Question about Sony CDP-CE315 5-Disc CD Changer
Disc tray keeps moving and doesn't stop to play
When you turn on CD player, the disc tray starts moving randomly and doesn't stop to play the disc.
4 Suggested Answers
carputers
  • 255 Answers
SOURCE: I have a sony 5 disc cd player. The cd tray will
motor is wearing out, or belt is slipping, or teeth are worn down
Posted on Sep 08, 2009
dunnbiker
  • 8546 Answers
SOURCE: My Sony Mega Storage 400
In computers there is no real randomness.
http://www.google.com/search?tbm=isch&hl=en&source=hp&biw=1195&bih=959&q=Denon+DRM710&gbv=2&oq=Denon+DRM710&aq=f&aqi=&aql=&gs_sm=e&gs_upl=1283l2359l0l2627l2l2l0l0l0l0l240l240l2-1l1l0
Repeats are not forbidden in a true random pattern anyway.
Posted on Aug 22, 2011
skywavebe
  • 1258 Answers
SOURCE: sony 5 disc cd player won't play 5 cds but plays just 1 disc
Check the mode of operation. There can be a setting where it just plays one disc. Random or mixed will give you more songs to get to other discs.
Posted on Dec 27, 2012
Is there an easy fix to the problem given in the details section below?
No there will not be a easy fix for this. You can keep putting up with this the way you have been or buy a new receiver and try to sell this one on craigslist, eBay, etc.
Jan 20, 2016 | Sony CDP-CE375 5-Disc CD Changer
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
Sony 5 disc cd player won't play 5 cds but plays just 1 disc
Dec 26, 2012 | Sony CDP-CE375 5-Disc CD Changer
Nakamichi cd cassette player 1 not spinning discs
There's a Music Bank 7-disc player in use in my bedroom these days. Nice unit, but they used to come in for service once in a while- from what I could tell, these units don't 'park' the CD drawers on a soft power off- they simply shut down. When powered up again, they sometimes let the disc last in play slide off the tray & jam the machine. I've had no issues, as long as I always hit stop, wait for it to park, and then shut off. The analog output's sound has been very good (has a coax out as well).
Jul 28, 2012 | Nakamichi Audio Players & Recorders
I put CD into cd tray, the tray and CD go into the player, it says loading, but nothing happens and it continues to say loading. I cannot even eject the CD, I have to power it off and back on to get the...
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.....
Sep 14, 2011 | Philips MX6050D System
Good evening, my cd player just stopped working in my expedition. It keeps saying cd error. Even when i try to eject the cd it says the same thing or when i swith cd's. Its a factory 6 cd changer...
I had this happen in my old dodge stratus. My trick to remove cd's was when you stopped or parked the car turn vehicle off and hit the eject button and it will usually eject the disc. remove all discs and then install them again when car is parked and not moving as vibration and bumps while driving can sometimes miss align the disc in the player. Sometimes when the stereo didn't work at all I disconnected the battery and it would reset and work. If this doesn't work it may be broken. Good Luck.
Jul 05, 2011 | 2003 Ford Expedition
Onkyo C-707chx cd tray jammed won't open won't play
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Jun 07, 2009 | Onkyo DX-C390 6-Disc CD Changer
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Sony CDP-CE315 5-Disc CD Changer Logo
20 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
