Question about Microwave Ovens
Ge model Jvm1563wh05 microwave oven
After very small fire in oven now nothing works , did not have to use water or fire extinguisher, fire went out when oxygen was depleted,would require very little clean up but not even clock works ,like it is not getting power,yet other appliances will work in this outlet, Thanks
  • Microwave Ovens Master
  • 9,098 Answers
I assume that model is JVM1653WH05?
The fire probably opened the internal flame senor, also known as the oven cavity thermal cutout (TCO) located on top of the cavity.
The TCO part number is WB27X10195 and it's available here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams here.
Accessing the cavity TCO will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Jan 29, 2009
  • William Miller
    William Miller Jan 29, 2009
    I mean "flame sensor", not senor.. lol
Had a small fire in the microwave and the power went out. Power is on to the receptacle, but there is no power in the unit. Is there a circuit breaker in the unit or is it toast?
Jim, a lot of microwaves have internal fuse, question is do you really want to bother after it has been on fire. Just a thought.
Good Luck.
May 04, 2016 | GE Hotpoint Over-the-Range Microwave
Rubbing alcohol was spilled down back of GE microwave in the move over 1 year ago. Is the microwave still usable or will the alcohol cause a fire?
Alcohol evaporates. Put a few drops of alcohol in a paper cup and leave it overnight. It should be gone in less than a day. A year should evaporate a lot of alcohol.
If you want to be extra safe and you're tech-savvy, open the case carefully and look for moisture. Otherwise, plug it in somewhere relatively safe and try it (fire extinguisher Class C or ABC handy. -- You need an BC in the kitchen anyway. http://garages.about.com/od/toolsmaterials/a/fire_extinguisher.htm).
Once tested, put the microwave where you need it.
Aug 16, 2013 | General Electric Microwave Oven
Flame Sensor not available
We could look it up if we knew your full model number, but some of their budget models (like some made for Wal-Mart) are made with only turntable parts available.
Within the warranty period, the oven is to be returned to the dealer.
But a fire would not normally be covered under warranty unless the oven came on by itself when idle.
Otherwise, the thermostat / TCO has temperature markings on it, and a generic equivalent or very close type can be matched at a local appliance parts store.
May 17, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Burnt smell in microwave
Hi Diane, that happened to me last year my daughter burned popcorn in microwave. I washed it out with baking soda and water, hot water. Then rinse it out good and place about a tsp. of baking soda in a small bowel with a little water set timer for 10 seconds on high power, this helps to nuetrilize the air flow and now you can use it with out any burn smell.
Feb 22, 2012 | GE Microwave Ovens
My GE Profile over range microwave spacemaker xl 1800 model jvm1870bf02 was working just perfect until my daughter decided to use the microwave as a timer and actual ran the microwave with nothing inside...
Magnetron is blown.
This high-energy microwave-transmitting device hides behind a small plate on side of oven.
The waveguide sticky-out part looks like a small tube.
Normally, water molecules absorb the energy, heating the food.
Without an absorbing 'load' inside the oven cavity, the high-frequency, high power energy bounces back into the magnetron and it destroys itself. (Magnetron Hari-Kiri).
In a nutshell, tech must renew magnetron.
Then iInstruct family members to never run it empty.
Oct 11, 2017 | GE JVM1850 1000 Watts Microwave Oven
My mothers Kenmore countertop microwave oven caught on fire late one evening. She remembers nothing of the fire circumstances as she was in a burn center for six weeks. My sister had the same model...
There is a GE/Kenmore recall: http://injurylaw.reganfirm.com/2007/12/articles/defective-products/cpsc-notice-ge-ge-profile-kenmore-microwave-ovens-recalled/. I don't know if your relative's models are involved. I suggest that you file an incident report with the Consumer Product Safety Commission.
Aug 03, 2009 | Kenmore Microwave Ovens
GE Microwave model JVM1640SJ 03 does not turn on
I keep reading it is the control board. Some have reported fires as well. I am gonna try to find a replacement control board for mine and if no luck no more GE microwaves!
Jan 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
80 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
