shoals, Al. They stand behind their products and were very nice to deal with, they even paid for the return shipping on the two that I returned. Hope this helps y'all.
Posted on Nov 10, 2008
Wont sew thread keeps coming out of needle
you have to hold the loose end for a couple stitches when starting off
Dec 16, 2015 | Sewing Machines
I'm using Brother Poly thread on my Brother PE-770. Everything was fine until I changed needles. I followed the directions exactly. But now, when I embroider, my thread keeps unraveling and the needle...
Please check your needle position, putting it in backwards is a very common error, the FLAT side of the needle shank should be towards the back. Also be sure that during the transition, that the bobbin thread did not get misaligned.
So, make sure the needle has the flat side to the back, and rethread your bobbin thread through making sure it is correct.
Jun 11, 2014 | Sewing Machines
How can I tighten the bobbin tension?
try adjusting the top thread tension
here are some link for a manual
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125_EN_272.PDF
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125i_EN_1628.PDF
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Mar 01, 2013 | Brother LS-2125 Mechanical Sewing Machine
Why are no embroidery stitches showing up, the needle moves in and out of the fabric but no stitches stay
here are some suggestions, if the suggestions don't help then the
machine needs to be checked to see if there is a adjustment or
timing problem
1. try changing the needle
2. try rethreading the machine top and bobbin
3. make sure the bobbin is turned the right way in the bobbin
case
Jan 18, 2013 | Brother PE770 Computerized Sewing Machine
My New Home skips stitches. I have cleaned it, changed needles, adjusted the tension and tried different bobbins .
Skipped stitches
it's also possible that the machine could be slightly out of time
Aug 29, 2012 | Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
I have a brother ls-2125 sewing machine. the upper thread is not catching the bobbin thread properly. help please
  1. Tension
    • Your sewing machine tension controls the rate at which the thread is fed through either the upper section of your machine or through the bobbin case. If your upper or bobbin threads aren't threading properly, sometimes adjusting the tension will correct this problem.
    Timing
    • Your sewing machine works by passing the upper thread through the needle of the sewing machine at precisely the same time the bobbin brings its thread to its uppermost position. If either the needle or the bobbin thread reach these positions too soon or too late, the threads won't interact and create the knots that make the seam. You can throw off your timing by sewing too many layers of fabric or hitting a pin with your needle. See you sewing machine repair facility to correct any timing issues.
    Thread
    • Thread can get snagged or caught in the upper section of your machine or on lint pieces in the lower bobbin section. If your threads aren't catching properly, you may be able to fix it by unthreading and rethreading both your upper thread and bobbin threads.
Oct 15, 2011 | Brother LS-2125 Mechanical Sewing Machine
Thread in bobbin area is catching and stopping machine after a couple of stitches
clean bobbin area for lint or loose thread
also under the needle plater for lint or loose threads
check the bobbin to make sure it's not warped
make sure the bobbin is inserted correctly
if none of these things help then I suggest a repair shop
Jul 31, 2011 | Brother XL-3030 Electronic Sewing Machine
Every 4 or 5 stitches the bobbin thread fails to catch the top thread resulting in skipped stitches
double check needle position and needle type. It will also do this on stretchy material, do to material catching on the thread
Aug 30, 2010 | Janome 1017 Mechanical Sewing Machine
Sewing Machines Logo
171 people viewed this question
Top Montgomery Ward Sewing Machines Experts
D. E. Hev
Les Morrison
Les Morrison
Are you a Montgomery Ward Sewing Machine Expert? Answer questions, earn points and help others
