Question about Compaq Presario M2000 Notebook
Green lines on dell inspiron e1505
I have vertical green lines on my screen. I think the problem is the monitor because the lines don't show on an external display.
Why does my monitor have colored vertical lines?
Hi Shannon,
I don't have good news for you. Coloured vertical lines is a symptom of terminal failure of LCD screens. Most common in laptops, monitors, and TVs. Problem only gets worse with time with more lines appearing, then expanding to cover a whole side of the screen. 30 - 50% normally.
Jul 19, 2012 | Dell Inspiron 2200 Notebook
Dell inspiron e1505 laptop has a thin light green line on far left of screen and a thin pink line approx an inch to the right of it. Both lines run from top to the bottom of the screen. I'm assisting in...
If you were to plug it into an external display, that will tell you whether it is a VGA uProcessor fault or a screen fault. If it is a screen fault, checkout ebay for a replacement screen.
Hope that helps.
Jan 25, 2011 | Dell Inspiron E1505 Notebook
Bluish green colour vertical line is coming in my
Your laptop screen has been faulty. you can checked it from service center.
Nov 13, 2009 | Dell E173FP 17" LCD Monitor
My dell inspiron E1505's screen only half showing
Generally an indication of an LCD failure. You can try reseating the LCD cable under the keyboard, see if it makes any difference. If no change, then replace the LCD
Oct 01, 2009 | Dell Inspiron E1505 Notebook
Horizental lines on dell inspiron E1505 monitor
Sorry to say but screen needs to be rplaced you can find one on ebay for about $100.
If you find this helpful please rate so.
Thanks
May 06, 2009 | E-Machines e15t 15" Flat Panel LCD Monitor
Dropped laptop. Everything seems to work, but screen messed up
Screen cracked, you will need to order a new screen and replace it.
Here is how to replace screen on Dell Inspiron E1505.
Mar 29, 2009 | Dell Inspiron E1505 Notebook
Black vetical lines on the screen. how do u fix
You need to flash or update your computer's bios. if you have an inspiron 1501 go here:
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R174470&SystemID=INS_PNT_1501&servicetag=&os=WLH&osl=en&deviceid=13120&devlib=0&typecnt=0&vercnt=9&catid=-1&impid=-1&formatcnt=1&libid=1&fileid=236967
read the installation instructions or print it. then download the file and follow the instructions. after restart. see if you still get the vertical lines.
Mar 02, 2009 | Dell Inspiron E1505 Notebook
Red vertical line going down the screen'
That shows a bad LCD screen that needs to be replaced. Unfortunately it's a hardware problem.
If you laptop is under warranty, you need to take it to a Dell Warranty/Service centre and have the LCD replaced.
Feb 22, 2009 | Dell Inspiron E1505 Notebook
Inspiron 1150 lines on screeN problem.
Connect an external monitor to the laptop and see if it also has the vertical lines. If the external monitor looks fine, then your laptop’s LCD display panel is bad. If the monitor has the vertical lines displayed on it, then your graphics card or motherboard is bad.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 10, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Compaq Presario M2000 Notebook Logo
291 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
