Question about Honeywell Access Systems Northern Computers NSLAN1, Nstar Ethernet Adaptor NS2 Network Adapter
Nstar backup and restore has a system error
Cannot start the Backup and Restore program on an NStar Access Control system. A window immediately comes up and says System Error. Also, in the NStar User Interface reports can no longer be generated, so SQL has to be used now to backup the system...tech support recommended a reinstall of the programs.
3 Suggested Answers
protek480
  • 1714 Answers
SOURCE: I have just installed underfloor heating with 4
You say you have3 rooms on the underfloor system that will probably require different temps. You said you have 1 zone valve for the under floor system. You can not control all the rooms with different thermostats and only 1 zone valve. You need more information and professional help here. I can give you more advice too...
Posted on Jul 01, 2009
SOURCE: i can not take a backup from hard drives
What is the name off the program you need?
Posted on Jan 18, 2013
Runtime error with EZ Backup restore
Did you try to reinstall the EZ software? perhaps you accidentally removed (a part of) a program.
Then try to restor the data again.
Jul 08, 2014 | NTI Backup Now EZ
Tip
How to make back up of your software settings
<p>Software settings on your computer are stored in the Windows registry. To create a backup of these preferences is made a system recovery. A restore point takes a snapshot of your registry settings and stores them on your hard drive. These restore points when using a plant damaged registry settings that result in errors pop up every time the computer. Windows provides an interface to quickly create a new restore point. <br /> <p><br /> <p>1. Click the Windows Start button. Click "Control Panel" to a new window. Click System and Maintenance link. "Click" System "to the system settings. <br /> <p><br /> <p>2. Click "System Protection", for the utility, create a restore point. If you are not logged in as administrator, a pop-up asking for the password. Enter your password and click OK. <br /> <p><br /> <p>3. Click "System Protection" tab. In this window, click Create a new window. Enter a name and description for your restore point, so you can see the backup. Click Create to create the backup software. <br />
on Jun 22, 2011 | Computers & Internet
Restore recovery disk
Hi Billy,
depends on what you mean by restore. Assuming you have windows installed, you can make a back-up by going to START > Control Panel > System and Security > Create a backup
(the path above may be a bit off from the wording, the PC I am on at the moment is not an english version.)
Then on the left side there is a link to create a recovery disk or create a backup. the recovery disk option only makes a bootable disk to start your computer if your windows cannot start. This only gives you an enviroment where you can try to fix windows or to restore a backup that you created beforehand with the second option above.
If you create a backup, there are two things to keep in mind... what type of data do you want to back up and how often. You can put check marks on all data that you want to backup (Note: the more data you backup the larger your backup file will be). If you plan on restoring a corrupt windows with the backup you should include "System State".
Restoring from a backup file a.k.a. backup image will ONLY give you back the files that were on your computer at the time you made the backup... that means everything that you created after you made the backup will be lost.
Hope that helps.
May 16, 2014 | Dell XPS 200 PC Desktop
How to Restore XP Backup Data in Windows 8 OS?
Microsoft offers file transfer support.
Apr 25, 2014 | Computers & Internet
All of my access codes have been deactivated. How do I fix it?
Hopefully you have a recent backup of the database. Just restore the backup. I cannot stress enough the importance of making a backup on a regular basis.
Aug 15, 2013 | Honeywell Access Systems NStar Access...
Back up error.....i need more help please
check out this link for the solution.
http://www.pagestart.com/win7br0x8100003301.html
Dec 28, 2011 | Acer Aspire AX3400U2022
My restore system will not work,when i try it it says can not restore to this point, but it will not restore to any point i try.. any suggestions ... thanks.
because your compter system not setting when you make restore point and when you make backup your system for next time you must active your system tool : click start-program-acsessories-systemtool and tab backup and configuration in there you can setting wahat do you want about restore and backup setting for your system computer.good luck
Apr 26, 2010 | Microsoft Windows XP Home Edition
Can not download any programs
The windows backup feature does not back up any installed programs , it would only backup up your data files , but no exe files. But you are not able to install a fresh copy of the programs over the internet and from the cd.
Try installing these programs from in safe mode of windows . To start the computer you need to press the F8 key a couple of times before windows starts up.
If the same is not working you need to redo the operating system once again
Thanks
proton
Oct 02, 2008 | Microsoft Windows XP Professional for PC
System Restore...
Did you set a restore point lately. You do need to do that occasionally
(for example after removing a virus)
Maybe your restore point is not valid anymore
you can do Your first port of call for System Restore problems should be the System
Restore Troubleshooter, which you'll find here. However, it's also possible
that one of your Restore points has become corrupt, in which case you'll
need to disable System Restore. This will delete all existing Restore points
and then re-enable it. To do so, right-click My Computer on the Start menu
or desktop and choose Properties -> System Restore tab. Tick the 'Turn off
System Restore on all drives' and click Apply - you'll be told that all
existing Restore points will be deleted, so click Yes, at which point the
Restore points will be removed. Now remove the tick and click Apply again to
re-enable it.
You can now test that System Restore is working properly by creating a new
Restore Point and then immediately attempting to restore your computer to
that point in time. Hopefully, now you'll be successful
Feb 14, 2008 | Computers & Internet
Backup DHCP,AD of win 2000 .
How To Use the Backup Program to Back Up and Restore the System State in Windows 2000 var sectionFilter = "type != 'notice' && type != 'securedata' && type != 'querywords'"; var tocArrow = "/library/images/support/kbgraphics/public/en-us/downarrow.gif"; var depthLimit = 10; var depth3Limit = 10; var depth4Limit = 5; var depth5Limit = 3; var tocEntryMinimum = 1; .toc{display: none;} SUMMARY loadTOCNode(1, 'summary'); This article describes how you can optionally back up the system state in the Windows 2000 Backup program to back up and restore critical system data. When you choose to back up the system state on a domain controller, the following items are included: • Active Directory (NTDS) • The boot files • The COM+ class registration database • The registry • The system volume (SYSVOL)When you back up the system state on a non-domain controller, the following items are included: • The Boot file • The COM+ class registration database • The registryWhen you back up a member server or domain controller with Certificate Server installed, the following additional item is also included: • Certificate ServerWindows 2000 Backup can back up and restore Active Directory on Windows 2000 domain controllers. You can perform a backup operation while the domain controller is online. You can perform a restore operation only when the domain controller is booted into Directory Services Restore mode (by pressing the F8 key when the server is booting).
uparrow.gifBack to the top
How to Back Up the System State on a Domain Controller loadTOCNode(2, 'summary'); 1. Click Start, point to Programs, point to Accessories, point to System Tools, and then click Backup. 2. Click the Backup tab. 3. Click to select the System State check box. (All of the components to be backed up are listed in the right pane. You cannot individually select each item.)
NOTE: During the system state backup, you must select to back up the Winnt\Sysvol folder. You must also select this option during the restore operation to have a working sysvol after the recovery.The following information applies only to domain controllers. You can restore member servers the same way, but in normal mode.
If any of the following conditions are not met, the system state is not restored. Backup attempts to restore the system state, but does not succeed. • The drive letter on which the %SystemRoot% folder is located must be the same as when it was backed up. • The %SystemRoot% folder must be the same folder as when it was backed up. • If sysvol or other Active Directory databases were located on another volume, they must exist and have the same drive letters also. The size of the volume does not matter. uparrow.gifBack to the top
How to Restore the System State on a Domain Controller loadTOCNode(2, 'summary'); 1. To restore the system state on a domain controller, first start the computer in Directory Services Restore Mode. To do so, restart the computer and press the F8 key when you see the Boot menu. 2. Choose Directory Services Restore Mode. 3. Choose the Windows 2000 installation you are going to recover, and then press ENTER. 4. At the logon prompt, supply the Directory Services Restore mode credentials you supplied during the Dcpromo.exe process. 5. Click OK to acknowledge that you are using Safe mode. 6. Click Start, point to Programs, point to Accessories, point to System Tools, and then click Backup. 7. Click the Restore tab. 8. Click the appropriate backup media and the system state to restore.
NOTE: During the restore operation, the Winnt\Sysvol folder must also be selected to be restored to have a working sysvol after the recovery process. Be sure that the advanced option to restore "junction points and data" is also selected prior to the restore. This ensures that sysvol junction points are re-created. 9. In the Restore Files to box, click Original Location.
NOTE: When you choose to restore a file to an alternative location or to a single file, not all system state data is restored. These options are used mostly for boot files or registry keys. 10. Click Start Restore. 11. After the restore process is finished, restart the computer.
Dec 02, 2007 | Microsoft Windows Server Standard 2003 for...
Honeywell Access Systems Northern Computers NSLAN1, Nstar Ethernet Adaptor NS2 Network Adapter Logo
35 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
