Question about Lexmark C510 Laser Printer
Persistent "network host busy" error
After using the printer successfully for awhile, the printer stopped working, and when I open the printer icon, it says "attempting to connect to on host 9100. Network host busy; will retry in 30 seconds."
We are running the printer from a USB connection on our router (Apple Time Capsule/Airport). No connections have changed. I've unplugged and restarted the airport, printer, and cable modem, with no change. It happens from every application and from both house computers (on which is plugged into the network by Ethernet).
  • Anonymous Mar 14, 2014
    printer does not work from wireless network. sometimes works with computer attached, sometimes does not
After working with Lexmark tech support (which is excellent, by the way), it became clear that the problem is with my network (Airport/Time Capsule) and not the printer. (The printer works when plugged directly into my computer.)
Posted on Jan 28, 2009
Error code -6210
  • QuickBooks File Doctor
  • Important: If you already have a version of File Doctor on your computer, proceed with downloading and installing File Doctor from this article to ensure you have the latest release.
  • Once the download is complete, double-click qbfd.exe and follow the on-screen instructions to install the QuickBooks File Doctor.
  • Once the File Doctor is finished installing, it will automatically open. If not, double-click on the green File Doctor icon on your desktop.
  • Note: If you do not see it opening, look for a green wrench icon in your Windows taskbar.
  • If you see a message that you need administrator rights to continue, click Yes.
  • Select one of the following options:
  • o Both file damage and network connectivity - if you suspect your company file is damaged, or you see a 6xxx error when you try to open your company file (data file problems).
  • o Network connectivity only - if you are using QuickBooks in a multi-user setup and get an H202 error when you try to open your company file (network errors).
  • If prompted, enter the Admin password for your company file, and then click Next.
  • Choose one of the following options, if prompted to share your company file:
  • o Yes - if you are running File Doctor on the computer hosting the company file (your Server).
  • o No - if you are running File Doctor on a computer that is not hosting the company file (your Workstation).
  • Proceed according to the results in the following table:
for more help call 1-855-383-7236 or visitQuickBooks Tech Support
Nov 09, 2013 | Intuit QuickBooks Pro 2007 Full Version...
Network installation error access denied on hp lj1020 my printer was working fine. i have installed printer on xp m/c its working fine but when i install it on win7 it give error print spooler error or...
HP says to use the Vista drivers. You have to install it a a local printer follow these steps....
1. Make sure the printer is turned on and connected to your network. Verify that you can access the printer's internal web page by browsing to its IP address before continuing. Print a network config page or make note of the IP address and Name. (should be a static IP)
2. Click >> Start >> Control panel >> Devices and Printers.
3. Click the Add a printer
4. Select Local printer
5. Select Create a new port and select Standard TCP/IP Port and click Next button.
6. Under Device type, select TCP/IP Device. Under Hostname or IP address, enter the printer's host name (found on the printer's network configuration report the generated above). Click Next.
If you get a message about Additional Port Information Required, then the printer was not found using the host name. You can go back and retry or using the printer's IP address instead of the host name.
7. Select HP or Hewlett-Packard from the list of manufacturers and select and select your printer model. Click Next.
If your printer model was not listed, then select Have Disk, browse the HP CD that came with your printer and select the first file that starts with hp and ends with inf.or use currently installed driver if you have teh correct on installed. Click Open then OK. Select your printer model. Click Next.
8. It will ask for the Printer name -- enter a new name or use the existing one. This will be the name of the printer that you select from other applications.
9. You may be asked to share the printer. Make a choice and click Next.
10. The Print Test Page box appears. Go ahead and print it.
11. Click Finish.
Dec 19, 2010 | HP LaserJet 1020 Printer
Hp all in one 6180 won't print
The ink cartridges included in the box are used to set up the printer. This type of ink cartridge is called a “host” cartridge. Once the printer has completed device initialization, they are marked as regular “trade” cartridges. This error only occurs if the printer has finished the device initialization process and one or more of the ink supplies inserted into the printer are a “host” supply.
Solution: The indicated ink cartridge(s) cannot be used after the device has undergone first-time setup. Once the product displays the message ' The following ink cartridges cannot be used after device initialization and must be replaced ', the designated host cartridge(s) (indicated by the color icon(s) on the display) that were rejected should be discarded or recycled and never used again. Replace the ink cartridge(s) with the appropriate “trade” ink cartridges for the HP All-in-One.
May 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
Scan cannot be performed
I also had the same problem with HP Officejet 6310 and after trying all the solutions that I could find on the web, I was almost giving up. Then I found this on HP's IT Resource Center website (author J.Eqbal) and tried it and finally it scanned without the error message.
This error happens only in Network connections.
Get the Ip address of the Printer and open the EWS page by typing i.e http://192.168.1.102...where 192.168.x.x.x is the IP address of the Printer.
On the EWS page click on Network and get the host name and copy it.
go to the following location C:\Windows\System32\drivers\etc...inside etc you will find the host file open it using notepad.
Underneath 127.0.0.1 local host
there might be the Ip address and host name ..which will be different from the current host name...change the Ip address and host name ..save the file.
Try to scan...it will definitely work.
Dec 08, 2008 | HP Photosmart C7180 All-In-One InkJet...
Client Printing + Word/Excel access times
DOWNLOAD THIS BOOK FOR FREE AND SOLVE ANY PC HARDWARE, SOFTWARE OR OPERATING SYSTEM PROBLEMS.
DOWNLOAD NOW......
Download mirror 1 ( Hosted by HostingDude)
Download mirror 2 ( Hosted by Softpedia )
Download mirror 3 ( Hosted by Soft32 )
Download mirror 4 ( Hosted by fileflyer )
Download mirror 5 ( Hosted by Rapid Share
369
Aug 06, 2008 | Microsoft Small Business Server 2003...
Problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Jul 02, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Samsung ML 2010 under mac os X 10.5
I found a solution that worked for me by prowling around various Apple discussion forums. The two keys to the solution for me were numbers 3 and 5 below.
1. Opened print/fax preferences
2. Opened Add printer by clicking the +
3. For protocol, select HP jetdirect-socket (not IPP or LDP)
4. Determined the IP address for my Belkin wired print server and typed this into the Address line of printer setup
5. Manually selected the printer driver as ML-2010. It is in the list of drivers but is in the M's, not under the Samsung drivers.
6. This worked for me. I've seen reports from people who had to power cycle their print server and/or printer as well.
Jun 22, 2008 | Samsung ML 2010 Laser Printer
E-studio 2500c "network host is busy"
you can try to print directly to the machine (not going through the novel system) using either apple talk or ip printing
Mar 27, 2008 | Toshiba e-Studio 205 Copier
Fax device I/O error
installed samsung scx-4521f multi function printer. can't fax from smarThru program. get message : Fax device I/O error
Jan 11, 2008 | Samsung CLX 3160fn All-In-One Printer
Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
Aug 08, 2007 | HP Photosmart C6180 All-In-One InkJet...
Lexmark C510 Laser Printer Logo
639 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
