Question about Genie Company Genie 34094R Garage Door Opener Safety Beam Kit
Genie model 3062
Limit settings
I did the set up for the genie opener and it will close automatically but will not open where did I go wrong?
You need to go through the whole programming sequence again setting the limits. You have to program the up limit and the down limit. Sounds like you may have only done the down limit
Jun 03, 2017 | Building Materials
Two red lights on (limits not set), can't program limits cuz round blue led on
Does turning off the opener by way of unplugging the power for an extended period of time, help?
I would also look for a reset button on the motor while I was either calling the 1800 number on the motor's housing or Google the Manufacturer and model number so you can download the owner's manual.
Aug 08, 2014 | Genie Garage Door. SilentMax 1000 3/4 HP...
Where can I find a filter for genie sv300q?
I have the Genie 3000 which is a 20 gal. wet/dry vac with a 3.0 HP motor. I had bought at Home Depot some 20+ years ago. I bought a replacement filter at HD made by someone other than Genie and claiming to fit my model...but it did not fit...too loose to stay in place. I did track down some hypo filters that might fit...but at $28+ for the filter I decided it was time to get a new model with better and cheaper and available filters. I bought a Ridgid WD1451 14 gal with 6.0 HP. It is so much nicer and quieter. HD regularly carries the WD1450 for $99 or so. The WD1451 is the same model but also had the car vac hose and attachments (a $40 set) included for free. That was a limited offer probably no longer available. Get you a new one and enjoy it...I did...and I still have the Genie...but I think I'll toss it because it is too big, too loud, and I love this new Ridgid.
May 28, 2014 | Genie Company GV150 Wet/Dry Vacuum
My friend has a bad Genie garage door opener down limit switch (Door goes down and right back up again). Limit switch is made by Tane with part No.'s on it: FM-102BR-138 and 33969B. Would Limit Switch...
This is the close limit sensor so yes it should work. They have them for $2.40 right now from an Amazon vendor - http://www.amazon.com/Genie-Excelerator-Close-Switch-33950S/dp/B00283OBXY/ref=?ie=UTF8&m=A1CTO3U79X1RZ3
You can also buy replacement sensors as a 10 pack in case you end up needing more from here -
http://dpcdist.com/flangemountcontactandmagnetendleads.aspx
Sep 16, 2011 | Genie Company Genie Excelerator Down Limit...
IS the down limit switch # 3395OS the replacement for the #33969B ?
Yes the 33950s is the correct part number for the down limt on an Excelerator model.
Feb 20, 2011 | Genie Company Genie Excelerator Down Limit...
How to set acsctg type 2
There is a button on the motor head you can press. Press it then press the button on the remote 3 times and try it. If not try it again. Genies are bad for not coding in the first time. Make sure there are new batteries in it. Thanks BB
Jul 19, 2010 | Genie Company IntelliCode GICT390-1BL...
Genie excelerator wants to run all the time
You need to check the limit switch. It is above the rail. Figure out if it wants to up too fr or down and look at that one. There is a press on connector that can come off or break. If it is broken solder or replace it. Thanks BB
Dec 20, 2009 | Genie Company Genie Excelerator Down Limit...
Genie garage door won't shut. the down limit switch wire (brown) got caught and I had to reconnect...stripped and twisted wires (just the brown down switch wire) together ... door still won't shut , it...
You don't say which model you have, however, MOST Genie systems use the switches as temporary contacts. By twisting them together, the computer board is reading it as a short. You need to replace the switch and route the wires properly.
Nov 21, 2009 | Genie Company Genie Excelerator Down Limit...
Genie Company Genie 34094R Garage Door Opener Safety Beam Kit Logo
82 people viewed this question
Top Genie Company Building Materials Experts
 Tony C
Tony C
Level 1 Expert
robert
chrisheman
Are you a Genie Company Building Material Expert? Answer questions, earn points and help others
