Question about Car Audio & Video
Loss of 12v and ground connection
Over time the plastic that encases the terminal blocks has become brittle and is not able to keep a solid connection. Can i still get replacement components?
  • 3,904 Answers
Absolutely. You can just get a new terminal block. It does not have to be exact brand but just rated for the proper voltage going through it.
Posted on Jan 26, 2013
2 Suggested Answers
doron_c21
  • 387 Answers
SOURCE: i accidentally wired the 12v
Hi
It look like you burned the power supply in the amp if the fuse is ok
there is a circuit that protect the amp and its possible that it burned
this should not be too expensive to be fixed
ecrdn@yahoo.com
Jack
Posted on Oct 19, 2010
Not getting power to the starter
that happens
what work has been done on the car recently
check battery cable to starter is sound
tight battery terminals
if starter motor clicks ..flat battery
if starter wont turn at all
possible faulty starter
or immobilizer is still activated
Oct 14, 2016 | Cars & Trucks
Refrigerator keeps flickering on and off
I would need to know what you mean by flickering on and off. You mean the power light on the fridge? Or do you mean when the fridge runs. It won't run all the time, just part of the time.
Oct 05, 2014 | Dometic RM2652 Refrigerator
2000 Mercury Grand Marquis horn is not working fuses are fine. alarm chirps. The contacts in the steering wheel are fine I checked them with a multimeter.
Have someone hold the horn button down and-
connect your meter across the terminals of the horn, can you read 12V ?
Then check the both terminals one at a time to the car frame or engine block, If you read 12v on both terminals the ground to frame is missing.
Sep 15, 2014 | Cars & Trucks
How do I change the batteries?
sorry to say
The battery cannot be replaced. The battery and the electronics controlling the blinking lights for the shoes are encased in a solid block of plastic (Plastic like material). Let's just say that you are willing to drill or saw your way through the plastic to get to the battery. (I was) This plastic brick is inside the heel of the shoe and can not be gotten at without stripping the seams for the bottom of the shoe. I assume, that unless you are skilled cobbler, there is no way to replace the battery without destroying the shoes.
Feb 08, 2014 | Skechers S Lights Terminal Shoes
Mapsenor
Hi there:Test the MAP Sensor output voltage at the MAP Sensor connector terminal B (as marked on the sensor body). This is done with the ignition switch ON and the engine OFF. Output voltage should be 4-5 volts.
The voltage should drop to 1.5-2.1 volts with a hot, neutral idle speed condition.
Test engine controller (terminal 5) for the same voltage as described above to verify the wire harness condition. Repair as necessary.
Test MAP Sensor supply voltage at sensor connector (terminal C) with the ignition ON. The voltage should be approximately 5V (+/- 0.5V). 5V (+/- 0.5V) should also be at terminal 6 of the engine controller wire harness connector.
Test the MAP Sensor ground circuit at the sensor connector (terminal A) and the engine controller connector (terminal 4).
Test the MAP Sensor ground circuit at the engine controller connector between terminal 4 and terminal 11 with an ohmmeter. If the ohmmeter indicates an open circuit, inspect for a defective sensor ground connection. This connection is located on the right side of the cylinder block, at the oil dipstick tube mounting stud. If the ground connection is good, replace the engine controller. If terminal 4 has a short circuit to 12V, correct this condition before replacing the engine controller.
Also could check this video...
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
May 07, 2012 | 1998 GMC Jimmy
JUST PUT A NEW BATTERY IN MY 2003 ENVOY AND ONCE I STARTED IT IN WENT TO A LOW IDLE ALMOST WANTING TO STALL. I TURNED OFF THE HEATER CONTROL AND I ALSO WANT TO STALL, EVENTUALLY IT DOES STALL SOMETIMES....
Do to the loss of battery power while changing your battery, your Engine Control Unit (ECU) has reset and need to re-gather information. It is also possible that your battery does not have a solid connection causing loss of power and loss of data for your ECU.
Check your connections and wiring to your battery to make sure you have a solid connection and no frayed wiring causing unintentional grounding, and insuring any corrosion has been cleaned from the terminals of your battery and the battery terminal clamps.
turn on your vehical and ideal it for 10 to15 minutes. Do not rev the throttle/engine during this time as your ECU will be gathering info from the idling and will adjust to compensate during this idle time. Typically you should be able to drive the vehical with no issues after this time. A 30 minute freeway drive following your idle should give your ECU a full set of info and your car should run smoothly after that.
Jul 02, 2011 | 2003 GMC Envoy
Replaced therostate dyer still dose not heat up
check your heating element for being open,then the hi-limit switch, then carefully inspect all electrical connections around the element case for burns and brittle wiring, also chk neutral at the terminal block on input power and at element case for a solid connection
Oct 15, 2009 | Dryers
Where do I buy a spare power adapter pa-225
For those who run across this situation, don't add to the land fill if you can fix it. The majority of the problems with the PA-225 and 226's, is the DC plug connector that connects to the MX-1. That plug's connections are 4 pins and one thru-hole terminal that's meant for the center wire, ground line connected to the plugs metal jacket, which is the ground for both 5 and 12 volt lines. The problem is that during assembly, they miss getting the wire through the eyelet of the ground terminal and solder it anyway, which usually creates an intermittent or permanent disconnection later. Although this can happen for the pins, the main culprit is this ground connection. When this becomes disconnected, the LED will Blink indicating a problem. Normally the LED is a solid orange. The plug's molding can be cut (spit in half) and slid back to expose the plugs ground terminal. The inside molding can be cut/chipped away in if need be to expose the ground line. You might need a really good mag lens to show the fault. I took some pictures and created a pdf on what I found but haven't posted any where. If all else fails, you can order one from Antec. However, beware that the connector used on the replacements will most likely not be the same as the originals. So, if your supply is really DEAD, keep it for the 4 pin male connector, and check out this Antec Online Store for their replacement. Also be aware that I've discovered that the original supplies, two of the pins are used as one 12v supply, and the other two pins are the 5 volt supply with the plugs metal jacket as the ground for both. The original supply's labeling is incorrectly pictures as each pin pair being both positive and negative, with the metal jacket not connected. Make sure that this your next supply does not ground to any of these pins, only to the jacket. The motherboard inside the MX1 connects each pin pair together for a positive terminal only, therefore, if you get a supply incorrectly matching, you can toast a new supply. If you look at the male connector from the original supply with the plastic key "top". The left pin pair is 12VDC, and the right pair is 5VDC with the metal jacket as ground for both. Good luck.
http://store.antec.com/Product/accessory-spare_parts/mx-1-power-adapter/0-76
1345-30290-6.aspx
Sep 23, 2009 | Computers & Internet
Trying to hook my amp up in my car, I already have everything but the main power supply which is the wire to the battery.I was wondering how would i do that the right way?
the car amp needs to be wired using a +12 power, ground, and +12v signal (rmt) cables.  the +12 volt cable needs to be connected from the posative terminal of the car battery to a fuse (the right size should be written on the amp somewhere) then to the +12v on the amp. the ground cable needs to be connected to the negative terminal of your car battery. the RMT is the more complicated one, this needs to be connected to the header unit or the ignition switch. if you look in the instructions for your header unit (the unict where you insert CD's or tapes etc) this should explain whewre exactly to connect this cable. or you can connect it to the terminal on the ignition switch which becomes live only when you turn the key, should be the third one in. this line basicly tells your amp to turn itself on when it recieves a 12v current. you can also wire it up to a manual switch directly from the battery by connecting another cable to the posative terminal of the battery then to a switch then to the RMT terminal of the amp.
Dec 27, 2008 | Scosche Industries EFX Amplifier Wiring...
Amp will not turn on
You need to confirm that you have voltage at the amplifier.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jul 07, 2008 | Rockford Fosgate Punch 301S Car Audio...
Car Audio & Video Logo
16 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
