Question about Netopia 3346N-VGx Router (3346NVGX)
Bridging I have a Netgear Router WGR614. I have set up an IP based camera system. The ports needed for them begin at 50050 and go up in order to get the cameras online. The ports available for the Netopia end in the 49000's. Therefore, I need to put the Netopia into bridge mode and assign ip addresses. What steps do I take and, how does this get accomplished?
  • 854 Answers
First you need to call your ISP to help you bridge the modem. After bridging, follow this steps;
Port Forwarding
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Posted on Sep 06, 2009
NetGear router WGR614 v9. No manual, don't know user name and password so can't login to your site. Need an encryption key for this router. Cannot get a wireless connection to internet otherwise.
plug computer into ethernet port of router
Via blue ethernet cat5 patch cable
try user name admin
and password as password
try 192.168.1.1 ( later version of router ) or 192.168.0.1 for router ip address in an internet browser.
then look at the wi fi settings for wi fi security encrption key or add one if not set .
https://www.lifewire.com/netgear-wgr614-default-password-2624841
Oct 16, 2017 | NetGear Computers & Internet
How do I reset my router and connect it to a different computer?
Look for a little hole that reads reset and press it with a little pin, hold it for about 10 seconds
Jan 31, 2012 | NetGear WGR614 Wireless Router
How do you get the Toshiba BDX2700 blu ray player reset to a NetGear WGR614 router with a different IP address when the router doesn't have a button?
That router uses a browser-based interface, so you can simply log on and set it up from any nearby PC.
The Netgear manual can be found here and the Toshiba manual here. Page 28 shows the network setup.
Jan 10, 2011 | NetGear WGR614 Wireless Router
Trying to set up laptop from desktop but dont know password for router wgr614
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 14, 2010 | NetGear WGR614 Wireless Router
How do I change the NAT type on my Netgear WGR614 v6 router from strict to open?
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Then click on NAT and then port forwarding then open port tcp and udp which you want then save settings and restart router.
Apr 19, 2010 | NetGear WGR614 Wireless Router
I gave my netgear router WGr614 to my daughter she is not able to connect to the internet. my security code is my old phone number would that make a difference?
How does she connect to the internet on the other PC? If a cable or ADSL modem is used then this needs to be connected to the WAN port of the router. Other wired systems need then to connect to the routers LAN ports. The wireless connections sound like they are already working connecting ok. Any trouble that might come after connecting in this fashion might come because the router is set to a fixed IP. Router needs to be set to connect via dynamic DCHP option.
Dec 29, 2009 | NetGear WGR614 54Mbps Wireless Router...
Trying to connect to remote camera. I go to a wifi spot and can connect. I try from my home and can't connect. What setting needs to be changed?
You cannot get to the outside of your router from inside the network. Use the internal IP address instead.
For instance:
Lets say you use http://camera.mydomain.com:8080 to get to the camera.
That URL points to your router which has some IP address. eg 80.180.23.234
You router forwards the request on port 8080 to the internal IP address of your camera eg. 192.168.1.45 an it is this address that you need to connect when inside the LAN.
Your need to replace the details above with those specific to your setup.
Nov 21, 2009 | NetGear WGR614 Wireless Router
I am given a set up error while trying to configure netgear WGR614. Below is the message The router is setup with the static IP values read from the computer. However, there is no Internet connection with...
You need to contact your Internet Service Provider to obtain the setup configuration for the cable or DSL modem. A LAN cable is then connected from the modem to the Internet LAN port on the wireless router.
Normally you do not set a static IP address on the router, and the wireless card should be set to obtain an IP address automatically.
If you still have problems, give me details of what configuration steps you have carried out on the router and the wireless card together with the error messages.
Sep 12, 2009 | NetGear WGR614 Wireless Router
Difficulty in installation
1. hard reset ur modem ( it will set to bridge by default)
2. connect ur modem to WAN port at netgear router
3. connect ur pc to LAN port at netgear router
4. by default ur pc ip should be 192.168.1.x
5. type at IE/firefox address bar
username = admin
password = password
6. enter all basic info (ISP = other, streamyx username password, wifi setting)
7. set value for idle timeout (in minutes) = 0
Dec 18, 2008 | NetGear WGR614 Wireless Router
Netopia 3346N-VGx Router (3346NVGX) Logo
206 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
