Question about Braun Stainless Steel Electric Tea Kettle Electric Kettle
Does Braun use BPA plastic in electric tea kettles?
3 Suggested Answers
SOURCE: My Braun electric kettle won't click on. Do I
It's possible it can be fixed. Ours also no longer clicked. I took it apart and found that the flat plastic piece in the handle that activates the circuitry in the base had broken away from the rocker piece in the base. Fortunately the same flat plastic piece conveniently had a couple of holes in it in a helpful location. I looped some wire through the holes and also around the bottom rocker piece to hold the two pieces together.
I reassembled the kettle and tried it out and it now works fine! Problem fixed.
To disassemble, take the four screws out of the bottom of the kettle. (You'll need the appropriate star bits to do so.) Put those screws in a safe location... Lift off the bottom plate.
Now, the plastic for the handle is held in place by the typical notched clasps used by so many plastic appliances. You unsnap the clasps by CAREFULLY inserting a straight blade screw driver between the handle plastic and the kettle and GENTLY prying the handle plastic away from the kettle. You'll hear the internal clasps "popping" as they snap loose. You CANNOT take the handle all the way off this way. You just loosen it. Now, the top of the handle is a separate piece. Do the same for this. The top will pop completely off.
Next, GENTLY remove the lid. You can slide it a bit up and away. It's a tight fit, so you need to use a little force, but not too much.
Once you've done this, there are two metal pins that hold the main part of the handle to the kettle. They have a little ridge around the top that you can use to pry them out with your fingernail. Once those pins are removed, the handle will simply come off.
BE CAREFUL! The various parts in the handle are now loose! If you aren't careful they'll fall off and you'll have to figure out how to reassemble them.
Now, you'll notice the long flat plastic piece running down the side of the kettle. That piece was hidden behind the handle. It is SUPPOSED to be fastened to a rocker plate at the bottom. If you look at the end of the flat piece at the bottom you will likely see what I did. It had just disconnected from the rocker plate. Take some wire and wire the two pieces together using the little hole-like slots at the end of the flat piece. Just loop the wire through the hole and down around the rocker plate piece exposed inside where the handle is.
While applying this wire, it will be helpful to put a little masking tape across the various handle pieces to keep them from falling off. This is important because you'll probably be wiring the pieces together with the kettle on its side like I did, and the parts will fall off if you aren't careful. When you are done wiring things together you just remove the tape.
Once you've done this, reassemble the kettle in the reverse order you disassembled it.
You'll notice that once you've wired together the two separated pieces, pressing the switch on the top pulls up on the flat plastic piece which pulls the rocker plate which closes the circuit in the base.
Posted on Mar 02, 2011
tunde007
  • 2382 Answers
SOURCE: how to clean my Braun electric kettle
Hi, follow the instruction below to clean it up...
Unplug the tea kettle from the wall outlet, and detach the plug from the kettle.
Pour 1/4 cup white vinegar into the kettle, and fill the kettle halfway with hot water.
Agitate the kettle so the vinegar mixture hits the sides of the kettle walls, and let the water sit for 20 minutes.
Discard the vinegar water, and scrub the interior of the kettle gently with a nylon sponge.
Rinse the kettle with hot water, and repeat as needed until all buildup is removed. Let the kettle air-dry before inserting the cord back into the kettle.
Posted on Apr 17, 2011
Is it okay to use glass whistler tea kettle on ceramic stove top range
I've seen mixed results across the internet on this one. From personal experience, for some reason, my glass teapot left some sort of stain on my ceramic stovetop. It also took longer to heat. I then went out and bought a simple metal one and have been pretty satisfied. If cosmetics are a concern, it's not too difficult a step to pour the water into your teapot after the fact, right?
Jul 23, 2014 | Frigidaire Ffed3025ls 30 Smooth Top...
Dead cuisinart electric tea kettle
Your tea kettle has a thermal fuse inside that more that likely got over heated, it happens all the time with irons, coffee makers, most small appliances that are electric. you have to take the bottom off to find it and replace it. does it have an indicator lamp?
Sep 18, 2012 | Cuisinart Tea Kettle High Quality...
I have a model RK 17 Cordless electric jug kettle from cuisinart that I just love because of the old fashioned design. I need a new base because a mouse decided to chew the cord and was incinerated.
i HAVE THE BASE IT WORKED FINE, MY DAUGHTER COOKED THE KETTLE WHEN SHE TRIED TO HEAT IT ON THE ELEMENT, now I need to find a new kettle! ONSCHMITT@SHAW.CA
Jul 18, 2012 | Cuisinart RK-17 Cordless Electric Kettle
How to clean my Braun electric kettle
Apr 17, 2011 | Braun WK200 Cordless Electric Kettle
My tea kettle leaks from the bottom
I just took ours apart for the same reason. In our case, it turns out that one of the two water indicators was cracked (at the top), causing the leak. The cracks were invisible without taking it apart.
There's a bigger leak near the bottom of the same piece, where a piece of the plastic is missing:
On the upside, the wk600 is really well designed - easy to take apart for repair. But I can't find replacement parts anywhere...
Feb 25, 2011 | Braun WK600 Cordless Electric Kettle
How to clean the inside of tea pot (scale deposits)?
Vinegar is very good at removing scaly deposits. Heat white/clear vinegar just as you would normally heat the water for your tea. After heating the vinegar, pour out and rinse thoroughly with water. If there are still deposits after this first attempt, use vinegar once again. Once you are satisfied that all the deposits have been removed, heat water in the tea pot 2-3 times to remove any smell or taste from the vinegar (before using for tea).
Jul 07, 2010 | Breville "Ikon" Tea Kettle Electric Kettle
Cushion lid release button sticks and the lid does not close
Over time the heat can causes the plastic parts to swell until the button that releases the lid gets stuck. The button can be easily & carefully pried completely out of the hole with a knife **note the orientation of the button and spring for replacement. Clean the button & hole but expect the button to still stick when re-inserted back into the kettle. Take the button back out and if you take a knife and gently carve/scrape away some of the plastic round the inside of the rim of the 'hole' and around the edge of the plastic button, you can remove enough of the plastic so that the button now moves easily back and forth in the hole releasing the lid. Good luck.
Jul 05, 2010 | Breville "Ikon" Tea Kettle Electric Kettle
Will not whistle
It is possible the reed valve broke.
Aug 02, 2009 | Electrolux CHANTAL Loop Tea Kettle -...
Damage to the bottom of Cuisinart cordless tea pot mod KUA-17
Even though there are no parts listed at the cuisinart.com website, the company does a few base pieces left in stock if you call them directly - 1-800-726-0190
Apr 11, 2009 | Cuisinart KUA-17 Cordless Electric Kettle
I would like to know where I can purchas a filter for my T-Fal Avante electric tea kettle
Thanks for the offer, but i no longer require help. I found out that the model tea kettle of mine is no longer made and they do not have filters for it.
Apr 08, 2009 | Tefal T-FAL Avante Stainless Steel...
Kitchen Appliances - Others Logo
77 people viewed this question
Top Braun Kitchen Appliances - Others Experts
Oscar Netto
Oscar Netto
Tom Chichester
Are you a Braun Kitchen Appliances - Other Expert? Answer questions, earn points and help others
