Question about Dirt Devil Vacuums
Dirt devil 990 central vacuume won't turn on
Central vacuum won't turn on
reddevil6
  • 1673 Answers
SOURCE: wet vacuum not sucking up water
Usually when these units don't pick up the water, there is a seal or gasket missing or out of place. But you have a years warranty on this, maybe you should take it to a warrenty shop and have it checked.
Posted on Jan 29, 2008
  • 126 Answers
SOURCE: Dirt Devil M084600 Dynamite
Your roller won't turn. The belt is designed to break if anything threatens to keep the motor from turning. When you have the roller out, check the end caps to see if they rotate easily. If they do, then install a new belt being very careful that the belt is not pinched on the channel that it sits in. Once you have the belt installed, turn the roller by hand to make sure that there is no jamming or catching of anything. Install the plate and check the rotation again. Once you are satisfied that the roller turns easily, try the machine.
If the caps on the roller are jammed, as they will get from debris, hair and thread, etc., then you may have to replace the roller. The end caps on most of the Dirt Devils are carbon fibre and will break when you try to remove them.
Posted on Jan 31, 2008
reddevil6
  • 1673 Answers
SOURCE: Dirt Devil Breeze-Bagless Vacuum
You probably have a clog either in the hose , wands, or the dirt inlet by the brush roll.
Posted on Mar 13, 2008
ukvacfan
  • 328 Answers
SOURCE: Dirt Devil Extreme Quick Vac - Won't turn on
Check that the filters are completely clear and not blocked - especially the top filter on top of the bin assembly. If its clogged completely brush it free of dirt and then reassemble. Make sure the inner cone filter and mesh filter is also completely clean. Then check the hose and main dust channel - something is clogged that makes this machine overheat and stop working - and often with this model (Hoover also make it in the UK under the Alyx name) its down to clogged filters or small clogs of dust in the dust channels.
Don't forget to rate, thanks.
Posted on Mar 06, 2009
galati2k
  • 281 Answers
SOURCE: dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Posted on Apr 29, 2009
My Dirt Devil KONE Hand Vacuum won't unscrew to empty
sounds like it may be cross threaded , or bits of grit holding it tight ,try tapping round the rim with screwdriver handle to see if it will loosen anything that's holding it ,then get someone else to help you hold one end and you hold the other end and twist..
Mar 11, 2013 | Dirt Devil KONE Hand Vacuum MO213BLU...
My dirt devil keeps shutting off randomly
It's overheating. Empty the cup and replace the filters. There's a breaker that opens up and turns it off when it gets too hot. When it cools down it closes back up and it will run again. It'll argue with you til the end of time or until you fix the problem.
Good Luck
Jan 13, 2013 | Dirt Devil M085805 Upright Vacuum
Dirt Devil Ultra Vision vacuum- no suction?
Check for a clog at the neck of the "bag".
Sep 11, 2017 | Dirt Devil Vacuums
Won't pull in dirt
you need to change belt on brush and also check for locked up bearings on brush roller and or debris lodged between brush and guard dislodge if need be or replace bearings on brush roller if they are bad
Jul 24, 2012 | Dirt Devil 12 Amp HEPA Filter Vacuum...
My dirt devil model bd10025w won;t recharge when plugged in and won'yt woek when plugged in
Assuming that you've tried a different electrical outlet, it may have a defective charger or a totally dead rechargeable battery.
Try Dirt Devil's customer help line:
1-800-321-1134.
Good luck from Detroit, MI.
Jul 18, 2011 | Vacuums
Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
Jan 24, 2009 | Dirt Devil Featherlight Bagless Upright...
The belt is broken of my dirt devil
Remove brush roller and black caps at each end of the roller. Clean and oil the bearings.they must turn freely.
Dec 10, 2008 | Dirt Devil Vision Turbo W/Bonus Upright...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Vacuums Logo
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
