Question about AKG C418 Professional Microphone
Plastic housing on c419 broken
Can I get parts to replace the egg shaped shell on the c419? and inner sponge?
  • 124 Answers
Sorry that the parts list is in German, but at least you can look at the visual, see how they are put together and order the parts. Although this microphone has been discontinued, parts should still be available from AKG.
See the pdf file at the following link:
You will also find the email address and phone number of the American distributor. You can also visit akg's website at:
If my assistance helps you solve your problem, I'd appreciate your rating. Thanks for using
Posted on Jan 28, 2009
  • Bernie Thames
    Bernie Thames Jan 30, 2009
    Do you still need help? If my information was useful, I'd appreciate your feedback. Thanks!
Kenmore Elite H3 washer's loud in spin cycle & smells burnt.Debris & plastic in well inside washer.Pushed aside rubber ring & saw lg. gap btwn. metal drum & surrounding plastic.Parts needing replace?
It sounds like the drum has broken from the rear mount. This will chew up the outer shell. This is a very labor extensive job. The parts are expensive also. You will probably need a new outer shell and inner drum.
May 29, 2015 | Kenmore Washing Machines
Replaced bellow in kenmore washer still leaks
Is the plastic housing (Outer Tub) in good shape? If the old boot was ripped, It might be the spider is also broken. Can you move the inner tub by hand and see if it lifts upward? If so you might have to get a new one. I had the spider bracket in the rear of the inner tub break in 4 pieces and too expensive to weld. So I bought a new top loader.
Sep 12, 2014 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Replacing headliner cheap
You need to take all of the hardware that holds the liner up. Take the liner out slowly ,not to damage it. You will have to remove the material and or sponge by hand.(do not peel layers)A good fabric shop will have replacement material. Bring a piece of the old fabric with you to match color of fabric.3M does make a headliner glue sold at a parts house to replace material. Measure liner from front to back ,not side to side. What I am saying is like from the rearview mirror to the back glass. Add at least a foot or two more to measurement. You will have to cut out holes for the hardware after you glue it down to the shell. You will also have to roll the material over the sides and glue the backsides. What I am saying about this is there is no molding where the shell meets the rearview mirror so roll it and glue it to the backside of shell , do the same for the back glass area of the shell. Use care when spraying glue not to get glue on the fabric. When you roll the fabric over and glue it you can hold the fabric down with a folded piece of cardboard held with clothes pins .Replace shell about 8 hrs later. Do not do this on a rainy day ,make sure it is sunny or hot day . Also when you spray the glue spray the shell and the sponge side with glue but do not over saturate the sponge or board that it would seep through the material. Good Luck!
Apr 20, 2014 | 2003 Dodge Dakota Club Cab
How to open bonnet on 2003 toyota corrolla when cable release is broken
this is a lot easier said than done. the easiest way that i know and have done is gain access to the cable closest to the handle, this seems to be the most common place a cable breaks, the next would be at the latch itself. very rarely do the break in the middle. any way, gain access to the cable and cut it. once you have cut it peel off the plastic protective coating. after this is done it you should see the outer steel shell that houses the cable. most of these outer shells are not solid but more of a tight coil configuration. with a good pair of pliers you can "unravel" the outer shell to gain access to the inner cable. hold the outer cable with pliers and using another pair of pliers pull the inner cable and the hood latch should release. this is the easiest way to do it with out chewing your hands up
Mar 03, 2013 | Toyota Corolla Cars & Trucks
Bangs and sqeels during high spin cycle, also there are plastic shavings in sink
This could be an easy fix if the counter weight came loose from the top of the tub shell which is a common problem causing banging. Unplug the unit and pull the unit out from the wall disconnection the water hoses after turning of the water. Remove the back panel to inspect the counter weight, spider pulley and belt. If the counter weight is not broken you can reattach it to tub shell and retighten the bolts. If it is broke it is about $30.00 plus shipping. Inspect the spider pulley which is attached to the tub with the belt around it. If it is not broken, you can turn the pulley by hand to check the tub bearings for free movement. Make sure the belt is in good shape and attached to the motor spindle and spider pulley. If the spider pulley is broken you may have to order a new pulley. If you have to remove the spider pulley you may want to use a gear puller from an auto parts store to remove the pulley. If you turn the pulley by hand you should not hear scraping. If you do in could be the bearings or a screw is rubbing against the shell. If you have to replace the outer tub shell (approximately $300.00 for parts only). I would unbolt the bolts holding the shell and find where the tub or screw is rubbing so you do not have to replace the expensive shell.
Feb 23, 2011 | Frigidaire ATF6000ES Front Load Washer
The washer clunks during spin cycle. I removed the back and found some pieces of plastic from the outer drum enclosure. Other than that, everything seemed to be intact. The "shocks" or feet were not broken...
If the inner basket has broken off on one of the three braces on the back side where it is welded to the main spindle shaft that goes through the outer shell and bearing, you will need to replace the spindle and probably the inner basket. Some come together, some can be bought seperately and bolted. Not sure which yours is. Most people go out and replace unit rather than attempt ths repair because of cost if done by a appliance business. It is a complete tear down, and part or parts are expensive.
If you grab the inner basket and try to move it side to side, it should be solid.. The whole tub assembly can move while your doing this, but the inner basket should be solid in the back bearing
Just one idea..
Jan 13, 2010 | Frigidaire Washing Machines
Front load whirl pool - broken tub front
From your description, what it sounds like is one of the drum supports has broken on the back of the spin basket (inner steel basket) and chewed up the outer wash tub shell. The outside perimeter of the spin basket is rough like a cheese grater and will cause significant damage if used after one of the drum supports breaks. The spin basket is not supposed to come in contact with the outer tub shell. I have seen this problem several times and it will require (at a minimum) the front tub shell, tub gasket and inner spin basket to correct the problem. The estimated costs could be:
Front Tub Shell - $221
Spin Basket - $146
Tub Gasket - $9
If my math skills are correct, that's $376 in parts. Depending on the damage, you may end up having to replace the Rear Tub shell as well, which would add another $242 on to the cost. That's a total of about $618.
All these prices are before any shipping costs and only if you wish to pursue the repair yourself. Most appliance repair companies will add over $300 in labor alone.
I do have instructions on how to replace the spin basket, but it is labor intensive.
You need to ask yourself if this is worth the $600 in parts to repair, or would it be wise to purchase a new one. I wish I had better news for you.
To dispell any rumors or myths, this problem is know in the field. It is not common, but it does happen. Some of the welds on the back of the spin basket have been known to break causing the tub to spin off balance. This is not something that the average consumer will cause to happen, unless you consistently overload the washer. I do not know of any recourse you have at this point because the appliance is 8 years old.
If you wish to pursue this repair, please let me know. I hope I have been of some help even though it may not be pleasant news to hear.
Sep 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HP Pavilion dv4000 won't turn on/freezes
1. Try logging in SAFE MODE
2. If done tell me. We'll take it further
May 23, 2009 | HP Pavilion dv4000 Notebook
How to repair broken hinge of my Verizon LG Vx8350
I was able to take apart a VX8350 I have with a broken screen. I don't see any way to replace just the hinges with replacing the whole top part of the phone including the screen. The ribbon cable from the screen runs through the hinge part into the main assembly of the phone. It appears the cable can't be removed without cutting it.
Jan 11, 2009 | LG VX8350 Cellular Phone
AKG C418 Professional Microphone Logo
363 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Vito Vacirca Jr.
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
