Question about GE Advantium SCA2000B Microwave Oven
Advantium Speedcook 120 interior light went out
How do I repair it or change it out?
  • GE Master
  • 9,086 Answers
There's a step-by-step guide with photos here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
These use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Jan 29, 2009
240V Advantium - Halogen Speedcook Not Working
If purchased "new" 6 months ago, it should still be under warranty. Call repair service....
Oct 18, 2014 | Microwave Ovens
Advantium 120 interior light won't go out
door switch is bad or out of adjustment I have a dometic that does this sometimes I just slam it a little harder
Jan 29, 2014 | GE Advantium 120 Convection/Microwave Oven
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Hi, my problem is with my GE advantium speedcook microwave oven. When using 'speedcook' feature, the oven starts, then there is sparking inside the circuit board area, followed by a loud POP, and this...
  • Select the "Options" menu and adjust the clock display settings if the display is blank. Set the clock if the oven won't start. The clock must be set for the oven to work properly, as oven programming is dependent on the clock.
  • Close the door tightly if the oven won't start. The oven won't start if the door isn't closed. You can identify from the lights whether the oven failing to start is related to the door or to the power supply. If the control panel is illuminated and interior lights are on when you open the oven door, you can be sure the oven is receiving power and any starting problems are due to the door not being closed tightly.
  • Press and hold the "Clear/Off" button if the oven performs strangely. Be sure to hold it for a few seconds. This will reset the GE Advantium.
    But as you mentioned that there is /was a loud noise this is a indication of the unit make any usual noise (groaning, gurgling, etc.?) or was / is it either louder or quieter than normal?It may be as simple as the top door switch or its mount or it may be a bad magnetron or shorted diode.
    For manual of the oven.please click the link below:--
  • http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40577-1.pdf
  • Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • Aug 12, 2010 | GE Advantium 120 Convection/Microwave Oven
    How do you change the inside light bulb in the advantium 120 mocel # sca1001hss01? The cooking is fine, the speedcook light works. I just need to know how to change the interior light
    We have the service / repair manual for this model and have uploaded it to our site here to help you.
    It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
    Most computers will open this document automatically, but you may need the free Adobe Reader.
    You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
    But bulbs can usually be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
    These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
    Jul 14, 2009 | GE JVM1650 1000 Watts Microwave Oven
    GE Advantium 120 Speedcook Oven
    THERE IS NO EXTERNAL VENT NO NEED TO CUT ANY HOLES GO TO THERE WEB SITE AND YOU WILL FIND THE MODEL YOU WANT, THERE ARE SEVERAL--IF IT IS VENTED IT HAS TO BE IN THE UNIT NO OUTSIDE VENT, IT IS A HOLEGEN LIGHT BULD WITH A MICROWAVE
    May 29, 2009 | GE Advantium 120 Convection/Microwave Oven
    Advantium Bulb replacement
    You are describing the little bulb in the front. The speedcook light is a different bulb
    See: http://www.instructables.com/id/GE-Advantium-Microwave-Halogen-Lightbulb-Replaceme/
    Apr 12, 2008 | GE Advantium SCA1000H Convection /...
    GE Advantium SCA2000B Microwave Oven Logo
    129 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    D. E. Hev
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
