I would like my computer to be wireless instead of having to hook it up to the modem every time how do I do this is their software I can buy or download
If u have a late model laptop, it would have come with wi Fi (wireless) switch, most likely in the front this turns your with Fi on and off, if its a late model you can buy a with Fi card for laptops, or a USB wi Fi dongle which allows you to connect to wi Fi , they can be bought at Harvey Norman or eBay ..
Posted on Jan 23, 2013
  • blair carriere Jan 29, 2013
    The problem was some of the drivers weren't working for the Wi-Fi part of it not much of a computer guy that's all I know I did somehow manage to fix it myself Playing with the help button and it kind of pushed me over in that area and then I just clicked on stuff and click reload or something like that
I can only get it to work with a wire,the box says its wireless.dlink233OL
If you are talking about the wire that comes from your modem to your dlink2330L, yes you have to have it hooked up via wire. Then your wireless "wifi" capable devices connect the the internet wirelessly through the modem. If you are talking about having to hook up a wire from the router to a computer to get the computer to get on the internet, that computer may not have a "wifi" device built into it. If the later is the case you can buy small "wifi" devices (like a "Bear Extender) that plug into your usb port to make them wireless.
Sep 26, 2016 | Computers & Internet
I have a dell 2400 desktop computer. I recently got FIOS and they hooked my wife's computer to their router with an ethernet cable. Can I also hook my dell up the same way?
Depends on the hardware. Is it a router or modem? Does is have extra ports in the back,
Router with extra ports, just connect new device with wire or even wireless if it has wireless.
Modem, most likey you have to buy a router.
Dec 28, 2012 | Dell Dimension 2400 PC Desktop
How do i hook up a wireless router to a cable router
If you already have a cable router, then you don't want to use a wireless router. You will want to use a wireless access point instead.
The reason for this is that anything plugged-in to your cable router will not be able to access anything connected to the wireless router due to the NAT firewall in the wireless router.
If the wireless router has the option to make it a "Gateway", then that will fix this issue; otherwise, take the router back and buy a wireless access point instead.
As for how you hook up the wireless router to the cable router, you have to unplug the power cord of the cable router for about 15 minutes before hooking the Ethernet jack from it to the wireless router.
Once the 15 minutes have passed, you then can plug the Ethernet cable from the wireless router "WAN" port into an Ethernet port on the cable router and then plug-in the power cord of the cable router.
Once the cable router is finished syncing-up, the cable router should provide an IP address to the wireless router.
If you really have a cable modem instead of a cable router, then you won't have to put the wireless router into gateway mode.
Dec 30, 2010 | Linksys Wireless-G WRT54G Router
Can I use more than one modem on my phone line to support multiple computers? Also, where can I obtain a list of modems compatible with a Netopia 2249n? Thanks
Hello
The short answer is no you really cant use multiple modems. The internet should come in to your home via the modem, then go in to a ROUTER. Many times the router will have 3 to 5 ports on the back to hook your other computers too. This means running cables. Another way is to use WIRELESS cards that you can find on the net or from best buy.
If your router does not have any extra ports you need to buy something called and ethernet switch. Again they come in 4 and 8 port models up to LOTS AND LOTS Of ports for big companies. You hook the switch in to the router, then hook the computers in to the switch.
I hope this helps you
Nov 27, 2010 | Arris Netopia 2240N-VGx Router
Cable and wireless question
Not possible, since the "input" to the 2WIRE modem is a 4-wire telephone-line, not an 8-wire Ethernet cable.
Instead, spend about $40 to buy a D-Link Wireless G modem, and connect its WAN port to the cable-modem, and connect up to 4 Ethernet cables to "wired" computers, and configure the "wireless" component of the D-Link router.
May 07, 2010 | Computers & Internet
I ordered a wireless router so I can hook up my PS3. My computer is not compatible with wifi so I thought I'd just leave it hooked up to the modem. The instructions tell me to put the CD into my computer...
You have to use the computer to insert the CD
As your computer is not wireless compatible, you can have this connected to the router itself on the wired connections and use PS3 on wireless
Do NOT connect your computer to modem and also Netgear to modem.
Either one of them won't work. Instead connect modem to Netgear and computer to Netgear with an ethernet cable.
After this type of connection is made, try to setup the router with the CD inserted into computer.
This is how things work!
Jan 22, 2010 | NetGear WNR1000 Router
So how is the other computer supposed to work on the internet, if this wireless router is hooked up with the current modem? If I need another part, then why did I spend $150, and not get all I needed??
Before you bought the wireless router, you probably had one computer directly hooked up to the modem (the box you got from your internet provider). The wireless router should have come with a cable similar to the one that had previously connected the modem to your computer.
When you use a router, the original cable from the modem is disconnected from the back of your computer and is instead plugged into the INPUT of your router. The cable that came with the router is then plugged in to the original computer.
So far, so good.
Now, when you want to add additional computers to the internet, you can do it in two ways: either wirelessly (which means the other computers need to have wireless capability already built in - which is the case with laptop and notebook computers, or they have to have a wireless card installed); or you have to purchase another cable (like the one that came with your router) to directly connect the other computer to the router.
The only time an additional cost would be involved is if you needed to purchase another cable (for a direct connection), or if your other computer doesn't have wireless capability.
Does that answer your question?
Jul 07, 2009 | Linksys WRTP54G-NA Wireless G Broadband...
I was given a linksys wireless-g model wrk54g router but it didn't come with an installation disk. I have a Thomson speedtouch modem ST530 V6. Right now I am hooked up thru ethernet and getting internet...
was the router used by previous users? or did you buy it? if it was used then it was probably configured for different ISP. You don't need any CD. Just connect to the router via your browser (probably http://192.168.1.1) and adjust settings in WAN section.
Mar 15, 2009 | Linksys Wireless-G Broadband Router
Cable modem
Go and buy a router. Plug your existing modem into the WAN port and your computers into the LAN port. You could even get a wireless router and connect your upstairs computer wireless. Be sure to lock down your SSID (Wireless Access Point Broadcast Name) so your neighbors or people driving by don't get on and do bad things on your network.
May 31, 2008 | RCA Cable Modem DCM315R (11603540)
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
